Some thoughts on deriving world coordinates for objects
Fri, Oct 23, 2020 2:48 AM
[ Note:  In March 2019, I said this wasn't possible.  I was wrong. ]
Definition:  "world coordinates" are the resulting "universe" coordinate
system of the whole model, the coordinate system that the displayed axes
are relative to.  They are distinct from the local coordinate system
inside a transformed object, and from the device coordinates used to
represent the model on a display device.
People frequently ask about various problems that involve things like
measuring distances between points on a model.
There are two tough problems in these questions:
1)  OpenSCAD modules are black holes; information goes in but no
information comes out.  You cannot extract any information about the
contents of the module.  But it can echo, and maybe that's helpful.
Anyhow, I'm not thinking about this part of the problem.
2)  Modules are mostly opaque to data coming in, too.  The object
doesn't know what its ancestors will do to it.  A cube() thinks that it
has a corner at [0,0,0], but usually it will be translated and rotated
so that it doesn't, and it doesn't have any way to either reverse that
transformation or evaluate it to determine its world coordinates.
It's this latter that I've been musing about.
There's no intrinsic reason why an object can't know its own
transformation.  After all, it's called through a tree of
transformations.  Its parents could tell it the transformation.
Consider these redefinitions of some standard primitives:
// Initially, the local coordinates are the same as world coordinates.
$mm = [
    [1,0,0,0],
    [0,1,0,0],
    [0,0,1,0],
    [0,0,0,1]
// Given a point in local coordinates, return its location in world coordinates.
function whereis(p3) =
    let(r4 = $mm * [p3.x, p3.y, p3.z, 1])
    [ r4.x, r4.y, r4.z];
// Translate, but tracking the transformation.
module translate(delta) {
    m = [
        [1,0,0,delta.x],
        [0,1,0,delta.y],
        [0,0,1,delta.z],
        [0,0,0,1]
    $mm = $mm * m;
    multmatrix(m) children();
// Rotate, tracking transformations.
module rotate(a) {
    a = is_num(a) ? [ 0,0,a ] : a;
    echo(a);
    rx = [
        [1, 0,        0,         0],
        [0, cos(a.x), -sin(a.x), 0],
        [0, sin(a.x), cos(a.x),  0],
        [0, 0,        0,         1]
    ry = [
        [ cos(a.y),  0, sin(a.y), 0],
        [ 0,         1, 0,        0],
        [ -sin(a.y), 0, cos(a.y), 0],
        [ 0,         0, 0,        1]
    rz = [
        [ cos(a.z), -sin(a.z), 0, 0],
        [ sin(a.z), cos(a.z),  0, 0],
        [ 0,        0,         1, 0],
        [ 0,        0,         0, 1]
    m = rx*ry*rz;
    $mm = $mm * m;
// Scale, tracking transformations
module scale(s) {
    s = is_num(s) ? [ s,s,s ] : s;
    m = [
        [ s.x, 0,   0,   0 ],
        [ 0,   s.y, 0,   0 ],
        [ 0,   0,   s.z, 0 ],
        [ 0,   0,   0,   1 ]
    $mm = $mm * m;
scale(2) rotate(45) translate([0,5,0]) translate([10,0,0]) {
    cube();
    echo(whereis([0,0,0]));
These "transformation-tracking" transformation modules give their
children a transformation matrix $mm that is the transformation from
local coordinates to world coordinates.  This allows the child to, for
any point in its local coordinate system, determine (and presumably emit
via echo()) the corresponding world coordinates for that point.
For extra fun, let's give translate() another feature:
$rm = $mm;
// Translate, but tracking the transformation and reverse transformation.
    m = [
        [1,0,0,delta.x],
        [0,1,0,delta.y],
        [0,0,1,delta.z],
        [0,0,0,1]
    $mm = $mm * m;
    rm = [
        [1,0,0,-delta.x],
        [0,1,0,-delta.y],
        [0,0,1,-delta.z],
        [0,0,0,1]
    $rm = $rm * rm;
and add a new module:
module origin() {
    multmatrix($rm) children();
Now if we do this:
    cube();
    origin() cube();
We get a cube that's out at [10,5,0] and another cube that's at the
origin, and the cube at the origin stays there no matter what we do to
the enclosing transformations.
(Equivalent extensions to rotate() and scale() left as an exercise for
the reader.)
Net, you would be able to determine world coordinates, and you'd be able
to position things in world coordinates even from inside a transformed
coordinate system.
This is similar to schemes that others have devised where you maintain a
transformation matrix "by hand", and then you apply it to your points
and objects.  This scheme does it within the normal structure of
OpenSCAD transformations.
