New thread.
I've built libopencsg 1.4.2 from source and installed it.
ldd /usr/bin/openscad-nightly | grep csg
libopencsg.so.1 => /usr/local/lib/libopencsg.so.1 (0x00007fe3dde8f000)
ll /usr/local/lib/libopencsg.so.1
/usr/local/lib/libopencsg.so.1 -> libopencsg.so.1.4.2*
All looks good.
But OpenSCAD still reports -
OpenCSG version: OpenCSG 1.4.0
and my preview issue remains.
Ideas?
do you have a packaged version of opencsg still installed?
does LD_LIBRARY_PATH get checked before other lib paths ?? (I can't
quite remember the order)
you could try setting it to /usr/local/lib
LD_LIBRARY_PATH=/usr/local/lib ./openscad
On 17/07/17 16:57, Ian Oliver wrote:
New thread.
All looks good.
Ideas?
As per comments at the bottom of this thread, setting Orthogonal fixes
this for me.
https://github.com/openscad/openscad/issues/1591
As it happens, I only need perspective to check accuracy of my model
against picture of "real" things, and when doing the latter I'm usually
not slicing, so this is close to a perfect solution.
