This has been driving me nuts.
I have a model with two tubes joined on one side at an angle.
The STL resulting has holes where the two arcs meet:
http://forum.openscad.org/file/n20041/holes_under.jpg
http://forum.openscad.org/file/n20041/holes_closeup.jpg
The two are the same just translated/rotated into the two positions.
I tried moving them in/out a bit, changing the $fa $fs values including to
ridiculous levels of detail, cleaning-up the join of that flat bit. I went
thru more than 10 iterations...
Finally, I rotated one 0.25 degrees on its z-axis, ie spin the cylinder.
Thus, I presume, moved vertices a fraction, overcoming the, again presumed,
floating point problem.
a. A tip
b. While 0.25d is trivial; is there any other way to join cleanly without
having to compromise the design?
I could have fixed the hole, but IMO it shouldn't get generated.
View this message in context: http://forum.openscad.org/Fix-holes-in-joined-tubes-tip-tp20041.html
What the fixed join looks like (with a fraction move apart too - but that was
after confirming the rotate fixed it).
http://forum.openscad.org/file/n20042/holes_fixed.jpg
View this message in context: http://forum.openscad.org/Fix-holes-in-joined-tubes-tip-tp20041p20042.html
MichaelAtOz wrote
a. A tip
I would clip the tubes appropriately before unioning them.
d=10; // distance
demo(x=d, w=60);
demo(x=d, w=-60);
module demo(R=20, r=18, h=40, x=0, w=0)
rotate([w, 0, 0]) // angle
translate([0, 0, x])
Ri(R, r, h);
// clip
translate([0, (w<0?-2:2)R])
cube(4R, center=true);
module Ri(R, r, h) linear_extrude(height = h, convexity = 2)
difference(){circle(R); circle(r);}
View this message in context: http://forum.openscad.org/Fix-holes-in-joined-tubes-tip-tp20041p20049.html