Note that while I've done this "in user mode", it could be implemented
inside OpenSCAD's built-in transformations.  (OCD:  Compatibly, give or
take the namespace intrusions.)
Problem:  scale with any axis having a scale of zero can't be reversed.
Problem:  reversing multmatrix itself is a matrix inversion, isn't
trivial.  (But it doesn't seem awful either.  Might be best to have
origin() invert $mm, rather than having multmatrix invert its argument.)
Combined with the $vxx variables, I think you could do things like have
label floating in a constant place on the screen, with an arrow pointing
at a particular point on the model.
You could not directly measure the distance between two points on the
model, because of the "module is a black hole" effect.  (Special case:
you can measure relative to an object that is the current object's
ancestor, because black holes only keep information from leaving.)
Similarly, you could not position an object relative to an object that
is not its ancestor.
Does anybody else think that there might be interesting possibilities here?
[ Note:  In March 2019, I said this wasn't possible.  I was wrong. ] Definition:  "world coordinates" are the resulting "universe" coordinate system of the whole model, the coordinate system that the displayed axes are relative to.  They are distinct from the local coordinate system inside a transformed object, and from the device coordinates used to represent the model on a display device. People frequently ask about various problems that involve things like measuring distances between points on a model. There are two tough problems in these questions: 1)  OpenSCAD modules are black holes; information goes in but no information comes out.  You cannot extract any information about the contents of the module.  But it can echo, and maybe that's helpful.  Anyhow, I'm not thinking about this part of the problem. 2)  Modules are mostly opaque to data coming *in*, too.  The object doesn't know what its ancestors will do to it.  A cube() thinks that it has a corner at [0,0,0], but usually it will be translated and rotated so that it doesn't, and it doesn't have any way to either reverse that transformation or evaluate it to determine its world coordinates. It's this latter that I've been musing about. There's no intrinsic reason why an object can't know its own transformation.  After all, it's called through a tree of transformations.  Its parents could tell it the transformation. Consider these redefinitions of some standard primitives: // Initially, the local coordinates are the same as world coordinates. $mm = [ [1,0,0,0], [0,1,0,0], [0,0,1,0], [0,0,0,1] ]; // Given a point in local coordinates, return its location in world coordinates. function whereis(p3) = let(r4 = $mm * [p3.x, p3.y, p3.z, 1]) [ r4.x, r4.y, r4.z]; // Translate, but tracking the transformation. module translate(delta) { m = [ [1,0,0,delta.x], [0,1,0,delta.y], [0,0,1,delta.z], [0,0,0,1] ]; $mm = $mm * m; multmatrix(m) children(); } // Rotate, tracking transformations. module rotate(a) { a = is_num(a) ? [ 0,0,a ] : a; echo(a); rx = [ [1, 0, 0, 0], [0, cos(a.x), -sin(a.x), 0], [0, sin(a.x), cos(a.x), 0], [0, 0, 0, 1] ]; ry = [ [ cos(a.y), 0, sin(a.y), 0], [ 0, 1, 0, 0], [ -sin(a.y), 0, cos(a.y), 0], [ 0, 0, 0, 1] ]; rz = [ [ cos(a.z), -sin(a.z), 0, 0], [ sin(a.z), cos(a.z), 0, 0], [ 0, 0, 1, 0], [ 0, 0, 0, 1] ]; m = rx*ry*rz; $mm = $mm * m; multmatrix(m) children(); } // Scale, tracking transformations module scale(s) { s = is_num(s) ? [ s,s,s ] : s; m = [ [ s.x, 0, 0, 0 ], [ 0, s.y, 0, 0 ], [ 0, 0, s.z, 0 ], [ 0, 0, 0, 1 ] ]; $mm = $mm * m; multmatrix(m) children(); } scale(2) rotate(45) translate([0,5,0]) translate([10,0,0]) { cube(); echo(whereis([0,0,0])); } These "transformation-tracking" transformation modules give their children a transformation matrix $mm that is the transformation from local coordinates to world coordinates.  This allows the child to, for any point in its local coordinate system, determine (and presumably emit via echo()) the corresponding world coordinates for that point. For extra fun, let's give translate() another feature: $rm = $mm; // Translate, but tracking the transformation and reverse transformation. module translate(delta) { m = [ [1,0,0,delta.x], [0,1,0,delta.y], [0,0,1,delta.z], [0,0,0,1] ]; $mm = $mm * m; rm = [ [1,0,0,-delta.x], [0,1,0,-delta.y], [0,0,1,-delta.z], [0,0,0,1] ]; $rm = $rm * rm; multmatrix(m) children(); } and add a new module: module origin() { multmatrix($rm) children(); } Now if we do this: translate([0,5,0]) translate([10,0,0]) { cube(); origin() cube(); } We get a cube that's out at [10,5,0] and another cube that's at the origin, and the cube at the origin stays there no matter what we do to the enclosing transformations. (Equivalent extensions to rotate() and scale() left as an exercise for the reader.) Net, you would be able to determine world coordinates, and you'd be able to position things in world coordinates even from inside a transformed coordinate system. This is similar to schemes that others have devised where you maintain a transformation matrix "by hand", and then you apply it to your points and objects.  