Sun, Feb 25, 2024 12:06 PM
I normally don't have F5 set to automatic, but I guess it was set this
way by accident. For simple models, this is really nice.
I just loaded a large model, and am now stuck with OpenSCAD hung,
waiting for F5 to finish.
It might make sense to have Auto F5 kill itself after a user-set
duration, such as 15 seconds.
Sun, Feb 25, 2024 12:12 PM
Note that my most recent hang involved source code with a misspelled
include file. Surely an error like that begs for the entire F5 process
to be immediately aborted. This should not be a warning: it is a fatal
error.
error.
> Jon
Sun, Feb 25, 2024 1:36 PM
A lot of my F5s take more than 15s. 2 minutes 19 for this because it has
more than 2500 parts:
On Sun, 25 Feb 2024 at 12:12, jon via Discuss discuss@lists.openscad.org
error.
On Sun, 25 Feb 2024 at 12:12, jon via Discuss <discuss@lists.openscad.org>
> error.
> Jon
> > Jon
> This email has been checked for viruses by AVG antivirus software.
> www.avg.com
Sun, Feb 25, 2024 1:57 PM
Do you want to wait 2 minutes each time you make a change to the source
code? I do not. If F5 takes under 2 seconds, fine; if more, then I
want to request the F5 manually. It is the auto F5 that trapped me for
5 minutes while OpenSCAD attempted a futile calculation. I am
advocating that we put a limit for auto F5 that can be set by the user.
In my case, I would set it to perhaps 5 seconds. Longer than that and
the facility is not useful to me.
Note that this is NOT a limit for a manual F5, just for the auto F5
has more than 2500 parts:
process
fatal
error.
www.avg.com <http://www.avg.com>
> process
> fatal
> error.
> Jon
> set this
> > Jon
Sun, Feb 25, 2024 2:05 PM
On 25.02.24 14:57, jon via Discuss wrote:
I am advocating that we put a limit for auto F5 that can be set by the user.
The discussion is moot. The problem is that it is technically not
supported at this point to cancel the action.
As soon as that gets implemented, if someone feels spending the time
on that (which would be very nice and obviously useful feature), then
it could just be a cancel button that always works.
Sun, Feb 25, 2024 2:24 PM
I don't want to wait 2 minutes but unfortunately that is how long it takes.
On Sun, 25 Feb 2024, 14:06 Torsten Paul via Discuss, <
user.
> user.
> ciao,
> Torsten.
CM
Curt McDowell
Thu, Feb 29, 2024 8:29 PM
I'm thinking that all computation should be managed in a separate
thread, one that can be killed whenever you hit the red X, or restarted
when you hit F5 again. Actually, it would might need to be a separate
process so that memory management is not an issue. But there are several
platforms to worry about... nothing is easy!
-Curt
the user.
-Curt
>> the user.
> ciao,
> Torsten.
