Carsten said:
Personally, I use modules in OpenSCAD extensively, but I would be even
happier with a class concept with both member functions and data members. A
3d hierarchy can be expressed also that way.
... Perhaps one could keep the OpenSCAD language limited and use it as an
intermediate representation generated by the kind of object oriented
language I am dreaming of :-)
The OpenSCAD2 design that I am working on will have a very simple object
model. Consider a typical OpenSCAD script: it has some named numeric
parameters at the top, then some function and module definitions, then some
top level geometry statements that render the model based on the
parameters. So that's an object. An object is a set of top level
definitions (name/value pairs), plus a list of values (which are normally
geometric shapes). OpenSCAD2 has a syntax for referencing an external
library file as an object, and a syntax for object literals (just an
OpenSCAD script, surrounded by braces). Given an object, you can reference
its named components using dot notation (object.name), or you can reference
the object in a geometric context (as an argument to a geometric
transformation, or at the top level of a script), in which case the object
behaves like its geometry.
There are a few more details, but that's the basic idea. Note that this is
much simpler than object oriented programming. There are no mutable
objects, no classes or user defined types, no support for encapsulation or
data abstraction. But, as I mentioned, objects do have "member functions
and data members", so it may go part way towards satisfying Carsten's
requirements. Objects will also satisfy Runsun's requirement for
associative arrays. I also think that constructing a 3D model as a tree of
objects will give us a better (more declarative) way to support
bill-of-materials.
We want to preserve the simple and declarative nature of OpenSCAD. I
believe that this very simple object model will address some of the main
pain points in doing geometric modelling with OpenSCAD, without turning it
into a complex OOP language.
On 14 May 2015 at 12:58, Carsten Arnholm arnholm@arnholm.org wrote:
Hi Marius!
On 2015-05-14 16:22, Marius Kintel wrote:
OpenSCAD aim to directly describe a 3D design hierarchy, not merely
execute code to spit out 3D objects.
I do understand, and any language chosen would obviously have to support
the design hierarchy. As far as I can tell, many languages should be able
to do it. Personally, I use modules in OpenSCAD extensively, but I would be
even happier with a class concept with both member functions and data
members. A 3d hierarchy can be expressed also that way.
Anyway, this was just my thoughts. OpenSCAD has made decisions long ago,
which I respect. Perhaps one could keep the OpenSCAD language limited and
use it as an intermediate representation generated by the kind of object
oriented language I am dreaming of :-)
Using a faster and more powerful CAD kernel is indeed on the radar.
Sadly, the world of Open Source CAD kernels is severely limited.
If we manage to get sufficient contributions or funding, working
towards such a kernel would be doable. If you have any spare
time, this would be a good place to start:
https://github.com/openscad/openscad/wiki/Project%3A-Survey-of-CSG-algorithms
..or if someone has the experience to do so: Evaluate OpenCascade as an
option. Most people I’ve talked to who’ve ever used that has strongly
recommended me never to touch it though. ..but FreeCAD somehow manages.
The funny thing is, I evaluated CAS.CADE (as it was known at the time) in
about 1994-1995 for the work previously mentioned. It was marketed by Matra
Datavision in France and I even went to see them a couple of times. They
had what we thought was a curious idea of their own home-grown language
(CDL) encapsulating the C++ kernel. Nowadays it looks like some finally
agree with our thoughts at the time :
http://dev.opencascade.org/doc/overview/html/occt_dev_guides__cdl.html
"Please note that CDL is considered as obsolete and is to be removed in
one of future releases of OCCT." :-)
CAS.CADE was closed source and extremely expensive back then, but we still
struggled very hard to make use of it. The end result for us was that it
was dropped and replaced it with ACIS. Only a few years ago, I discovered
CAS.CADE had become quasi open source as OpenCascade (OCCT). I also found
there is now something called OCE - Open CASCADE Community Edition
https://github.com/tpaviot/oce/
I had the idea of trying OCE, but frankly not enough incentive and power
to do it, and my work is different now. OCE may probably be something to be
considered for OpenSCAD CAD kernel, I suspect OpenCascade has come a long
way since I saw it.
