Wish - mouseover parts in viewport should highlight code
S
Scalpel78
Mon, Dec 8, 2014 5:53 PM
Hi, I was thinking... When you have a scenario that consists of multiple
parts I find it tedious to find the correct piece of code that created that
part. I usually sprinkle #'s around to try to identify which node is which
by doing a preview each time I move the # to a new piece of code.
So, my idea is - would it be possible to highlight the line of code that
drew the current object I'm mousing over?
Say for instance I have a this script:
cube(10);
translate([15, 10, 10]) sphere(5);
When I move the mouse over the cube in the viewport the first line should be
highlighted. When I move the mousecursor over the sphere, the second line
should be highlighted.
What do you think? Bad idea?
View this message in context: http://forum.openscad.org/Wish-mouseover-parts-in-viewport-should-highlight-code-tp10431.html
Hi, I was thinking... When you have a scenario that consists of multiple parts I find it tedious to find the correct piece of code that created that part. I usually sprinkle #'s around to try to identify which node is which by doing a preview each time I move the # to a new piece of code. So, my idea is - would it be possible to highlight the line of code that drew the current object I'm mousing over? Say for instance I have a this script: cube(10); translate([15, 10, 10]) sphere(5); When I move the mouse over the cube in the viewport the first line should be highlighted. When I move the mousecursor over the sphere, the second line should be highlighted. What do you think? Bad idea? -- View this message in context: http://forum.openscad.org/Wish-mouseover-parts-in-viewport-should-highlight-code-tp10431.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Dec 8, 2014 5:58 PM
A number of ideas along this line is already listed in the project idea list:
https://github.com/openscad/openscad/wiki/Project%3A-Improve-OpenGL-rendering
I guess we could add some more details there...
On 12/08/2014 06:53 PM, Scalpel78 wrote: > So, my idea is - would it be possible to highlight the line of code that > drew the current object I'm mousing over? > A number of ideas along this line is already listed in the project idea list: https://github.com/openscad/openscad/wiki/Project%3A-Improve-OpenGL-rendering I guess we could add some more details there... ciao, Torsten.
S
Scalpel78
Mon, Dec 8, 2014 9:36 PM
Aha, good, then the idea wasn't as farfetched as I was afraid of.
Hope someone implements it :)
Frode
View this message in context: http://forum.openscad.org/Wish-mouseover-parts-in-viewport-should-highlight-code-tp10431p10434.html
Aha, good, then the idea wasn't as farfetched as I was afraid of. Hope someone implements it :) Frode -- View this message in context: http://forum.openscad.org/Wish-mouseover-parts-in-viewport-should-highlight-code-tp10431p10434.html Sent from the OpenSCAD mailing list archive at Nabble.com.
