Hi Skybound,
Firstly, your post is still flagged as "This post has NOT been accepted by
the mailing list yet", so nobody gets it unless they look.
You need to subscribe to the mailing list
and CLICK THE LINK in the registration email (check your spam folder).
Re the servo.
You need to edit thing-28566 (servo_arm.scad), add line 208
translate([0, 0, head_heigth]) {
if (arm_count) // <--- add this
line - just prevents an error message.
for (i = [0 : arm_count - 1]) {
In you code
Add, at top:
use <servo_arm.scad> // from Thing:28566 (make sure your file and
this are in the same directory)
translate([0,0,20])
rotate([180,0,0])
servo_standard(0,0);
- Adjust your models shaft & the above translate of the servo hub to the
right position.
View this message in context: http://forum.openscad.org/How-to-use-some-else-s-code-with-yours-tp21778p21781.html
Hi Skybound,
<http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1> ,
Re the servo.
1. You need to edit thing-28566 (servo_arm.scad), add line 208
2. In you code
Add, at top:
translate([0,0,20])
rotate([180,0,0])
3. Adjust your models shaft & the above translate of the servo hub to the
right position.
