auto completion in new release candidate
Sun, Dec 13, 2020 6:26 PM
Is there a good reason for the auto completion code to continue to work
(interfere) while entering a comment?
Thanks
Is there a good reason for the auto completion code to continue to work (interfere) while entering a comment? Thanks Jon
Troberg
Sun, Dec 13, 2020 7:24 PM
I can find it useful when editing commented out code, something I frequently
do before I've made the final "put everything together" modules.
I can find it useful when editing commented out code, something I frequently do before I've made the final "put everything together" modules. -- Sent from: http://forum.openscad.org/
lar3ry
Sun, Dec 13, 2020 8:12 PM
frequently
I agree, but there something else that would be nice.
If I type, say "cu", the tab, then "(", I see three choices:
cube(s)
cube([width,depth, height])
cube([width,depth, height],center=true)
None of these are highlighted, and there is no way to autocomplete them.
I think it would be nice to allow completion of a template, perhaps with
something like these.
cube();
cube([]);
It would be very particularly helpful for things like translate, scale,
rotate, etc.
I might also be nice to use autocomplete for user-defined modules.
Troberg wrote > I can find it useful when editing commented out code, something I > frequently > do before I've made the final "put everything together" modules. I agree, but there something else that would be nice. If I type, say "cu", the tab, then "(", I see three choices: cube(s) cube([width,depth, height]) cube([width,depth, height],center=true) None of these are highlighted, and there is no way to autocomplete them. I think it would be nice to allow completion of a template, perhaps with something like these. cube(); cube([]); It would be very particularly helpful for things like translate, scale, rotate, etc. I might also be nice to use autocomplete for user-defined modules. -- Sent from: http://forum.openscad.org/