Sidenote: One thing that has struck me is that the compilation in OpenSCAD
is quite fast, but the rendering (F6) is extremely slow. I was wondering if
the generation of triangles for STL really needs the graphical rendering to
be completed first? If not, one could imagine a function to export the
compiled model to STL and use an external viewer to speed things up when
iterating on a complex design that takes forever to render.
Is there a {beta,alpha,prototype} version of OpenSCAD2 somewhere for
people to play with? Is there a spec to read?
I, for one, would like to see anything you are willing to share on this.
G. Wade
On Sat, 16 May 2015 12:44:38 -0400
object model. Consider a typical OpenSCAD script: it has some named
numeric parameters at the top, then some function and module
definitions, then some top level geometry statements that render the
model based on the parameters. So that's an object. An object is a
set of top level definitions (name/value pairs), plus a list of
values (which are normally geometric shapes). OpenSCAD2 has a syntax
for referencing an external library file as an object, and a syntax
for object literals (just an OpenSCAD script, surrounded by braces).
Given an object, you can reference its named components using dot
notation (object.name), or you can reference the object in a
geometric context (as an argument to a geometric transformation, or
at the top level of a script), in which case the object behaves like
its geometry.
this is much simpler than object oriented programming. There are no
mutable objects, no classes or user defined types, no support for
encapsulation or data abstraction. But, as I mentioned, objects do
have "member functions and data members", so it may go part way
towards satisfying Carsten's requirements. Objects will also satisfy
Runsun's requirement for associative arrays. I also think that
constructing a 3D model as a tree of objects will give us a better
(more declarative) way to support bill-of-materials.
main pain points in doing geometric modelling with OpenSCAD, without
turning it into a complex OOP language.
Hi Marius!
support the design hierarchy. As far as I can tell, many languages
should be able to do it. Personally, I use modules in OpenSCAD
extensively, but I would be even happier with a class concept with
both member functions and data members. A 3d hierarchy can be
ago, which I respect. Perhaps one could keep the OpenSCAD language
limited and use it as an intermediate representation generated by
the kind of object oriented language I am dreaming of :-)
as an option. Most people I’ve talked to who’ve ever used that has
strongly recommended me never to touch it though. ..but FreeCAD
somehow manages.
time) in about 1994-1995 for the work previously mentioned. It was
marketed by Matra Datavision in France and I even went to see them
a couple of times. They had what we thought was a curious idea of
their own home-grown language (CDL) encapsulating the C++ kernel.
Nowadays it looks like some finally agree with our thoughts at the
time :
removed in one of future releases of OCCT." :-)
we still struggled very hard to make use of it. The end result for
us was that it was dropped and replaced it with ACIS. Only a few
years ago, I discovered CAS.CADE had become quasi open source as
OpenCascade (OCCT). I also found there is now something called OCE
OpenSCAD is quite fast, but the rendering (F6) is extremely slow. I
was wondering if the generation of triangles for STL really needs
the graphical rendering to be completed first? If not, one could
imagine a function to export the compiled model to STL and use an
external viewer to speed things up when iterating on a complex
Controlling complexity is the essence of computer programming
-- Brian Kernighan
Hi G. Wade.
No prototype or spec yet. I've been working on the design for a month, with
feedback from Marius, and for the last week, I've been trying to create a
bison grammar that is backward compatible with current OpenSCAD, and also
free of conflicts.
Now I've reached the point where I need to collaborate with more people.
Once I convert my latest design iteration to bison and resolve the
conflicts, I'll write a spec and send you the link. Thanks for volunteering
to read it.
Doug.
G. Wade
its geometry.
Hi Marius!
somehow manages.
time :
-- Brian Kernighan
On Sat, 16 May 2015 15:09:31 -0400
Hi G. Wade.
month, with feedback from Marius, and for the last week, I've been
trying to create a bison grammar that is backward compatible with
current OpenSCAD, and also free of conflicts.
people. Once I convert my latest design iteration to bison and
resolve the conflicts, I'll write a spec and send you the link.
Thanks for volunteering to read it.
Doug.
Glad to do it. It sounds like an interesting approach that could help
OpenSCAD without breaking what makes it useful in my work.
G. Wade
this.
