KM
Kuba Marek
Sun, Apr 10, 2016 11:51 AM
I'm trying to make a parametric NACA 4digit airfoil shape using
polygon(). I have a function that gives me Y coordinate for every X,
and I'm calculating a vector of X, Y coordinates using a list
comprehension.
My problem is that when I select the X spacing too narrow, the
resulting polygon looks like it's skipping some points -- the lower the
stepping, the more points lost.
MWE is attached to this mail. The step size 0.0035 was chosen so that
the problem is visible enough. With step size 0.05 it still looks OK,
lower than that the problem starts to appear with increasing severity.
To verify that the vector fed as an input to the polygons the correct,
the example also renders spheres at positions of the control points.
When I scale the positions in the vector (set scale variable to 100
int the example), the problem disappears.
Is this intended, or a bug?
I'm using OpenSCAD 2015.03, built from source with Gentoo ebuild.
Kuba Marek
comprehension.
Kuba Marek
Sun, Apr 10, 2016 3:23 PM
See if you get better results with this:
extra_scale = 100; // increase if needed
step = 0.0035;
scale = 100*extra_scale;
top = [for(x = [0:step:1]) scale * [x,
0.12 * naca_thickness(x)]];
scale(1/extra_scale ) polygon(points=top);
scale(1/extra_scale ) %for(p = top) translate([p[0], p[1], 0]) sphere(scale
2016-04-10 8:51 GMT-03:00 Kuba Marek blue.cube@seznam.cz:
comprehension.
Kuba Marek
step = 0.0035;
* 0.005);
2016-04-10 8:51 GMT-03:00 Kuba Marek <blue.cube@seznam.cz>:
> Hi,
> comprehension.
> Kuba Marek
Sun, Apr 10, 2016 4:01 PM
comprehension.
Kuba Marek
This is a known bug, and scaling up is the workaround.
https://github.com/openscad/openscad/issues/999
On 10 April 2016 at 07:51, Kuba Marek <blue.cube@seznam.cz> wrote:
> Hi,
> comprehension.
> Kuba Marek
Sun, Apr 10, 2016 4:02 PM
This is a known bug: https://github.com/openscad/openscad/issues/999
KM
Kuba Marek
Sun, Apr 10, 2016 4:30 PM
Weird that I didn't find that bug report :-)
Thanks for your answers, the scaling workaround works well enough.
step = 0.0035;
sphere(scale
comprehension.
the stepping, the more points lost.
that the problem is visible enough. With step size 0.05 it still
looks OK, lower than that the problem starts to appear with
correct, the example also renders spheres at positions of the
control points.
Kuba Marek
> step = 0.0035;
> sphere(scale
> * 0.005);
> > Hi,
> > comprehension.
> > control points.
> > Kuba Marek
Sun, Apr 10, 2016 6:37 PM
Besides, observe that the Naca profile has a very fast variation of the
tangent near x=0 and which varies slowly to the right. You may consider a
varying discretization on sampling x, starting with a fine discretization
for low x and enlaging it for greater x.
2016-04-10 13:30 GMT-03:00 Kuba Marek blue.cube@seznam.cz:
step = 0.0035;
sphere(scale
comprehension.
control points.
Kuba Marek
2016-04-10 13:30 GMT-03:00 Kuba Marek <blue.cube@seznam.cz>:
> > step = 0.0035;
> > sphere(scale
> > * 0.005);
> > > Hi,
> > > comprehension.
> > > control points.
> > > Kuba Marek
N
Neon22
Sun, Apr 10, 2016 9:26 PM
It would be great if you extended the existing NACA library with some more of
the NACA algorithms/codes.
View this message in context: http://forum.openscad.org/Rounding-problem-with-polygon-tp17020p17033.html
KM
Kuba Marek
Sun, Apr 10, 2016 9:39 PM
Yes, that was the plan after I get the rest of my project working :-)
the tangent near x=0 and which varies slowly to the right. You may
consider a varying discretization on sampling x, starting with a fine
discretization for low x and enlaging it for greater x.
step = 0.0035;
sphere(scale
every X, and I'm calculating a vector of X, Y coordinates using
a list comprehension.
lower the stepping, the more points lost.
control points.
100 int the example), the problem disappears.
ebuild.
Kuba Marek
> > > step = 0.0035;
> > > sphere(scale
> > > * 0.005);
> > > > Hi,
> > > > control points.
> > > > ebuild.
> > > > Kuba Marek
KM
Kuba Marek
Sun, Apr 10, 2016 9:45 PM
I'd like to do that, but what I have is a new implementation rather than
an extension :-)
So far it can do all 4 digit codes (based on wikipedia) with
regular discretization in X axis and output to a list or polygon.
Is there a way I can make a pull request to the thingieverse?
Anyway I'm planning to put my code up on github sometime soon.
an extension :-)
> more of the NACA algorithms/codes.
