Tue, Nov 19, 2019 1:24 AM
Is it legal to give a polyhedron faces that have zero area, e.g. a face like
[ [0,0,0],[0,0,0], [0,0,1],[0,0,1]]? Or a degenerate "triangle" like
[[0,0,0],[0,0,0],[0,0,1]]? What about a completely degenerate faces where
all vertices are equal?
In trying to implement a certain degenerate case in my code I have used some
degenerate faces and it appears to work. (I can render, and add multiple
polyhedra to the model.) But I wonder if there might be hidden problems.
Doug Moen
Tue, Nov 19, 2019 1:26 AM
Degenerate faces like this should generally be avoided. The face has zero area, and the normal vector is [0,0,0]. That's considered defective, and some programs will not allow you to import such a mesh. Other programs won't have a problem.
Tue, Nov 19, 2019 9:20 AM
I think CGAL will throw an exception if you do a union with a unit cube();
> like
> where
> some
> problems.
Tue, Nov 19, 2019 11:14 AM
Nope. Adding more geometry doesn't cause render to fail.
> doug@
>> like
>> where
>> some
>> multiple
>> problems.
> Discuss@.openscad
> Discuss@.openscad
> Discuss@.openscad
Tue, Nov 19, 2019 12:03 PM
Possibly because simple degenerate triangles get removed but ones where the
sum of two sides equals the third and ones where two sides are equal and
the third is zero don't get removed.
I made a branch where I removed all the degenerate triangles but decided it
was pointless without also removing self intersections because both are
consequences of truncating coordinates and grid snapping.
> cube();
> > doug@
> zero
> face
> >> like
> >> where
> used
> >> some
> >> multiple
> >> problems.
> > Discuss@.openscad
> > Discuss@.openscad
> > Discuss@.openscad
