I want to render a "footprint" shadow of a car, which is enough of a
convincing shadow for me to use in a video game I am making.
I tried using projection() as follows:
module shadow() { color([0,0,0, 1]) projection() car();}
...but it was slow.
So I had the idea to squash the model down on the z-axis into a "flat"
surface, which is close enough to what i need and very quick:
module shadow() { flattenZ = [[ 1 , 0 , 0 , 0 ], [ 0 , 1 , 0
, 0 ], [ 0 , 0 , 0.01 , 0 ], [ 0 , 0 , 0 , 1 ] ];
color([0,0,0, 1]) multmatrix(flattenZ) car();}
As you can see it's not quite flat, but 0.01 flat, which avoids z-fighting
and is not noticeable to the eye.
Thought this was worth sharing.
I've used scale() for this in the past. It obviously doesn't let you render or do booleans as if it was 2D, but when you just need the projection for visual purposes, it works fine.
On May 3, 2021, 13:30 -0700, gingerbeardman matt.sephton@gmail.com, wrote:
I want to render a "footprint" shadow of a car, which is enough of a convincing shadow for me to use in a video game I am making.
module shadow() {
color([0,0,0, 1])
projection()
car();
...but it was slow.
So I had the idea to squash the model down on the z-axis into a "flat" surface, which is close enough to what i need and very quick:
module shadow() {
[ 0 , 1 , 0 , 0 ],
color([0,0,0, 1])
car();
As you can see it's not quite flat, but 0.01 flat, which avoids z-fighting and is not noticeable to the eye.
Yes I think the matrix is the same as scale([1,1,0.01])
module shadow() {
color([0,0,0, 1])
projection()
car();
...but it was slow.
module shadow() {
[ 0 , 1 , 0 , 0 ],
color([0,0,0, 1])
car();
at Nabble.com.
Yes, scale() just fills in a matrix that looks exactly the same as the one
you created, so it will be slightly faster done in C++ rather than OpenSCAD.
On Mon, 10 May 2021 at 21:26, gingerbeardman matt.sephton@gmail.com wrote:
Oh, yes!
at Nabble.com.