This scheme does it within the normal structure of OpenSCAD transformations. Note that while I've done this "in user mode", it could be implemented inside OpenSCAD's built-in transformations.  (OCD:  Compatibly, give or take the namespace intrusions.) Problem:  scale with any axis having a scale of zero can't be reversed. Problem:  reversing multmatrix itself is a matrix inversion, isn't trivial.  (But it doesn't seem awful either.  Might be best to have origin() invert $mm, rather than having multmatrix invert its argument.) Combined with the $vxx variables, I think you could do things like have label floating in a constant place on the screen, with an arrow pointing at a particular point on the model. You could *not* directly measure the distance between two points on the model, because of the "module is a black hole" effect.  (Special case:  you can measure relative to an object that is the current object's ancestor, because black holes only keep information from leaving.)  Similarly, you could not position an object relative to an object that is not its ancestor. Does anybody else think that there might be interesting possibilities here?
Fri, Oct 23, 2020 3:00 AM
For anybody who is curious about the mistake that I made back then...
I had assumed that a module yielded an object based on its parameters,
period.  That object could then be transformed, after it was created.
Because it could be transformed after it was created, it couldn't
possibly know the relationship between its local coordinate system and
the world coordinate system, because at the time it was created that
relationship wasn't known.
There are perfectly reasonable graphics systems that use this model.
But that's not how OpenSCAD objects are created.  They are always
created in the context of their ancestral tree of transformations.  That
tree exists before the object is constructed.  In addition, that tree
can pass information down into the object in $ variables.
As a result, it is possible for an OpenSCAD object to know how its
local coordinate system relates to the world coordinate system.
On 10/22/2020 7:48 PM, Jordan Brown wrote: > > [ Note:  In March 2019, I said this wasn't possible.  I was wrong. ] > For anybody who is curious about the mistake that I made back then... I had assumed that a module yielded an object based on its parameters, period.  That object could then be transformed, *after* it was created.  Because it could be transformed after it was created, it couldn't possibly know the relationship between its local coordinate system and the world coordinate system, because at the time it was created that relationship wasn't known. There are perfectly reasonable graphics systems that use this model. But that's not how OpenSCAD objects are created.  They are always created in the context of their ancestral tree of transformations.  That tree exists *before* the object is constructed.  In addition, that tree can pass information down into the object in $ variables. As a result, it *is* possible for an OpenSCAD object to know how its local coordinate system relates to the world coordinate system.
Doug Moen
Fri, Oct 23, 2020 3:27 AM
It sounds similar to the Relativity library:
https://github.com/davidson16807/relativity.scad
  1. OpenSCAD modules are black holes; information goes in but no information comes out.  You cannot extract any information about the contents of the module.  But it can echo, and maybe that's helpful.  Anyhow, I'm not thinking about this part of the problem.
  2. Modules are mostly opaque to data coming in, too.  The object doesn't know what its ancestors will do to it.  A cube() thinks that it has a corner at [0,0,0], but usually it will be translated and rotated so that it doesn't, and it doesn't have any way to either reverse that transformation or evaluate it to determine its world coordinates.
$mm = [
[1,0,0,0],
[0,1,0,0],
[0,0,1,0],
[0,0,0,1]
m = [
[1,0,0,delta.x],
[0,1,0,delta.y],
[0,0,1,delta.z],
[0,0,0,1]
$mm = $mm * m;
module rotate(a) {
echo(a);
rx = [
[1, 0,        0,        0],
[0, 0,        0,        1]
ry = [
[ 0,        1, 0,        0],
[ 0,        0, 0,        1]
rz = [
[ 0,        0,        1, 0],
[ 0,        0,        0, 1]
m = rxryrz;
$mm = $mm * m;
module scale(s) {
m = [
[ s.x, 0,  0,  0 ],
[ 0,  s.y, 0,  0 ],
[ 0,  0,  s.z, 0 ],
[ 0,  0,  0,  1 ]
$mm = $mm * m;
cube();
$rm = $mm;
m = [
[1,0,0,delta.x],
[0,1,0,delta.y],
[0,0,1,delta.z],
[0,0,0,1]
$mm = $mm * m;
rm = [
[1,0,0,-delta.x],
[0,1,0,-delta.y],
[0,0,1,-delta.z],
[0,0,0,1]
$rm = $rm * rm;
module origin() {
Now if we do this:
cube();
origin() cube();
You could not directly measure the distance between two points on the model, because of the "module is a black hole" effect.  (Special case:  you can measure relative to an object that is the current object's ancestor, because black holes only keep information from leaving.)  Similarly, you could not position an object relative to an object that is not its ancestor.
