I am trying to modify a peg hook (https://www.thingiverse.com/thing:53229) to
make it stronger. I had one break after a couple of years hanging a damp
towel on it. I tried using the BOSL library, shapes.scad,
thinning_triangle(), then I tried right_triangle(), and finally, my own
triangle using a hull() of three spheres.
I can preview the object, but I can only render one of the parts. I choose
which part using the "!" character, and I can render the hook, OR the brace,
but if I try to render both, I only get the brace. Ideas?
$fn=36;
import("PegHook.stl");
brace();
module brace() {
hull() {
translate([18,8.5,1.505])
sphere(d=3);
translate([18,8.5,22.5])
sphere(d=3);
translate([43,8.5,1.505])
sphere(d=3);
PegHook.stl http://forum.openscad.org/file/t2121/PegHook.stl
It means the .stl file has bad geometry.
Self Intersections:
http://forum.openscad.org/file/t359/Capture_peghook.jpg
Those red bits, that top is not glued on properly...
Why not build your own hook in OpenSCAD?
Self Intersections:
<http://forum.openscad.org/file/t359/Capture_peghook.jpg>
I did end up making my own, but I was just curious as to what the problem
was. I loaded it into Meshmixer and tried "Analysis", but it showed no
problem. In that it rendered properly by itself, and was not flagged as a
problem in Slic3r, I was at a loss to explain it.
What program did you use to find that bad geometry?
That is Netfabb Studio Basic, which isn't available anymore.
I understand you can download the trial version which relapses to a basic
version at the end of the trial.
To find the above problem I went into Repair, which showed nothing, then
Repair/Detect-self-intersections.