G. Wade
data members. A 3d hierarchy can be expressed also that way.
named numeric parameters at the top, then some function and module
the model based on the parameters. So that's an object. An object
is a set of top level definitions (name/value pairs), plus a list
of values (which are normally geometric shapes). OpenSCAD2 has a
syntax for referencing an external library file as an object, and
a syntax for object literals (just an OpenSCAD script, surrounded
by braces). Given an object, you can reference its named
the object behaves like its geometry.
no mutable objects, no classes or user defined types, no support
for encapsulation or data abstraction. But, as I mentioned,
objects do have "member functions and data members", so it may go
part way towards satisfying Carsten's requirements. Objects will
also satisfy Runsun's requirement for associative arrays. I also
think that constructing a 3D model as a tree of objects will give
us a better (more declarative) way to support bill-of-materials.
OpenSCAD. I believe that this very simple object model will
address some of the main pain points in doing geometric modelling
with OpenSCAD, without turning it into a complex OOP language.
Hi Marius!
merely execute code to spit out 3D objects.
languages should be able to do it. Personally, I use modules in
OpenSCAD extensively, but I would be even happier with a class
concept with both member functions and data members. A 3d
long ago, which I respect. Perhaps one could keep the OpenSCAD
language limited and use it as an intermediate representation
generated by the kind of object oriented language I am dreaming
of :-)
radar.
limited.
working
OpenCascade as an option. Most people I’ve talked to who’ve
ever used that has strongly recommended me never to touch it
was marketed by Matra Datavision in France and I even went to
see them a couple of times. They had what we thought was a
curious idea of their own home-grown language (CDL)
finally agree with our thoughts at the time :
but we still struggled very hard to make use of it. The end
result for us was that it was dropped and replaced it with
ACIS. Only a few years ago, I discovered CAS.CADE had become
quasi open source as OpenCascade (OCCT). I also found there is
in OpenSCAD is quite fast, but the rendering (F6) is extremely
slow. I was wondering if the generation of triangles for STL
really needs the graphical rendering to be completed first? If
not, one could imagine a function to export the compiled model
-- Brian Kernighan
Reality is just a convenient measure of complexity.
-- Alvy Ray Smith
That was my reaction as well.
In my opinion, classes are not there to complicate things. On the
contrary, it is an important tool for simplification. Being able to name
a type, encapsulate its data members and provide member functions would
go a long way towards the goal of being more expressive without
complicating things.
In my line of thinking, which may be different from OpenSCAD2 (as I have
not grasped the full idea of it), the main ideas would be:
classes would be used for constructing named parametric objects
(instantiation) and being able to union, intersect and difference the
result with other named or unnamed objects (union(), intersect() and
difference() would be member functions on any class. unlike a module, a
class may contain data members unique to each instance created.
Below is just a silly example to illustrate: 2 lollipops on a table.
The difference between a module and a class here is that a class may be
instantiated and may remember its construction parameters so they can be
re-used later. It also owns its CSG object.
// classes are new
class lollipop {
// a constructor is a member function with the same name as the class
lollipop(rad, diam, hei)
// keep data members
radius = rad;
diameter = diam;
height = hei;
// "this CSG object"
this = union() {
translate([0,0,height]) sphere(r=radius);
cylinder(d=diameter,h=height);
// data members of the class
radius;
diameter;
height;
// modules exist as before
module example_model()
// create 2 lollipops of different sizes
// the second is dependent on the first
lolA = lollipop(rad=10,diam=2,hei=50);
lolB = lollipop(lolA.radius*2,lolA.diameter*3,lolA.height);
// create a cube representing the table plate. Here,
// the construction parameters cannot be accessed later
// since the cube is a primitive only
table_plate = cube(size=[100,100,5],center=true);
// union the lollipops with the table plate and return it
table_plate.union(lolA);
table_plate.union(lolB);
// be explicit about what the module returns
return table_plate;
// construct the exmple model and export it as STL
example_model().render().export("STL","lollipops_on_table.stl");
You could go on, classes could have data members being instantiations of
other classes, or even containers containing such.
The above is just meant as a supplement to what I wrote before,
illustrating the idea that the OpenSCAD language could be extended in a
direction which would be immediately recognisable to programmers, while
still being backwards compatible with existing OpenSCAD code. If you
want to express things as it is currently being done, you can, but you
also have other possibilities.
