Sat, May 22, 2021 7:14 AM
RE EDITING FORUM POSTS
OpenSCAD mailing list-2 wrote
Not in my case! The only entries that appear under ‘More’ are
That is because we have two classes of users ;)
Nothing personal, but there is this technical issue with email
authentication mechanisms.
You will note that some users, including you Terry, have posts that end up
on the Forum under generic User names, e.g. "User: OpenSCAD mailing list-2
Email: discuss@lists.openscad.org" not the logged on User name (for Terry -
Terrypin) as for other users.
tl;dr Main workaround, signup for a gmail account, use it on the Forum, set
to forward gmail to your main account. But do read the bit about 'editing'
below.
You will note, (ATM - as I'm testing settings), such users actual-posts on
the Mailing-list appear as an attachment. It is the host of the users email
account that has the setting concerned. Note that gmail manages to work OK.
This may be fixed in the future, but setting up DMARC in our environment is
not straight forward.
If your a 'normal' user, whose posts end up under their real User name, you
can Edit via the More drop-down, HOWEVER!!!! when you do so the edits do not
get sent to Mailing-list users.
Edit basically corrects the archived post.
So, unless it is minor typo for posterity, you are better 'Reply'ing to you
own post, use the 'Quote' button, remove most of the quote (incl. all the
historical detritus) and show something like the dhskfnbeExample I will post
next.
- on the Forum, click on my MichaelAtOz label, there is a link to email me.
below.
*Edit basically corrects the archived post.*
next.
* on the Forum, click on my MichaelAtOz label, there is a link to email me.
Sat, May 22, 2021 7:18 AM
Arhhg! That was
MichaelAtOz wrote
...and show something like the
(falsely blames auto-correct)
Arhhg! That was
> Mobius-strip
> Example...
Sat, May 22, 2021 7:23 AM
you are better 'Reply'ing to you own post
Because you will note that such a correction does go to all the Mailing-list
users, unlike Forum 'Edits'.
Sat, May 22, 2021 7:37 AM
Email:
And just for completness, you will note such 'generic' posts show up in the
email inbox as /<Forum User name> via Discuss/, with their actual email in
the CC.
[unfortunately the CC is not available to me in the Nabble code I can
customise, and Nabble support is pupating]
and finally, re the BOSL dates, Terry I believe you will find that they are
the dates you extracted them from the zip file.
> Email:
> discuss@.openscad
the CC.
t.pinnell@btinternet.com
Sat, May 22, 2021 8:16 AM
Thanks Michael, understood. And your status reconfiguration seems to be working fine as I’m replying to this via email.
Terry
Nothing personal, but there is this technical issue with email authentication mechanisms.
You will note that some users, including you Terry, have posts that end up on the Forum under generic User names, e.g. "User: OpenSCAD mailing list-2 Email: discuss@lists.openscad.org" not the logged on User name (for Terry - Terrypin) as for other users.
tl;dr Main workaround, signup for a gmail account, use it on the Forum, set to forward gmail to your main account. But do read the bit about 'editing' below.
You will note, (ATM - as I'm testing settings), such users actual-posts on the Mailing-list appear as an attachment. It is the host of the users email account that has the setting concerned. Note that gmail manages to work OK.
This may be fixed in the future, but setting up DMARC in our environment is not straight forward.
If your a 'normal' user, whose posts end up under their real User name, you can Edit via the More drop-down, HOWEVER!!!! when you do so the edits do not get sent to Mailing-list users.
So, unless it is minor typo for posterity, you are better 'Reply'ing to you own post, use the 'Quote' button, remove most of the quote (incl. all the historical detritus) and show something like the dhskfnbeExample I will post next.
Unless specifically shown otherwise above, my contribution is in the Public Domain;
to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work.
Terry
> Obviously inclusion of works of previous authors is not included in the above.
Sat, May 22, 2021 10:37 AM
That is because we have two classes of users.
There is this technical issue with email authentication mechanisms.
It is the host of the email account that has the setting.
There is nothing I can do with an email service that is affected. (incl.
yahoo, aol, and many more)
Regarless you do NOT want to edit a post on the Forum.
If you had a material error in a post/email, either use the Forum and my
'Reply' 'Quote' suggestion, or via email reply to your email and do
likewise. ie "<expletive> I meant 'do NOT', not 'do'...."
It is the *host of the email account that has the setting*.
Gene Heskett
Sat, May 22, 2021 4:42 PM
something stupid...
First qualification for the latter is the recommend we do business of any
kind with gmail. I'm an old hand at that and gave up makeing gmail work
as an email server. I voted with my feet and procmail rules long ago,
and nothing I have seen since has changed my mind. And my incoming spam
traffic is 5% of what it was then. Missing the first post of a thread is
one of the hazards here. So are 2nd posts that do not quote the firat
for context continuity.
The alternative is far worse.
email me.
I am not posting from the forum, hence the onlist reply.
Cheers, Gene Heskett
-Ed Howdershelt (Author)
> something stupid...
> email me.
> Public Domain; to the extent possible under law, I have waived all
> copyright and related or neighbouring rights to this work. Obviously
- Louis D. Brandeis
Sat, May 22, 2021 10:04 PM
Sent: Sun, 23 May 2021 02:43
Subject: [OpenSCAD] Re: Is the BOSL 1.03 library obsolete?
Thanks Gene. I always like feedback.
OK.
If you can do business that way, but as the Forum & List Admin, that doesn't work for me.
For experienced email based users, I would expect they don't need coaching to find my email
address.
Let me know if I can assist further.
> -----Original Message-----
> From: Gene Heskett [mailto:gheskett@shentel.net]
> > something stupid...
> kind with gmail.
OK.
> > email me.
address.
> - Louis D. Brandeis
Gene Heskett
Sat, May 22, 2021 11:08 PM
something stupid...
of any
kind with gmail.
ago,
spam
firat
OK.
I can't argue with that at all. But it does confuse me when I see a reply
that looks interesting but I did not get the first, original post, and
the reply doesn't quote enough context that describes what the OP wants
to do So I'm sitting here in the dark. I can only guess that the O-Post
was to the forum, which I'm not a logged in member of. So my thoughts
are, that if they are going to be linked for replies, why not the
Original Post too?
There are those of us more comfy with a mailing list, and seeing the OP
would be a definite plus for list only members. I of coarse, haven't a
clue how hard that might be to accomplish. My oar to steer this ship is
a toothpick of coarse. MichaelAtOz will do as the list rules say. I am
pleased it exists, and has been most helpfull to this old new bee.
Thank you.
email me.
coaching to find my email address.
It is in the headers. But many do not accept email sent to that
address...
> > > something stupid...
> > of any
> > kind with gmail.
> > ago,
> > spam
> > firat
> OK.
Original Post too?
Thank you.
> > > email me.
address...
- Louis D. Brandeis
Sat, May 22, 2021 11:40 PM
reply that looks interesting but I did not get the first, original
post, and the reply doesn't quote enough context that describes what
the OP wants to do So I'm sitting here in the dark. I can only guess
that the O-Post was to the forum, which I'm not a logged in member of.
So my thoughts are, that if they are going to be linked for replies,
why not the Original Post too?
I haven't seen any evidence that initial forum posts don't go to the
mailing list.
For instance, I got Terry's initial message in this thread, and GregL's
"Challenge" message of the 21st at 3:56am Pacific, and both of those
appear to have originated at the forum.
mailing list.
