ME
Mark Erbaugh
Mon, Nov 11, 2024 3:46 PM
Is there programmatic way to get the center (or any other reference, such as a corner) point of a 2d object at an arbitrary position in the XY plane?
Mark
Mark
Mon, Nov 11, 2024 4:22 PM
Its long time since I have written any function in openSCAD, but this
should work
p0=[[2,0],[10,5],[5,10]];
function center_point(p,p1=[0,0,0],n=0)=
n==(len(p))?p1/len(p):center_point(p,p1+p[n],n+1);
echo(center_point(p0));
basically center of mass for any object would be
sum of all the points(2d or 3d coordinates)/ number of points
On Mon, 11 Nov 2024 at 21:16, Mark Erbaugh via Discuss <
Mark
should work
> Mark
GS
Guenther Sohler
Mon, Nov 11, 2024 4:25 PM
Issue IS that in openscad you dont have Access to the objects vertices 😞
Sanjeev Prabhakar via Discuss discuss@lists.openscad.org schrieb am Mo.,
11. Nov. 2024, 17:22:
should work
Mark
Sanjeev Prabhakar via Discuss <discuss@lists.openscad.org> schrieb am Mo.,
> should work
>> Mark
Mon, Nov 11, 2024 4:32 PM
oh I thought to make a polygon in openSCAD you have to define points anyway.
Nevermind, I wrote a recursive function after a long time in openSCAD
On Mon, 11 Nov 2024 at 21:56, Guenther Sohler via Discuss <
Mo., 11. Nov. 2024, 17:22:
should work
plane?
Mark
>> should work
>>> plane?
>>> Mark
Mon, Nov 11, 2024 5:25 PM
To make a polygon primitive, yes.
But you can also get 2D objects from Boolean combinations of other 2D objects, from projection(), from imported 2D objects, et cetera, and there’s currently no way to retrieve the coordinates of such an object.
It’s exactly the same situation as for 3D objects, but flatter.
TA
Todd Allen
Mon, Nov 11, 2024 5:42 PM
Use the 2d shape functions from BOSL2 which return geometry and you can
manipulate it with their functions such as rotate, scale, union and
difference which return geometry. BOSL2 also has functions such
as path_closest_point() which you might use to find corners and calculate a
center point. The BOSL2 code can also provide a starting point to modify
into your own solutions when there isn't a routine in the library that can
do what you need.
On Mon, Nov 11, 2024 at 10:33 AM Sanjeev Prabhakar via Discuss <
anyway.
should work
plane?
Mark
do what you need.
> anyway.
>>> should work
>>>> plane?
>>>> Mark
Mon, Nov 11, 2024 5:49 PM
I love it!
<grin>
I love it!
<grin>
Mon, Nov 11, 2024 5:51 PM
I think maybe you meant to say that BOSL2 has functions that return point
lists and you can manipulate them with rotate, scale, union, difference
etc. In addition, BOSL2 has centroid() which computes the centroid
(center of mass) of a polygon or polyhedron, which is not simply the
average of the vertices. You can compute the average of the vertices---if
you want that value instead---with mean().
On Mon, Nov 11, 2024 at 12:43 PM Todd Allen via Discuss <
do what you need.
anyway.
should work
plane?
Mark
> do what you need.
>> anyway.
>>>> should work
>>>>> plane?
>>>>> Mark
TA
Todd Allen
Mon, Nov 11, 2024 6:29 PM
lists
I said what I meant as I thought the point lists returned were one form of
geometry and a VNF is another type of data representing geometry. The
centroid() function which can operate on point lists and VNFs is in a file
named geometry.scad. But if the word geometry is technically reserved for
something else such as the output of rendering then thanks for the
correction and explanation.
On Mon, Nov 11, 2024 at 11:52 AM Adrian Mariano via Discuss <
do what you need.
anyway.
should work
plane?
Mark
lists
>> do what you need.
>>> anyway.
>>>>> should work
>>>>>> plane?
>>>>>> Mark
Mon, Nov 11, 2024 6:37 PM
Without getting feedback from cursor position, I'm not sure how you
could define corners - 'top-left' wouldn't always work, for example. I
expect, if you could define the point you wanted to select, you could
just as easily calculate it in most cases. Openscad creates, it does not
deconstruct.
Mark
deconstruct.
> Mark