Again, just my thoughts. I don't know if it would be easy to implement.
Carsten
@doug.moen,
I believe your oop-like idea is exactly what I have in mind.
The first time I learned about Openscad, I was amazed by how easy it can
produce a shape with simple code. I went on to design a crank, with as
simple as two objects: an arm ( a bar between points A and B) and a wheel.
When the wheel turns, A should follows a point C on the wheel.
Then I realize that openscad object has no way to bear data, so once it's
made, it can't following the coordinate of C. As a result, moving A to
follow C is more difficult than I thought, involving in more complicated
calc, especially if this crank is to be put on some face of some other
object.
The 2nd thing giving me a surprise is that openscad doesn't have a mind of
drawing a line from A to B. The simplest way is to make a sphere at the
origin, move to A, and another one to move to B, then do a hull() between A
and B. But the result (shape of line) is not very controllable.
In fact, everything openscad makes is to follow this: (1) make at the
origin, (2) do a rotation, and (3) translate to the target location. Even as
simple as a point in space has to go through these steps.
To me, an idea modeling tool would be able to: (a) make an object X directly
at any point in spcace; (b) X can report where it is, i.e., contains data,
especially coordinates; and (c) attachment to that object can be made based
on the data of X. That is, given a point A on X, users can make a line, a
wheel ... ect, based on A, but don't have to go through (1~3) steps all over
again.
To achieve this, it has to rely heavily on polyhedron-based approach ---
everything has to be polyhedron, because only polyhedron can bear coordinate
info.
In the past year, I've spent most of my openscad time on developing a lib
toward that direction (well, other than the doctest lib). The most important
ingredient is the hash parameter to mimic the associated array. Using
something like:
data= ["angle",30, "r", 3]
makes it possible to pack all parameters of an object. In some sense, this
data becomes THE object. It can be updated with new info, thus produce a
sub-object easily. Without this I can't even start the first step.
Since a set of data represents an object, in the future we might be able to
do:
data= [ "angle", 30
, "r", 3
, "action", ["bend", ... ]
, "merge", some_other_object
But that's a very long road ahead.
Discuss@.openscad
$ Runsun Pan, PhD
$ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse )
View this message in context: http://forum.openscad.org/eval-tp12627p12669.html
Hi Carsten.
One of my top goals for "OpenSCAD 2" is to stay true to the goals and
philosophy of OpenSCAD. I've tried to figure out what these are by
talking to Marius and reading forum posts for the last few years.
Some OpenSCAD users are computer programmers like you and me, but many
are not. If OpenSCAD is your first experience with computer
programming, then how many new concepts do you need to learn before
you can be productive? OpenSCAD seems to have a low barrier to entry,
and we want to keep it this way.
One philosophical principle I've learned from the community is that
OpenSCAD is intended to be a purely declarative or 'functional'
language, except that it should also be much easier to learn than
serious functional languages such as Haskell. This means that there is
no state. You can't increment a variable or modify a data structure
in-place.
Traditional OOP languages are based on the idea of objects with state,
and there is a lot of additional heavy weight machinery that you need
to learn before you can be productive. But we don't want this: we'll
end up with a language that is easy to use once you have learned
object oriented programming, but it with a higher barrier to entry for
beginners.
In your first example (class lollipop), you defined a class, you
defined a constructor inside the class, you declared data members then
separately assigned them initial values within the constructor, and
you have an assignment to the special variable 'this'. You used a lot
of machinery to accomplish something very simple.
In your second example (module example_module), you create a mutable
object and modify its state, in these lines:
return table_plate;
But we want OpenSCAD to be purely declarative, without state mutation semantics.
When I have more time, maybe I'll try and rewrite your code in
OpenSCAD 2, to demonstrate that the same things can be accomplished in
a simpler way, without all the heavy machinery of OOP.
Doug Moen.
// classes are new
class lollipop {
radius = rad;
diameter = diam;
height = hei;
this = union() {
radius;
diameter;
height;
return table_plate;
Carsten
Doug,
This is a fascinating discussion, and I wanted to chime in about objects
and mutability (full disclosure, experienced programmer). I have an
interest in functional, immutable programming styles, but have not
personally used lisp or Haskell. Most of my experience is with Scala.
