Colors and texts in rendered diagram?
Al
Wed, Nov 8, 2017 11:38 AM
I am a beginner at OpenSCAD, and I like it very much.  But I have two issues.
I have a nice 3D figure I've created, which includes different colors and
some text.  But when I render it, all the colors vanish as does the text.
How can I get the colors and text in the rendered result?
I'm using version 20171106 under ArchLinux.
For that matter, what is the best way of saving a diagram so that somebody
else can play around with it?  Somebody who doesn't necessarily have
OpenSCAD themselves?  I'd like to send my completed diagram to a colleague.
Thanks everybody,
Al
I am a beginner at OpenSCAD, and I like it very much. But I have two issues. I have a nice 3D figure I've created, which includes different colors and some text. But when I render it, all the colors vanish as does the text. How can I get the colors and text in the rendered result? I'm using version 20171106 under ArchLinux. For that matter, what is the best way of saving a diagram so that somebody else can play around with it? Somebody who doesn't necessarily have OpenSCAD themselves? I'd like to send my completed diagram to a colleague. Thanks everybody, Al -- Sent from: http://forum.openscad.org/
Wed, Nov 8, 2017 12:16 PM
ATM colour is a preview only attribute, as there is little to no support for
colour properties in 3D rendered formats like STL. It is a work-in-progress
to support it in rendered format, but not anywhere close to reality.
Text is a 2D geometry, if you want to show it with a 3D object, you need to
linear_extrude()
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_the_2D_Subsystem#Linear_Extrude
it to some thickness (height=?) to make it a 3D object.
Once you do that, apart from colour, you can export it to a range of 3D
formats (no colour), which your colleague will need a 3D viewer, there are a
number. What Operating System do they have?
Alternatively you could  export in 2D
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/DXF_Extrusion  , from
various angles.
ATM colour is a preview only attribute, as there is little to no support for colour properties in 3D rendered formats like STL. It is a work-in-progress to support it in rendered format, but not anywhere close to reality. Text is a 2D geometry, if you want to show it with a 3D object, you need to linear_extrude() <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_the_2D_Subsystem#Linear_Extrude> it to some thickness (height=?) to make it a 3D object. Once you do that, apart from colour, you can export it to a range of 3D formats (no colour), which your colleague will need a 3D viewer, there are a number. What Operating System do they have? Alternatively you could export in 2D <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/DXF_Extrusion> , from various angles. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
Al
Wed, Nov 8, 2017 1:58 PM
Thanks very much - that all makes sense.  I can certainly extrude text to
make it 3D.
As to colors, that's a pity, but I now understand the limitations.  I am in
fact trying to make a sort of 3D model diagram which explains the
interrelationships between parts of a structure: there are too many to do it
easily in 2D, and I can get a nice effect in 3D.  But the result needs to be
portable.  The preview, with the colors, looks good, and it's that I'd want
to make available.  Maybe the best option would be to use OpenJSCAD?
Thanks again,
Al
Thanks very much - that all makes sense. I can certainly extrude text to make it 3D. As to colors, that's a pity, but I now understand the limitations. I am in fact trying to make a sort of 3D model diagram which explains the interrelationships between parts of a structure: there are too many to do it easily in 2D, and I can get a nice effect in 3D. But the result needs to be portable. The preview, with the colors, looks good, and it's that I'd want to make available. Maybe the best option would be to use OpenJSCAD? Thanks again, Al -- Sent from: http://forum.openscad.org/
Wed, Nov 8, 2017 9:26 PM
Sorry, I'm not up on OpenJSCAD, it would depend on its 3D rendering engine,
again the file format re colour may be the problem. Others may comment.
You can also export as .PNG from preview as an image.
Sorry, I'm not up on OpenJSCAD, it would depend on its 3D rendering engine, again the file format re colour may be the problem. Others may comment. You can also export as .PNG from preview as an image. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
