Hi, I am running openscad in AWS lambda. It works often but some times it
randomly crashes. When it crashes I get return code: -4.
output: Could not initialize localization.
ECHO: "Starting up ..."
The echo statement is the first line in the openscad file. The error about
localization occurs even when it works fine so that doesn't seem to be the
problem. The code and environment doesn't change as far as I can tell
between the times it works or when it doesn't. How can I troubleshoot it?
What could cause code -4 to be returned? Is there any way I can get any more
output on why it is crashing and what I can do about it?
I am using OpenSCAD version 2017.07.31.
Thank you
Much can go wrong with native code on Lambda.
I would look at these things:
It works fine most of the time so it must be compatible, the problem only
happens occasionally. Lambda did not kill the process - the execution of
openscad returns "-4", quite quickly and then continues executing my code.
Lambda shows me the memory used and it is not close to the max, increasing
the memory doesn't help. What does a return value of "-4" mean?
I can't recall if I built the binary myself or downloaded a prebuilt - I did
that a while ago. The debug build with a stack trace sounds like the way to
go.
Thank you
We don’t use negative return values.
A negative value usually means that the process was killed from the outside.