I think you can preserve much of the usefulness of objects while keeping
a simple syntax and immutability. In fact, we don't even really need a
new keyword. Modules are fine as is, with a few minor extensions. The
main features that seem useful are:
Carsten's example would look something like this:
module Lollipop(
radius,
diameter,
height
) extends Geometry /* This could be the default, and not needed to be stated explicitly */ {
// create 2 lollipops of different sizes, the second dependent on the first
lolA = Lollipop(radius = 10, diameter = 2, height = 50);
lolB = lolA.with(radius = lolA.radius*2, diameter = lolA.diameter*2); // height is omitted -- it stays the same
// cube is a module just like everything else (albeit a native one),
// and it's parameters ARE accessible, and has a .with() if needed.
table_plate = cube(size=[100,100,5], center=true);
// union, a member of the base geometry module, returns an immutable copy of itself
// unioned with the arguments to union. Since we are a module, any geometry declared is
// implicitly unioned as before.
table_plate.union(lolA, lolB);
example_model()
.render() // Produces rendered geometry... more on this later
.exportStl("lollipops_on_table.stl"); // magic strings are ugly. Use an actual method name for STL
But these extensions would allow far more, but remain mostly, if not
completely backwards compatible. We can actually implement the
"geometry" base module using the existing functionality of OpenSCAD:
module GeometryBase {
unionOf = (args* /*vararg syntax tdb, of course /) -> { / Anonymous function syntax TDB */
this
args
rendered = (x = 1) -> render(x) { this }
If we consider { ... } to be an "inline module", you get associative
arrays for free:
data = {
a = 10;
b = 20;
echo(data.a); // Valid because variables of modules are exposed
// You can create a copy with new values as well
data2 = data.with(b=30, c=100);
Just my two cents, but it would be a simple way to keep backwards
compatibility and all the desirable current features while giving the
programmers many of the features that feel natural to us.
doug moen mailto:doug@moens.org
May 16, 2015 at 16:35
Hi Carsten.
in-place.
beginners.
return table_plate;
Doug Moen.
// classes are new
class lollipop {
radius = rad;
diameter = diam;
height = hei;
this = union() {
radius;
diameter;
height;
return table_plate;
Carsten
Carsten Arnholm mailto:arnholm@arnholm.org
May 16, 2015 at 15:08
name a type, encapsulate its data members and provide member functions
would go a long way towards the goal of being more expressive without
have not grasped the full idea of it), the main ideas would be:
a class may contain data members unique to each instance created.
be instantiated and may remember its construction parameters so they
can be re-used later. It also owns its CSG object.
// classes are new
class lollipop {
radius = rad;
diameter = diam;
height = hei;
this = union() {
radius;
diameter;
height;
return table_plate;
of other classes, or even containers containing such.
a direction which would be immediately recognisable to programmers,
while still being backwards compatible with existing OpenSCAD code. If
you want to express things as it is currently being done, you can, but
you also have other possibilities.
Carsten
G. Wade Johnson mailto:gwadej@anomaly.org
May 16, 2015 at 10:33
G. Wade
May 16, 2015 at 09:44
model based on the parameters. So that's an object. An object is a set
of top level definitions (name/value pairs), plus a list of values
(which are normally geometric shapes). OpenSCAD2 has a syntax for
referencing an external library file as an object, and a syntax for
object literals (just an OpenSCAD script, surrounded by braces). Given
an object, you can reference its named components using dot notation
(object.name http://object.name), or you can reference the object in
a geometric context (as an argument to a geometric transformation, or
its geometry.
May 14, 2015 at 09:58
Hi Marius!
limited and use it as an intermediate representation generated by the
option. Most people I've talked to who've ever used that has strongly
in about 1994-1995 for the work previously mentioned. It was marketed
by Matra Datavision in France and I even went to see them a couple of
times. They had what we thought was a curious idea of their own
home-grown language (CDL) encapsulating the C++ kernel. Nowadays it
looks like some finally agree with our thoughts at the time :
still struggled very hard to make use of it. The end result for us was
that it was dropped and replaced it with ACIS. Only a few years ago, I
discovered CAS.CADE had become quasi open source as OpenCascade
(OCCT). I also found there is now something called OCE - Open CASCADE
Community Edition https://github.com/tpaviot/oce/
power to do it, and my work is different now. OCE may probably be
something to be considered for OpenSCAD CAD kernel, I suspect
OpenCascade has come a long way since I saw it.
was wondering if the generation of triangles for STL really needs the
graphical rendering to be completed first? If not, one could imagine a
function to export the compiled model to STL and use an external
viewer to speed things up when iterating on a complex design that
Hi Yona. I find parts of your post confusing (the term "module" is
overloaded), but we are thinking along the same lines.