It sounds similar to the Relativity library: https://github.com/davidson16807/relativity.scad On Thu, Oct 22, 2020, at 10:48 PM, Jordan Brown wrote: > [ Note: In March 2019, I said this wasn't possible. I was wrong. ] > Definition: "world coordinates" are the resulting "universe" coordinate system of the whole model, the coordinate system that the displayed axes are relative to. They are distinct from the local coordinate system inside a transformed object, and from the device coordinates used to represent the model on a display device. > > People frequently ask about various problems that involve things like measuring distances between points on a model. > > There are two tough problems in these questions: > 1) OpenSCAD modules are black holes; information goes in but no information comes out. You cannot extract any information about the contents of the module. But it can echo, and maybe that's helpful. Anyhow, I'm not thinking about this part of the problem. > > 2) Modules are mostly opaque to data coming *in*, too. The object doesn't know what its ancestors will do to it. A cube() thinks that it has a corner at [0,0,0], but usually it will be translated and rotated so that it doesn't, and it doesn't have any way to either reverse that transformation or evaluate it to determine its world coordinates. > > It's this latter that I've been musing about. > > There's no intrinsic reason why an object can't know its own transformation. After all, it's called through a tree of transformations. Its parents could tell it the transformation. > > Consider these redefinitions of some standard primitives: > >> // Initially, the local coordinates are the same as world coordinates. $mm = [ [1,0,0,0], [0,1,0,0], [0,0,1,0], [0,0,0,1] ]; // Given a point in local coordinates, return its location in world coordinates. function whereis(p3) = let(r4 = $mm * [p3.x, p3.y, p3.z, 1]) [ r4.x, r4.y, r4.z]; // Translate, but tracking the transformation. module translate(delta) { m = [ [1,0,0,delta.x], [0,1,0,delta.y], [0,0,1,delta.z], [0,0,0,1] ]; $mm = $mm * m; multmatrix(m) children(); } // Rotate, tracking transformations. module rotate(a) { a = is_num(a) ? [ 0,0,a ] : a; echo(a); rx = [ [1, 0, 0, 0], [0, cos(a.x), -sin(a.x), 0], [0, sin(a.x), cos(a.x), 0], [0, 0, 0, 1] ]; ry = [ [ cos(a.y), 0, sin(a.y), 0], [ 0, 1, 0, 0], [ -sin(a.y), 0, cos(a.y), 0], [ 0, 0, 0, 1] ]; rz = [ [ cos(a.z), -sin(a.z), 0, 0], [ sin(a.z), cos(a.z), 0, 0], [ 0, 0, 1, 0], [ 0, 0, 0, 1] ]; m = rx*ry*rz; $mm = $mm * m; multmatrix(m) children(); } // Scale, tracking transformations module scale(s) { s = is_num(s) ? [ s,s,s ] : s; m = [ [ s.x, 0, 0, 0 ], [ 0, s.y, 0, 0 ], [ 0, 0, s.z, 0 ], [ 0, 0, 0, 1 ] ]; $mm = $mm * m; multmatrix(m) children(); } scale(2) rotate(45) translate([0,5,0]) translate([10,0,0]) { cube(); echo(whereis([0,0,0])); } >> > These "transformation-tracking" transformation modules give their children a transformation matrix $mm that is the transformation from local coordinates to world coordinates. This allows the child to, for any point in its local coordinate system, determine (and presumably emit via echo()) the corresponding world coordinates for that point. > For extra fun, let's give translate() another feature: >> $rm = $mm; // Translate, but tracking the transformation and reverse transformation. module translate(delta) { m = [ [1,0,0,delta.x], [0,1,0,delta.y], [0,0,1,delta.z], [0,0,0,1] ]; $mm = $mm * m; rm = [ [1,0,0,-delta.x], [0,1,0,-delta.y], [0,0,1,-delta.z], [0,0,0,1] ]; $rm = $rm * rm; multmatrix(m) children(); } >> > and add a new module: >> module origin() { multmatrix($rm) children(); } >> > Now if we do this: >> translate([0,5,0]) translate([10,0,0]) { cube(); origin() cube(); } >> > We get a cube that's out at [10,5,0] and another cube that's at the origin, and the cube at the origin stays there no matter what we do to the enclosing transformations. > (Equivalent extensions to rotate() and scale() left as an exercise for the reader.) > Net, you would be able to determine world coordinates, and you'd be able to position things in world coordinates even from inside a transformed coordinate system. > This is similar to schemes that others have devised where you maintain a transformation matrix "by hand", and then you apply it to your points and objects. This scheme does it within the normal structure of OpenSCAD transformations. > Note that while I've done this "in user mode", it could be implemented inside OpenSCAD's built-in transformations. (OCD: Compatibly, give or take the namespace intrusions.) > Problem: scale with any axis having a scale of zero can't be reversed. > Problem: reversing multmatrix itself