If you've got Netfabb, move the stl to the origin in Netfabb, then use it's
measuring tools to work out exactly where the holes are that you want to
change. Then use this information in OpenSCAD to difference a couple of
cylinders from the stl.
Ian
View this message in context: http://forum.openscad.org/How-do-I-edit-an-imported-STL-file-tp20466p20467.html
Ian
