lar3ry
Fri, Dec 25, 2020 4:41 PM
Would there be any downside to making the 'center' keyword default to 'true'?
This would make it so that
cube(10,center=true);
and
cube(10,center);
produce the same result.
I don't think it would break any existing code.
I can't think of any other instances of boolean keywords that also might
benefit from this, but if there are...
and
cube(10,center);
Fri, Dec 25, 2020 4:46 PM
Since it currently defaults to false, I guess it would break a lot of
code...
and
cube(10,center);
code...
> and
> cube(10,center);
Fri, Dec 25, 2020 5:01 PM
I think that lar3ry's idea wasn't clearly articulated. He wants to be able
to omit the "=true" in the invocation and write
cube(10,center);
instead of
In other words, the idea is that just giving a keyword is equivalent to
setting the keyword to true. The code that would break is code that looked
like
center=false;
cube(10,center);
I suppose lar3ry could get the behavior he wants (at least sort of) by
defining center=true at the top of his code.
code...
'true'?
and
cube(10,center);
cube(10,center);
instead of
like
center=false;
cube(10,center);
> code...
>> 'true'?
>> and
>> cube(10,center);
> Discuss@.openscad
lar3ry
Fri, Dec 25, 2020 5:03 PM
How so? You can't use the default by using just the keyword without
specifying 'false'
Oh, I guess the parameter, if not used at all in a statement, is actually
used, and the default is false.
That sort of thing gets us into trouble with other parameters, as in:
cylinder(10,10);
where it seems that a parameter (r2) is assumed, and the default is 1.
code...
'true'?
and
cube(10,center);
specifying 'false'
cylinder(10,10);
> code...
>> 'true'?
>> and
>> cube(10,center);
lar3ry
Fri, Dec 25, 2020 5:08 PM
looked
like
center=false;
cube(10,center);
center=false;
cube(10,center);
doesn't do it. If it did, I would be somewhat happy with it.
> looked
> like
> center=false;
> cube(10,center);
center=false;
cube(10,center);
Fri, Dec 25, 2020 5:21 PM
I like the idea that you could say cube(10, center) but I'm not sure the
parser will handle it properly. I am sure that those with more
knowledge of these things will chime in soon.
cube(10,center);
instead of
> cube(10,center);
> instead of
Fri, Dec 25, 2020 5:40 PM
The point is that lar3y is requesting a change to the OpenSCAD language,
namely that you can pass the center argument without giving it a value and
when you do that, it's equivalent to giving it a true value, so that
can be simplified to
cube(10,center);
The reason this is problematic is that the second thing already has a
different meaning, namely that you pass the local variable "center" as the
second positional arg.
able
cube(10,center);
instead of
cube(10,center);
>> able
>> cube(10,center);
>> instead of
> Discuss@.openscad
Fri, Dec 25, 2020 5:50 PM
I said, "by defining center=true" which you didn't do. You copied my example
with center=false which I specifically constructed to break your idea.
I am not sure if you fully understand how parameter passing works. There
are positional parameters and keyword parameters. So if you invoke some
function foo(parm1,parm2,keyword=value) then it invokes the function/module
foo and passes it a couple positional parameters and then also passes it a
keyword parameter. The keyword parameter might be the 5th positional
parameter---we don't know. By using the keyword passing method you avoid
the need to specify the other parameters and you can allow them to have
default values.
If you consider changing this to
foo(parm1,parm2,keyword)
it now looks like you're invoking foo with 3 positional parameters. And in
fact, that is precisely how it is interpreted. And the thing that was the
keyword is now regarded as a local variable.
You could make this work for you by defining a variable center equal to true
(not false as in my example below) and then you can pass it as a positional
parameter---in the right place. So
center=true;
cube(10,center);
cylinder(100,5,5,center);
but if you don't put things in the right place you're going to get
unexpected results. So doing
cylinder(100,5,center);
means you've passed "true" as the second radius. Apparently this (bogus)
value is ignored and the default of 1 is taken in this case.
Allow me also to draw attention to the following to complete the story:
center=false;
cube(10,center=center);
In this case the statement center=center is kind of confusing because the
"center" on the left is the keyword name and the "center" on the right is a
local variable (which we have set to false in this example).
looked
like
center=false;
cube(10,center);
center=false;
cube(10,center);
default values.
center=true;
cube(10,center);
center=false;
>> looked
>> like
>> center=false;
>> cube(10,center);
> center=false;
> cube(10,center);
> Discuss@.openscad
lar3ry
Fri, Dec 25, 2020 6:57 PM
Point taken. I forgot that r2 was also a positional argument.
example
function/module
default values.
in
true
positional
center=true;
cube(10,center);
center=false;
a
looked
like
center=false;
cube(10,center);
center=false;
cube(10,center);
> example
> function/module
> default values.
> in
> true
> positional
> center=true;
> cube(10,center);
> center=false;
> a
>>> looked
>>> like
>>> center=false;
>>> cube(10,center);
>> center=false;
>> cube(10,center);
>> Discuss@.openscad
> Discuss@.openscad
Ray West
Fri, Dec 25, 2020 6:58 PM
I'm not sure of the benefit, unless for readability. if that is the
case, then could set 'centered=true', and 'offset=false', or come to
UK, and use 'centre'...
It seems to be, that the default 'center', uses the last value set.
Best Wishers,
Ray
cube(10,center);
able
cube(10,center);
instead of
Best Wishers,
Ray
> cube(10,center);
>>> able
>>> cube(10,center);
>>> instead of
>> Discuss@.openscad