is a matrix inversion, isn't trivial. (But it doesn't seem awful either. Might be best to have origin() invert $mm, rather than having multmatrix invert its argument.) > Combined with the $vxx variables, I think you could do things like have label floating in a constant place on the screen, with an arrow pointing at a particular point on the model. > You could *not* directly measure the distance between two points on the model, because of the "module is a black hole" effect. (Special case: you can measure relative to an object that is the current object's ancestor, because black holes only keep information from leaving.) Similarly, you could not position an object relative to an object that is not its ancestor. > > Does anybody else think that there might be interesting possibilities here? > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Fri, Oct 23, 2020 4:35 AM
On 10/22/2020 8:27 PM, Doug Moen wrote:
Not really.  Relativity (from a brief look) is about constructing
objects connected to one another.
This concept is about managing the relationship between local
coordinates and world coordinates.
The two are orthogonal to one another.
On 10/22/2020 8:27 PM, Doug Moen wrote: > It sounds similar to the Relativity library: > https://github.com/davidson16807/relativity.scad > <https://github.com/davidson16807/relativity.scad> Not really.  Relativity (from a brief look) is about constructing objects connected to one another. This concept is about managing the relationship between local coordinates and world coordinates. The two are orthogonal to one another.
Rob Ward
Fri, Oct 23, 2020 8:00 AM
This is assuming there is some reverse logic provided at the time the forward logic of an openscad design is conceived. Unfortunately for people who ask these questions about openscad the original designers of the scripts (let's not call it a programming language until it can do X=X+1) only looked forward to what it could produce (ie parts for 3D printers).  Not how it it could be introspective, and analyse itself. Its current powers are a noble and awesome achievement for sure, and should be applauded, but in this race to simply produce "things" lies its main restriction.
Those of you who desire to work your way back through the 3-D machinations of your design to reliable coordinates in a defined universe will be ultimately disappointed. I am not, because I don't aspire to these heights of intellectual achievement. Design it, print it for me.
But I do understand what you desire, however only a total rewrite of openscad could achieve that. There are too many hours invested by the people who have built Openscad in the way it is useful for them now, to invest the intellectual effort you improve it beyond what will make most of their previous designs unworkable.
I have sympathies on both sides.
Cheers, RobW
On 23 October 2020 3:35:06 pm AEDT, Jordan Brown openscad@jordan.maileater.net wrote:
This is assuming there is some reverse logic provided at the time the forward logic of an openscad design is conceived. Unfortunately for people who ask these questions about openscad the original designers of the scripts (let's not call it a programming language until it can do X=X+1) only looked forward to what it could produce (ie parts for 3D printers). Not how it it could be introspective, and analyse itself. Its current powers are a noble and awesome achievement for sure, and should be applauded, but in this race to simply produce "things" lies its main restriction. Those of you who desire to work your way back through the 3-D machinations of your design to reliable coordinates in a defined universe will be ultimately disappointed. I am not, because I don't aspire to these heights of intellectual achievement. Design it, print it for me. But I do understand what you desire, however only a total rewrite of openscad could achieve that. There are too many hours invested by the people who have built Openscad in the way it is useful for them now, to invest the intellectual effort you improve it beyond what will make most of their previous designs unworkable. I have sympathies on both sides. Cheers, RobW On 23 October 2020 3:35:06 pm AEDT, Jordan Brown <openscad@jordan.maileater.net> wrote: >On 10/22/2020 8:27 PM, Doug Moen wrote: >> It sounds similar to the Relativity library: >> https://github.com/davidson16807/relativity.scad >> <https://github.com/davidson16807/relativity.scad> > >Not really.  Relativity (from a brief look) is about constructing >objects connected to one another. > >This concept is about managing the relationship between local >coordinates and world coordinates. > >The two are orthogonal to one another.
