Hi, welcome to the forum.
This concept has been under discussion for some time.
I imagine it will get done eventually, but there is great debate about the
best way to do it ATM.
BTW if your next post (after a fee minutes) is still flagged as "This post
has NOT been accepted by the mailing list yet" you should check your
subscription
http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1 .
View this message in context: http://forum.openscad.org/export-module-tp10913p10943.html
I have written the modules to realign the various parts to fit
on my print plate. I have to do the first plate, render, export,
then the next plate, render export... 12 plates and counting.
This post shows an easy workaround using a simple shell-script/
batch-file to do the actual export:
http://forum.openscad.org/100-Bounty-for-easy-feature-tp10618p10640.html
