Syntax Query
Trygon
Thu, Aug 6, 2015 7:41 AM
Question 1
Is it acceptable to omit the curly braces after if and for statements if
there is only one child object?
Question 2
Should union() always be specified or is it OK to rely on implicit union
operations?
// example 1
if(true) cube(20);
// example 2
translate([0,0,0]) {cube(30,center=true);cube(30);}
sphere(r=18);
// example 3 - combining 1 & 2
if(true) translate([10,0,0]) {cube(30,center=true);cube(30);}
View this message in context: http://forum.openscad.org/Syntax-Query-tp13457.html
Question 1 Is it acceptable to omit the curly braces after if and for statements if there is only one child object? Question 2 Should union() always be specified or is it OK to rely on implicit union operations? // example 1 if(true) cube(20); // example 2 difference(){ translate([0,0,0]) {cube(30,center=true);cube(30);} sphere(r=18); // example 3 - combining 1 & 2 if(true) translate([10,0,0]) {cube(30,center=true);cube(30);} -- View this message in context: http://forum.openscad.org/Syntax-Query-tp13457.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Aug 6, 2015 9:15 AM
Q1. Yes. Note it is often good to use round braces in the if expression, as
you have. e.g.
if (thisBooleanVariable) cube(); // in this exact case without () you get an
error
else sphere();
Q2.
implicit union() is only on the top level of the main program or a module
AFAIK.
using {} without a union(), in your ex. 2&3, can be problematic if it
contains geometry.
I think {} turns into group{} (not documented), I find it is inconsistent.
Don't use it.
View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13458.html
Q1. Yes. Note it is often good to use round braces in the if expression, as you have. e.g. if (thisBooleanVariable) cube(); // in this exact case without () you get an error else sphere(); Q2. implicit union() is only on the top level of the main program or a module AFAIK. using {} without a union(), in your ex. 2&3, can be problematic if it contains geometry. I think {} turns into group{} (not documented), I find it is inconsistent. Don't use it. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13458.html Sent from the OpenSCAD mailing list archive at Nabble.com.
B
bobc
Thu, Aug 6, 2015 12:28 PM
Q1) round braces around the "if" expression are not just a good idea, they
are mandatory! :)
Q2) a statement such as translate () {...} used to create a group is fine,
but will perform implicit union. I normally use group() in that sort of
case, but group() and union() are equivalent.
"{A; B;}" does not become "group() {A;B;}" , it becomes "A; B;". Probably
not what is desired.
viz
difference ()
{ cube(); sphere(); }
cube();
=> CSG Tree
group() {
cube(size = [1, 1, 1], center = false);
sphere($fn = 0, $fa = 12, $fs = 2, r = 1);
There is another quirk in the syntax I noticed:
cube () { cube(); }
compiles and renders without error/warning, but the second cube is ignored.
View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13459.html
Q1) round braces around the "if" expression are not just a good idea, they are mandatory! :) Q2) a statement such as translate () {...} used to create a group is fine, but *will* perform implicit union. I normally use group() in that sort of case, but group() and union() are equivalent. "{A; B;}" does not become "group() {A;B;}" , it becomes "A; B;". Probably not what is desired. viz difference () { { cube(); sphere(); } cube(); } => CSG Tree group() { difference() { cube(size = [1, 1, 1], center = false); sphere($fn = 0, $fa = 12, $fs = 2, r = 1); cube(size = [1, 1, 1], center = false); } } There is another quirk in the syntax I noticed: cube () { cube(); } compiles and renders without error/warning, but the second cube is ignored. -- View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13459.html Sent from the OpenSCAD mailing list archive at Nabble.com.
JL
Jean-Paul Louis
Thu, Aug 6, 2015 4:00 PM
Bob,
Please do not confuse a beginner. You did not respond to his Q1.
He asked about the “{}” around a single statement after an if() definition,
and you responded about the “()” of the test itself.
Just my humble $0.02,
Jean-Paul
AC9GH
are mandatory! :)
viz
difference ()
cube();
=> CSG Tree
group() {
cube () { cube(); }
Bob, Please do not confuse a beginner. You did not respond to his Q1. He asked about the “{}” around a single statement after an if() definition, and you responded about the “()” of the test itself. Just my humble $0.02, Jean-Paul AC9GH > On Aug 6, 2015, at 8:28 AM, bobc <bobcousins42@googlemail.com> wrote: > > Q1) round braces around the "if" expression are not just a good idea, they > are mandatory! :) > > Q2) a statement such as translate () {...} used to create a group is fine, > but *will* perform implicit union. I normally use group() in that sort of > case, but group() and union() are equivalent. > > "{A; B;}" does not become "group() {A;B;}" , it becomes "A; B;". Probably > not what is desired. > > viz > > difference () > { > { cube(); sphere(); } > cube(); > } > => CSG Tree > group() { > difference() { > cube(size = [1, 1, 1], center = false); > sphere($fn = 0, $fa = 12, $fs = 2, r = 1); > cube(size = [1, 1, 1], center = false); > } > } > > There is another quirk in the syntax I noticed: > > cube () { cube(); } > > compiles and renders without error/warning, but the second cube is ignored. > > > > > -- > View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13459.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
B
bobc
Thu, Aug 6, 2015 4:38 PM
Sorry, yes you are right! I was responding to Michael's comment, he confused
me talking about round braces.
For the OP, I believe that
if (1) cube ();
if (1) { cube (); }
if (1) group () { cube(); }
if (1) union () { cube(); }
are all identical in function.