Fri, Oct 23, 2020 8:26 AM
Actually if you want to go to the effort of overriding all the transformation built-ins (translate, rotate, scale) with user modules calling multmatrix(), and provide an alternate call for multmatrix() itself, it should become fairly trivial to keep track of the world coordinates compared to local.
-Revar
Cheers, RobW
Actually if you want to go to the effort of overriding all the transformation built-ins (translate, rotate, scale) with user modules calling multmatrix(), and provide an alternate call for multmatrix() itself, it should become fairly trivial to keep track of the world coordinates compared to local. -Revar > On Oct 23, 2020, at 1:01 AM, Rob Ward <rl.ward@bigpond.com> wrote: > >  This is assuming there is some reverse logic provided at the time the forward logic of an openscad design is conceived. Unfortunately for people who ask these questions about openscad the original designers of the scripts (let's not call it a programming language until it can do X=X+1) only looked forward to what it could produce (ie parts for 3D printers). Not how it it could be introspective, and analyse itself. Its current powers are a noble and awesome achievement for sure, and should be applauded, but in this race to simply produce "things" lies its main restriction. > > Those of you who desire to work your way back through the 3-D machinations of your design to reliable coordinates in a defined universe will be ultimately disappointed. I am not, because I don't aspire to these heights of intellectual achievement. Design it, print it for me. > > But I do understand what you desire, however only a total rewrite of openscad could achieve that. There are too many hours invested by the people who have built Openscad in the way it is useful for them now, to invest the intellectual effort you improve it beyond what will make most of their previous designs unworkable. > > I have sympathies on both sides. > Cheers, RobW > >> On 23 October 2020 3:35:06 pm AEDT, Jordan Brown <openscad@jordan.maileater.net> wrote: >>> On 10/22/2020 8:27 PM, Doug Moen wrote: >>> It sounds similar to the Relativity library: >>> https://github.com/davidson16807/relativity.scad >> Not really. Relativity (from a brief look) is about constructing objects connected to one another. >> >> This concept is about managing the relationship between local coordinates and world coordinates. >> >> The two are orthogonal to one another. >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
arnholm (at) arnholm.org
Fri, Oct 23, 2020 8:43 AM
If you want to be a purist you might say that an object and its
transformation(s) are separate, the transformation defines the context
and an object can exist in several contexts at the same time. I come
from the tradition of Finite Element Analysis and super-element
techniques where this is important. A super-element can thus not know
its transformation, because it exists in multiple contexts on multiple
levels, and the same super-element might be "re-tracked" in several
contexts.
However, in Constructive Solid Geometry (CSG) this way of looking at
things is not so central, and unlike for Finite Element super-elements a
CSG object is typically copied with each transformation, so each copy
can thus know its transformation. This is exactly what happens in
AngelCAD. Also, since 3d objects are named variables there, they can be
used to return some information. Any 2d or 3d object inherits from
"shape" ( https://arnholm.github.io/angelcad-docs/docs/classshape.html )
and a shape can return its transformation in the form of a tmatrix
object which is essentially just a 4x4 homogenous transformation matrix
like in your code examples
argument.)
General NxN matrix inversion isn't trivial, but the special case of 4x4
inversion is pretty much trivial and can be coded symbolically.
On 2020-10-23 04:48, Jordan Brown wrote: > There's no intrinsic reason why an object can't know its own > transformation. After all, it's called through a tree of > transformations. Its parents could tell it the transformation. If you want to be a purist you might say that an object and its transformation(s) are separate, the transformation defines the context and an object can exist in several contexts at the same time. I come from the tradition of Finite Element Analysis and super-element techniques where this is important. A super-element can thus not know its transformation, because it exists in multiple contexts on multiple levels, and the same super-element might be "re-tracked" in several contexts. However, in Constructive Solid Geometry (CSG) this way of looking at things is not so central, and unlike for Finite Element super-elements a CSG object is typically copied with