I hit upon an interesting use case. If I have two files A and B, and B
includes A (keyword /include/) which contains a function/module that
references a special variable, setting the variable in B will be seen in A.
However, if B uses A (keyword /use/), then the function/module will not see
the special variable set in the global scope of B (though, it can be passed
as a parameter).
This doesn't seem consistent. What do you think?
View this message in context: http://forum.openscad.org/Special-variable-scoping-rules-tp20305.html
To avoid any misunderstandings, could your provide testable code for this, including expected and actual results?
Sure:
// File A$special="No, I'm just weird.";function special() = $special;module
special(){ echo($special);}// File
Binclude<A.scad>//use<A.scad>echo (special());$special = "I'm
special!";special();
If include is used, then /"I'm special!"/ comes up twice, this is what I
expected for both include and use. When use is used, then /"No, I'm
just weird."/ comes up.
View this message in context: http://forum.openscad.org/Special-variable-scoping-rules-tp20305p20310.html
When file A.scad is included there is only one top level scope so it works
as expected. I.e. just the same as if you pasted A.scad into B.scad.
When you use a file things get very weird. The used file has its own
separate top level scope. But one would expect dynamic scope variables to
override that when functions and modules are called.
This is the work around that I use and I don't have an explanation why it
works.
// File A
special= $special == undef ? "No, I'm just weird." : $special;
function special() = special;
module special()
echo(special, $special);
If $special is not set in B.scad then it prints:
ECHO: "No, I'm just weird."
ECHO: "No, I'm just weird.", undef
If $special is set then it prints:
ECHO: "I'm special!"
ECHO: "I'm special!", "I'm special!"
On 3 February 2017 at 22:06, adrian adrianh.bsc@gmail.com wrote:
Sure:
// File A
module special()
echo($special);
// File B
include<A.scad>
//use<A.scad>
echo (special());
$special = "I'm special!";
special();
View this message in context: Re: Special variable scoping rules
at Nabble.com.
works.
It seems that when you use an OpenSCAD file, the assignments in the used
file override the assignments in the main file.
View this message in context: http://forum.openscad.org/Special-variable-scoping-rules-tp20305p20345.html
So to me, this sounds like it is a bug. It's definitely not what I would
have expected. What does eveyone else think?
View this message in context: http://forum.openscad.org/Special-variable-scoping-rules-tp20305p20361.html
It's hard to say because OpenSCAD's scope rules are unique, so you can't
compare them with an existing language to say what is expected in this
situation. You can't normally inject symbols into another module you are
using.
It seems you can inject special variables but whether they should override
special variables in the used module I am not sure. It is probably more
useful if they do but you can work around it.
View this message in context: http://forum.openscad.org/Special-variable-scoping-rules-tp20305p20362.html
Thanks Adrian,
Special variables is probably one of the worst design mistakes in OpenSCAD. I would strongly recommend not using your own special variables. The main purpose of introducing these was to allow dynamic binding of tessellation density ($fn/$fs/$fa) variables, but the mechanism was (somehow) extended to catch all variables starting with ‘$’.
I’ll look into this specific case as soon as I find enough space cycles..
They are essential for passing parameters to children. For example:
function layout_offset(widths, i, gap = 2) = i == 0 ? widths[0] / 2
: layout_offset(widths, i - 1, gap) + widths[i - 1] / 2 + gap + widths[i] /
2;
module layout(widths, gap = 2) {
for($i = [0 : len(widths) - 1])
translate([layout_offset(widths, $i, gap), 0, 0])
layout([for(p = pillars) pillar_od(p)])
pillar(pillars[$i]);
On 8 February 2017 at 05:10, Marius Kintel marius@kintel.net wrote:
Thanks Adrian,
Yes, there are naturally good uses of such constructs (for the above-average power users :))
A good discussion would be the best way of achieving this in the context of a future language revamp.
