http://forum.openscad.org/file/n18544/openscaderror.png When I try and
render openSCAD programs that are slightly more complex than some other
programs, computer has a breakdown and openSCAD stops responding. It throws
up the error message in the picture when the object has nearly rendered and
gives me no choice but to close openSCAD. Does anyone else have this issue
and know a way of getting around it?
Thanks in advance,
Patrick
View this message in context: http://forum.openscad.org/Issue-while-rendering-image-tp18544.html
That happens when it runs out of memory. (consider upping your swap file aka
virtual memory/paging file size)
Usually takes a big design tho.
Care to share your code, see if it works for others?
View this message in context: http://forum.openscad.org/Issue-while-rendering-image-tp18544p18551.html
I have just tried increasing the virtual memory and that has not solved the
problem. OpenSCAD still crashes at the same stage in the rendering. I'v
attached the file that I'm trying to render below.
Chassis.scad http://forum.openscad.org/file/n18559/Chassis.scad process.
View this message in context: http://forum.openscad.org/Issue-while-rendering-image-tp18544p18559.html
Renders in 7 seconds here. OpenSCAD 2015.05.16 (git e673fff)
process.
not solved the problem. OpenSCAD still crashes at the same
stage in the rendering. I'v attached the file that I'm trying
to render below.
This previews instantly and renders in about 5 or 6 seconds
with not much memory consumption (on Debian/testing with the
latest nightly build).
What OpenSCAD version is that and what system is it running
on (maybe post the content of the Help->Library Info dialog).
I suspect you hit a bug as the complexity of the model does
not look like it should run out of memory even on 32-bit
systems.
Here is the library info. Also I have no issue with compiling this file, it
just won't render.
OpenSCAD Version: 2016.04.06
System information: Windows 8.1 (v6.3.0.0) 4 CPUs 7.47 GB RAM
Compiler: GCC "5.2.0" 64bit
Boost version: 1_57
Eigen version: 3.2.5
CGAL version, kernels: 4.5, Cartesian, Extended_cartesian, Epeck
OpenCSG version: OpenCSG 1.4.0
Qt version: 5.5.1
QScintilla version: 2.8.4
MingW build: MingW64
GLib version: 2.44.1
Application Path: C:/Program Files/OpenSCAD
Documents Path: C:\Users\Patrick\Documents
Resource Path: C:/Program Files/OpenSCAD
User Library Path: C:/Users/Patrick/Documents/OpenSCAD/libraries
User Config Path: C:\Users\Patrick\AppData\Local/OpenSCAD
Backup Path: C:/Users/Patrick/Documents/OpenSCAD/backups
OPENSCADPATH:
OpenSCAD library path:
C:/Program Files/OpenSCAD\libraries
View this message in context: http://forum.openscad.org/Issue-while-rendering-image-tp18544p18562.html
Hmm, nothing obvious jumping out. I'd suggest to
Try the latest snapshot version (just using the ZIP
package will not overwrite any installed version).
Check if the graphics driver is up to date, although
those issues usually hit with preview, so that's
probably no the issue here.
Also I have no issue with compiling this file, it just
won't render.
Not sure I follow. I understand that means F5 works
but F6 crashes?
Yes that's what I mean.
won't render.
but F6 crashes?
View this message in context: http://forum.openscad.org/Issue-while-rendering-image-tp18544p18567.html
tp3 wrote
I have just tried this and I'm still having the issue.
View this message in context: http://forum.openscad.org/Issue-while-rendering-image-tp18544p18568.html
On 10/06/2016 07:24 PM, Entropic wrote:
Any details in the Windows Event Log?
(https://www.winhelp.us/event-viewer-in-windows.html)