each transformation, so each copy can thus know its transformation. This is exactly what happens in AngelCAD. Also, since 3d objects are named variables there, they can be used to return some information. Any 2d or 3d object inherits from "shape" ( https://arnholm.github.io/angelcad-docs/docs/classshape.html ) and a shape can return its transformation in the form of a tmatrix object which is essentially just a 4x4 homogenous transformation matrix like in your code examples > Problem: reversing multmatrix itself is a matrix inversion, isn't > trivial. (But it doesn't seem awful either. Might be best to have > origin() invert $mm, rather than having multmatrix invert its > argument.) General NxN matrix inversion isn't trivial, but the special case of 4x4 inversion is pretty much trivial and can be coded symbolically. Carsten Arnholm
Fri, Oct 23, 2020 11:32 AM
This seems to work:
$local_matrix = undef;
function _wc_transpose(m) = [
    for (c=[0:3]) [
        for (r=[0:3]) m[r][c]
function _wc_minor(m,r,c) = [
    for (rr=[0:1:len(m)-1])
    if (rr != r) [
        for (cc=[0:1:len(m[rr])-1])
        if (cc != c)
        m[rr][cc]
function _wc_sum(v,_total=0,_i=0) =
    _i>=len(v) ? _total :
    _wc_sum(v, _total+v[_i], _i+1);
function _wc_determinant(m) =
    len(m)==2? m[0][0] * m[1][1] - m[0][1] * m[1][0] :
    _wc_sum([
        for (c = [0:1:len(m[0])-1])
        ((c%2==0)? 1 : -1) * m[0][c] *
        _wc_determinant(_wc_minor(m,0,c))
function _wc_inverse(m) =
    let(
        det = _wc_determinant(m),
        inv = _wc_transpose([
            for (r = [0:3]) [
                for (c = [0:3])
                ((r+c) % 2 == 0? 1 : -1) *
                _wc_determinant(_wc_minor(m,r,c))
        ]) / det
    ) inv;
function _wc_ident() = [
	[1, 0, 0, 0],
	[0, 1, 0, 0],
	[0, 0, 1, 0],
	[0, 0, 0, 1]
function _wc_translate(v) = [
    [1, 0, 0, v.x],
    [0, 1, 0, v.y],
    [0, 0, 1, v.z],
    [0 ,0, 0,   1]
function _wc_scale(v) = [
    [v.x,   0,   0, 0],
    [  0, v.y,   0, 0],
    [  0,   0, v.z, 0],
    [  0,   0,   0, 1]
function _wc_rotx(ang) = [
    [1,        0,         0,   0],
    [0, cos(ang), -sin(ang),   0],
    [0, sin(ang),  cos(ang),   0],
    [0,        0,         0,   1]
function _wc_roty(ang) = [
    [ cos(ang), 0, sin(ang),   0],
    [        0, 1,        0,   0],
    [-sin(ang), 0, cos(ang),   0],
    [        0, 0,        0,   1]
function _wc_rotz(ang) = [
    [cos(ang), -sin(ang), 0, 0],
    [sin(ang),  cos(ang), 0, 0],
    [       0,         0, 1, 0],
    [       0,         0, 0, 1]
function _wc_rot_by_axis(u, ang) =
    ang==0? _wc_ident() :
    let(
        u = u/norm(u),
        c = cos(ang),
        c2 = 1-c,
        s = sin(ang)
        [u.x*u.x*c2+c    , u.x*u.y*c2-u.z*s, u.x*u.z*c2+u.y*s, 0],
        [u.y*u.x*c2+u.z*s, u.y*u.y*c2+c    , u.y*u.z*c2-u.x*s, 0],
        [u.z*u.x*c2-u.y*s, u.z*u.y*c2+u.x*s, u.z*u.z*c2+c    , 0],
        [               0,                0,                0, 1]
function _wc_vec_angle(v1,v2) =
    let(
        n0 = norm(v1),
        n1 = norm(v2)
    assert(n0>0 && n1>0, "Zero length vector.")
    let (
        c1 = (v1*v2)/(n0*n1),
        c2 = min(max(c1,-1),1) // Correct for FP rounding errors.
    ) acos(c2);
function _wc_to3d(v) = [for (i=[0:2]) i<len(v)? v[i] : 0];
function _wc_vec_axis(v1,v2) =
        let(
          eps = 1e-6,
          w1 = _wc_to3d(v1/norm(v1)),
          w2 = _wc_to3d(v2/norm(v2)),
          w3 = (norm(w1-w2) > eps && norm(w1+w2) > eps) ? w2
               : (norm([abs(w2.x),abs(w2.y),abs(w2.z)]-[0,0,1]) > eps)? [0,0,1]
               : [1,0,0],
          x = cross(w1,w3)
        ) x/norm(x);
module translate(v) {
    multmat(_wc_translate(v)) children();
module scale(v) {
    multmat(_wc_scale(v)) children();
module rotate(a=0, v) {
    mat = is_undef(v)? (
        is_list(a)? (
            _wc_rotx(len(a)>=1? assert(is_num(a.x)) a.x : 0) *
            _wc_roty(len(a)>=2? assert(is_num(a.y)) a.y : 0) *
            _wc_rotz(len(a)>=3? assert(is_num(a.z)) a.z : 0)
            assert(is_num(a)) _wc_rotz(a)
        assert(is_num(a))
        assert(is_list(v))
        let( v = [ for (i=[0:2]) v[i] ] )
        _wc_rot_by_axis(v, a)
    multmat(mat) children();
module multmat(mat) {
    $local_matrix = is_undef($local_matrix)? mat : ($local_matrix * mat);
    multmatrix(mat) children();
// Returns the local transformation matrix.
function local_matrix() =
    is_undef($local_matrix)? _wc_ident() :
    $local_matrix;
// Returns the local translation vector [X,Y,Z]
function local_translation() =
    is_undef($local_matrix)? [0,0,0] :
    let(
        vec = [0, 0, 0, 1],
        lvec = $local_matrix * vec
    ) _wc_to3d(lvec);
// If mat is undef, resets to the world reference frame.
