I never had to run OpenSCAD in Administrator mode, but now I do with the
2/25 release. This is a minor pain in the neck, since I have been
unable to find any combination of compatibility settings under
Properties that will allow me to do this automatically. Even right
clicking and selecting Run As Administrator still requires another click
before the program runs.
Anyone have any tips on how to make this process easier?
I just run with UAC off and have good firewalls (plural) and virus scanners.
View this message in context: http://forum.openscad.org/Administrator-Mode-tp11826p11861.html
You don't say what version of windows you have.
For Windows 7:
To mark an application to always run as an administrator, do the following:
The application will now always run using an administrator access token.
Keep in mind that if you are using a standard account and prompting is
disabled, the application will fail to run.
View this message in context: http://forum.openscad.org/Administrator-Mode-tp11826p11908.html
My understanding of the problem was that it shouldn't be necessary to run OpenSCAD as administrator in the first place.
I recall someone saying it was fiddling with areas of the registry which
required it, vague recall that if may be the first run which sets stuff up.
Helpful I know /:
View this message in context: http://forum.openscad.org/Administrator-Mode-tp11826p11910.html
I just changed UAC to max and 2015.02.25 ran without triggering UAC, NOT run
as Admin.
View this message in context: http://forum.openscad.org/Administrator-Mode-tp11826p11911.html
I just downloaded a version (2015.02.15) which I have not previously. Set it
up, no UAC events.
I've probably got whatever in my registry already.
View this message in context: http://forum.openscad.org/Administrator-Mode-tp11826p11912.html
