Does anyone on this list design plywood structures with finger joints
using OpenSCAD? Any pointers? I would want to create the 3D structure
in OpenSCAD and then send the 2D cut patterns (DXF?) to a friend with a
laser cutter.
Thanks
I'd be tempted to design a plate with parametrically modified sides. A
cube where each of the 4 edges has an optional overlay that does the
notches. You can auto center it and control the width of the finger. So
a flat cube, difference each side (as needed) with an array of cubes
modified for finger depth and spacing. A little work with a defined
vector (side, spacing, depth) at a minimum would allow you to have
uniform fingers. That as a template would allow laser cut holes as needed.
I'm doing something of the same concept, but using printed circuit
boards and 3D printed cases. It's all derived from the board layout.
Harvey
structure in OpenSCAD and then send the 2D cut patterns (DXF?) to a
friend with a laser cutter.
Thanks
On Saturday, February 14, 2026 at 10:14:13 PM EST, Jon Bondy via Discuss discuss@lists.openscad.org wrote:
laser cutter.
Guenther has been working on this in PythonSCAD:
https://old.reddit.com/r/OpenPythonSCAD/comments/1r0xkpi/triangular_shelf_for_laser_cutting/
https://old.reddit.com/r/OpenPythonSCAD/comments/1qsg4my/more_lasercut_progress/
https://old.reddit.com/r/OpenPythonSCAD/comments/1qmwfse/creating_lasercuts_with_pythonscad/
I've also been experimenting with this sort of thing: https://github.com/WillAdams/gcodepreview/blob/main/gcpcutdxf.py
Arguably, what someone should do is code up support for boxes.py https://boxes.hackerspace-bamberg.de/ or https://www.makercase.com/
I have a beta version of a tabbed-box library I built. There are still
some bugs I am not satisfied with, but I have been using it to design
French Cleat holders and jigs. Let me know if you are interested and I
will share it with you for evaluation. I feel that I am quite a way from
releasing it publicly, but would share it if you are willing to help polish
it up (or at least not accept it as a rough work in progress).
Anyway, some of the specialized functionality allows you to specify pin
lengths, and how to skip particular pins when appropriate (I used this when
designing French Cleat holders where the pins along the edge of the
backplate would interfere with a cleat's support foot).
EBo --
On Sat, Feb 14, 2026 at 10:44 PM Harvey white via Discuss <
Harvey
Thanks
Thanks
Finger joints, or even dovetails or butterfly's might be easier to do in
LinuxCNC with a common text editor. I've done several pieces of green
and green style furniture that way, then converted it to wood on my
milling machines, all run by LinuxCNC from starting to make chips to
finish application.
Basically you define the XY points needed to mark corners. Including
setting tool diameters according to which side of the tool is to follow
the line between 2 sets of points, then write the RS-274-d gcode to do
it. Do the test cuts in cheap white pine to get it right, break out the
$20 a bd-ft walnut, cherry, mahogany or white ash and do it for real.
Lets you control the fit to a thou or less. That laser cutter is likely
a lot slower than a normal mill if its being used as a precision saw.
And gcode is easy to write most of the time.
On Sunday, February 15, 2026 at 03:02:15 AM EST, gene heskett via Discuss discuss@lists.openscad.org wrote:
finish application.
Finger (or box) joints and butterfly joints work well on a laser since they are 2D through cuts --- I'm kind of stumped as to how one would do dovetails since they require variable depth pockets w/ angled sides --- are there readily available and affordable at a hobbyist/individual user level which supports the kind of cutting needed for dovetails?
do in
green
to
finish application.
I think the clues in Gene's comment might be LinuxCNC and milling
machines.
Larry
Dovetails would require through cuts at an angle, not perpendicular to the
material surface (for making the pin board). Can laser cutters change the
angle of the laser?
On Sun, Feb 15, 2026 at 8:52 AM William F. Adams via Discuss <
On Sunday, February 15, 2026 at 03:02:15 AM EST, gene heskett via Discuss <
finish application.
@Adrian Mariano avm4@cornell.edu
there ARE some laser cutters that can angle their beam path off of
perpendicular, but those are REALLY EXPENSIVE machines (for example:
https://www.youtube.com/watch?v=yFqm-QqgdeE ). The types of machines that
us mere mortals can afford does not allow us to cut bevels or variable
angles from perpendicular.
EBo --
On Sun, Feb 15, 2026 at 9:15 AM Adrian Mariano via Discuss <
angle of the laser?
finish application.
Adrian:
are the "dovetails" that are generated by BOSL2 straight vertical cuts?
They look so to me.
the material surface (for making the pin board). Can laser cutters
change the angle of the laser?
to do in
green
finish application.
