mintUpdate 4.9.3.3 is complaining about the latest openscad update being
"not authenticated". Anyone else seeing this?
openscad-nightly (version 20161125T013427.gitf560510-1729.1) will be
upgraded to version 20161130T003602.gitb942e96-1733.1
Thanks,
Bill m
update being "not authenticated". Anyone else seeing this?
will be upgraded to version 20161130T003602.gitb942e96-1733.1
Yes, the old OBS signing key expired. This is now extended
but needs to be re-imported to the local key chain.
See note at http://www.openscad.org/downloads.html#snapshots
Hi Torsten,
Ok, I followed the script, still not working. I tried 'su root' before
the wget, made no difference. Already had the
*/etc/apt/sources.list.d/openscad.list *file, with correct contents,
re-wrote it anyway, still no luck. This is on Ubuntu 14.04 LTS system.
Any ideas?
Regards,
Bill m
On 12/02/2016 05:18 PM, William W Martin wrote:
Hi Torsten,
'su root' before the wget, made no difference. Already
had the */etc/apt/sources.list.d/openscad.list *file,
with correct contents, re-wrote it anyway, still no
luck. This is on Ubuntu 14.04 LTS system. Any ideas?
The important part is:
NOTE: If you get errors about an expired key valid
till 2016-11-28, please re-import via the following
command.
wget -qO - http://files.openscad.org/OBS-Repository-Key.pub | sudo apt-key add -
You can do that also in separate steps by just downloading
the file via web browser and then just run the command
"apt-key add OBS-Repository-Key.pub" as root.
After this, a call to "apt update" should not get errors
about the expired key anymore.
Well....now it is magically working again. May be an Update Manager
issue, it started working when a new update for something else was added
to the list of updates.
Bill m
On 12/02/2016 08:18 AM, William W Martin wrote:
Hi Torsten,
Any ideas?
Regards,
Bill m
See note athttp://www.openscad.org/downloads.html#snapshots