A quick way to summarize my thinking is that you don't need classes to do
object oriented programming. The prototype/delegation paradigm used by
Javascript is just as powerful. But if all objects are immutable, then you
don't need delegation, and things get really simple. You just need:
And that's it, you have a functional OOP system. It's simple, more powerful
than it looks, and good enough for our purposes.
OpenSCAD already has the above 3 concepts:
OpenSCAD 2 just generalizes these already-existing concepts. It adds object
literals and first class object values. It adds a better syntax for
customizing an object. It unifies "functions" and "modules", using the word
"function" to describe both.
Now I'll copy and paste part of Yona's post, with terminology and syntax
changed to correspond to my current OpenSCAD 2 design:
// If we consider { ... } to be an "inline object", you get associative
arrays for free:
data = {
a = 10;
b = 20;
echo(data.a);
data2 = data(b=30, c=100);
Doug Moen.
On 16 May 2015 at 20:52, Yona Appletree hypher@gmail.com wrote:
Doug,
I think you can preserve much of the usefulness of objects while keeping a
simple syntax and immutability. In fact, we don't even really need a new
keyword. Modules are fine as is, with a few minor extensions. The main
1. Combining data, geometry and functions into one variable space
2. Module mix-ins
3. Access to module parameters and variables as "fields"
4. A module "copy" method. I will use the name "with", where you can
specify overrides to the parameters and variables in the modules. This
would return a copy of the module with the new values, keeping immutability.
module Lollipop(
radius,
diameter,
height
example_model()
completely backwards compatible. We can actually implement the "geometry"
this
args
arrays for free:
data = {
a = 10;
b = 20;
Yona
Hi Carsten.
in-place.
beginners.
return table_plate;
Doug Moen.
On 16/05/2015, Carsten Arnholm arnholm@arnholm.org arnholm@arnholm.org wrote:
// classes are new
class lollipop {
radius = rad;
diameter = diam;
height = hei;
this = union() {
radius;
diameter;
height;
return table_plate;
Carsten
contrary, it is an important tool for simplification. Being able to name a
type, encapsulate its data members and provide member functions would go a
long way towards the goal of being more expressive without complicating
things.
// classes are new
class lollipop {
radius = rad;
diameter = diam;
height = hei;
this = union() {
radius;
diameter;
height;
return table_plate;
still being backwards compatible with existing OpenSCAD code. If you want
to express things as it is currently being done, you can, but you also have
Carsten
G. Wade
reference the object in a geometric context (as an argument to a geometric
bill-of-materials.
Hi Marius!
way since I saw it.
I know 'God' is faith based, but application specific too? tut tut tut....{}
On Wednesday, 13 May 2015 10:58 PM, jon <jon@jonbondy.com> wrote:
Oh, god. Please do not head towards Visual Basic.
On 5/13/2015 12:56 AM, runsun wrote:
Indeed. A first class function will work pretty well in cases like I post above.
Just thought of something. Since in openscad, parameters and functions are stored in different places:
abc=3;
function abc()=...;
Assigning abc to a parameter, if possible, will be confusing:
x = abc; // function or parameter?
A possible way out of this is like what Visual Basic does:
x = something; // assign parameter
set x = something; // assign object
That is, set for object assignment. In openscad, could be function or module assignment. Not sure how expensive it is though.
$ Runsun Pan, PhD
$ -- OpenScad_DocTest: doc and unit test ( Github, Thingiverse )
$ -- hash parameter model: here, here
View this message in context: Re: eval( ) ???
Checked by AVG - www.avg.com
Version: 2015.0.5863 / Virus Database: 4342/9758 - Release Date: 05/12/15