View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13462.html
Sorry, yes you are right! I was responding to Michael's comment, he confused me talking about round braces. For the OP, I believe that if (1) cube (); if (1) { cube (); } if (1) group () { cube(); } if (1) union () { cube(); } are all identical in function. -- View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13462.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Trygon
Thu, Aug 6, 2015 6:32 PM
OK thanks, in summary instead of writing:
if() {translate() union{cube();cube();}}
it can simply be written as:
if() translate() {cube();cube();}
I hope that the above is correct...
The only item I am now unsure of is group(), which does not appear to be
documented, but OpenSCAD clearly recognises.  Is it a deprecated boolean
operator?
View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13463.html
OK thanks, in summary instead of writing: if() {translate() union{cube();cube();}} it can simply be written as: if() translate() {cube();cube();} I hope that the above is correct... The only item I am now unsure of is group(), which does not appear to be documented, but OpenSCAD clearly recognises. Is it a deprecated boolean operator? -- View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13463.html Sent from the OpenSCAD mailing list archive at Nabble.com.
runsun
Thu, Aug 6, 2015 7:25 PM
operator?
Go to menu [View][Show CSG tree], where openscad display how shapes are
organized internally, you'll see lots of group() but no union(). Obviously
it's an internal thing.
$  Runsun Pan, PhD
$ -- libs: doctest , faces ( git ), offliner ( git );
tips: hash( 1 , 2 ), sweep , var
View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13464.html
Trygon wrote > The only item I am now unsure of is group(), which does not appear to be > documented, but OpenSCAD clearly recognises. Is it a deprecated boolean > operator? Go to menu [View][Show CSG tree], where openscad display how shapes are organized internally, you'll see lots of group() but no union(). Obviously it's an internal thing. ----- $ Runsun Pan, PhD $ -- libs: doctest , faces ( git ), offliner ( git ); tips: hash( 1 , 2 ), sweep , var $ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD 2015.03.15/2015.04.01.nightly -- View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13464.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Aug 6, 2015 9:15 PM
if (1) cube ();
if (1) { cube (); }
The reason I said to avoid plain { } is the code below (cut down example),
with the commented out union() does not produce the same geometry as with
the uncommented union(). Both for F5 & F6. I came across this yesterday
morning, so it was fresh in my mind.
cube();
//union()
sphere();
cylinder(r=0.5,h=5,true);
View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13465.html
bobc wrote > Sorry, yes you are right! I was responding to Michael's comment, he > confused me talking about round braces. > > For the OP, I believe that > > if (1) cube (); > if (1) { cube (); } > if (1) group () { cube(); } > if (1) union () { cube(); } > > are all identical in function. The reason I said to avoid plain { } is the code below (cut down example), with the commented out union() does not produce the same geometry as with the uncommented union(). Both for F5 & F6. I came across this yesterday morning, so it was fresh in my mind. intersection() { cube(); //union() { sphere(); cylinder(r=0.5,h=5,true); } } ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13465.html Sent from the OpenSCAD mailing list archive at Nabble.com.
BC
Bob Cousins
Thu, Aug 6, 2015 9:47 PM
Yes, that seems like a bug, if not an unexpected feature. the "{..}" gets
flattened in the CSG tree:
group() {
cylinder($fn = 0, $fa = 12, $fs = 2, h = 1, r1 = 0.5, r2 = 0.5, center
= false);
There is no implicit union generated in this case, unlike "if () {...}".
I'm not sure whether this is an unintended side-effect of the syntax, or if
it is needed in some other case?
I don't recall seeing an issue for it, I'm not sure what keywords to search
for. I've probably stumbled across this a few times myself without
realising.
if (1) cube ();
if (1) { cube (); }
cube();
//union()
sphere();
Yes, that seems like a bug, if not an unexpected feature. the "{..}" gets flattened in the CSG tree: group() { intersection() { cube(size = [1, 1, 1], center = false); sphere($fn = 0, $fa = 12, $fs = 2, r = 1); cylinder($fn = 0, $fa = 12, $fs = 2, h = 1, r1 = 0.5, r2 = 0.5, center = false); } } There is no implicit union generated in this case, unlike "if () {...}". I'm not sure whether this is an unintended side-effect of the syntax, or if it is needed in some other case? I don't recall seeing an issue for it, I'm not sure what keywords to search for. I've probably stumbled across this a few times myself without realising. On 6 August 2015 at 22:15, MichaelAtOz <oz.at.michael@gmail.com> wrote: > bobc wrote > > Sorry, yes you are right! I was responding to Michael's comment, he > > confused me talking about round braces. > > > > For the OP, I believe that > > > > if (1) cube (); > > if (1) { cube (); } > > if (1) group () { cube(); } > > if (1) union () { cube(); } > > > > are all identical in function. > > The reason I said to avoid plain { } is the code below (cut down example), > with the commented out union() does not produce the same geometry as with > the uncommented union(). Both for F5 & F6. I came across this yesterday > morning, so it was fresh in my mind. > > intersection() { > cube(); > //union() > { > sphere(); > cylinder(r=0.5,h=5,true); > } > } > > > > ----- > Unless specifically shown otherwise above, my contribution is in the > Public Domain; To the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. This work is > published globally via the internet. :) Inclusion of works of previous > authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ > -- > View this message in context: > http://forum.openscad.org/Syntax-Query-tp13457p13465.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Thu, Aug 6, 2015 10:00 PM
Given group() and the use of plain {} is undocumented, I just steer clear
most of the time.
I just use {} to group related variables so they can be collapsed in the
editor.
View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13467.html
Given group() and the use of plain {} is undocumented, I just steer clear most of the time. I just use {} to group related variables so they can be collapsed in the editor. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Syntax-Query-tp13457p13467.html Sent from the OpenSCAD mailing list archive at Nabble.com.
