couple of weeks ago accidentaly deleted most of my work.
Before I did find a neat way to round edges using hull(), rather than minkowski which is kinda too slow for my taste, I tried to replicate from memory the code but no luck,
it was something like:
//**** HandlerBar module ******
idiameter = 32.5;
band_dickness = 3;
band_width = 20;
xdiameter = idiameter + band_dickness;
fix_block_high = 15;
stop = 2;
sideWall = 2 *2;
//**** Flash light Module *****
detach_lower_block_length = fix_block_length - stop;
detach_lower_block_width = band_width - sideWall;
detach_lower_block_high = 3;
chanel_width = 3;
chanel_neck = 3;
detach_upper_block_length = 35;
detach_upper_block_width = 25;
detach_upper_block_high = 15;
roundRadio = 1;
screw_offset_length = 8 * 2; //two per side
screw_offset_width = band_width;
screw_offset_dickness = 3 * 2; //uper & lower sides
//union()
hull()
for(i=[0:3])
translate(-[i % 2] * band_width, + i[i % 2] * xdiameter + screw_offset_length, 0], cube(), center = true); //I get a syntax error on this line, why?
I found this other one with two for()s, the problem is does not round the top of cube edges:
hull(){
for(end = [-1,1])
for(side = [-1,1])
translate([end * (length / 2 - orad), side * (width / 2 - orad), 0])
cylinder(r = orad, h = height);
sphere(orad);
I will appreciate any help.
Thank you for reading,
Your brackets () and [] are all mixed up:
value=1
//union()
hull()
for(i=[0:3])
translate([-(i % 2) * band_width, + i*(i % 2) * xdiameter +
screw_offset_length, 0], cube(value, center = true); //I get a syntax error
on this line, why?
2015-02-22 9:02 GMT+01:00 jose tav j_tav@yahoo.com:
idiameter = 32.5;
band_dickness = 3;
band_width = 20;
stop = 2;
sideWall = 2 *2;
chanel_width = 3;
chanel_neck = 3;
roundRadio = 1;
//union()
hull()
for(i=[0:3])
on this line, why?
top of cube edges:
hull(){
for(end = [-1,1])
for(side = [-1,1])
sphere(orad);
schreiben.
Enjoy!
Still mixed up :)
But I did only fixed syntax, not sure it does what you need:
value=1;
//union()
hull()
for(i=[0:3])
screw_offset_length, 0]) cube(value, center = true); //I get a syntax error
on this line, why?
2015-02-22 11:33 GMT+01:00 Peter Falke stempeldergeschichte@googlemail.com
value=1
//union()
hull()
for(i=[0:3])
on this line, why?
idiameter = 32.5;
band_dickness = 3;
band_width = 20;
stop = 2;
sideWall = 2 *2;
chanel_width = 3;
chanel_neck = 3;
roundRadio = 1;
//union()
hull()
for(i=[0:3])
on this line, why?
hull(){
for(end = [-1,1])
for(side = [-1,1])
sphere(orad);
schreiben.
Enjoy!
schreiben.
Enjoy!