// If given a matrix in mat, resets to that reference frame.
module reference_frame(mat) {
    if (is_undef(mat)) {
        multmat(_wc_inverse($local_matrix)) children();
    } else {
        multmat(_wc_inverse(mat)) children();
translate([30,40,50]) {
    scale([2,3,4]) {
        rotate(30,v=[1,1,0]) {
            cylinder(d1=5,d2=0,h=5);
            reference_frame() {
                cylinder(d1=5,d2=0,h=5);  // This gets rendered in the world reference frame
You should be able to also store local reference frames in the middle there, in $special_vars and pass those to reference_frame() to access arbitrary reference frames.  You just have to make sure that your code never calls multmatrix(), but multmat() instead.
  • Revar
-Revar
Cheers, RobW
This seems to work: ```openscad $local_matrix = undef; function _wc_transpose(m) = [ for (c=[0:3]) [ for (r=[0:3]) m[r][c] ] ]; function _wc_minor(m,r,c) = [ for (rr=[0:1:len(m)-1]) if (rr != r) [ for (cc=[0:1:len(m[rr])-1]) if (cc != c) m[rr][cc] ] ]; function _wc_sum(v,_total=0,_i=0) = _i>=len(v) ? _total : _wc_sum(v, _total+v[_i], _i+1); function _wc_determinant(m) = len(m)==2? m[0][0] * m[1][1] - m[0][1] * m[1][0] : _wc_sum([ for (c = [0:1:len(m[0])-1]) ((c%2==0)? 1 : -1) * m[0][c] * _wc_determinant(_wc_minor(m,0,c)) ]); function _wc_inverse(m) = let( det = _wc_determinant(m), inv = _wc_transpose([ for (r = [0:3]) [ for (c = [0:3]) ((r+c) % 2 == 0? 1 : -1) * _wc_determinant(_wc_minor(m,r,c)) ] ]) / det ) inv; function _wc_ident() = [ [1, 0, 0, 0], [0, 1, 0, 0], [0, 0, 1, 0], [0, 0, 0, 1] ]; function _wc_translate(v) = [ [1, 0, 0, v.x], [0, 1, 0, v.y], [0, 0, 1, v.z], [0 ,0, 0, 1] ]; function _wc_scale(v) = [ [v.x, 0, 0, 0], [ 0, v.y, 0, 0], [ 0, 0, v.z, 0], [ 0, 0, 0, 1] ]; function _wc_rotx(ang) = [ [1, 0, 0, 0], [0, cos(ang), -sin(ang), 0], [0, sin(ang), cos(ang), 0], [0, 0, 0, 1] ]; function _wc_roty(ang) = [ [ cos(ang), 0, sin(ang), 0], [ 0, 1, 0, 0], [-sin(ang), 0, cos(ang), 0], [ 0, 0, 0, 1] ]; function _wc_rotz(ang) = [ [cos(ang), -sin(ang), 0, 0], [sin(ang), cos(ang), 0, 0], [ 0, 0, 1, 0], [ 0, 0, 0, 1] ]; function _wc_rot_by_axis(u, ang) = ang==0? _wc_ident() : let( u = u/norm(u), c = cos(ang), c2 = 1-c, s = sin(ang) ) [ [u.x*u.x*c2+c , u.x*u.y*c2-u.z*s, u.x*u.z*c2+u.y*s, 0], [u.y*u.x*c2+u.z*s, u.y*u.y*c2+c , u.y*u.z*c2-u.x*s, 0], [u.z*u.x*c2-u.y*s, u.z*u.y*c2+u.x*s, u.z*u.z*c2+c , 0], [ 0, 0, 0, 1] ]; function _wc_vec_angle(v1,v2) = let( n0 = norm(v1), n1 = norm(v2) ) assert(n0>0 && n1>0, "Zero length vector.") let ( c1 = (v1*v2)/(n0*n1), c2 = min(max(c1,-1),1) // Correct for FP rounding errors. ) acos(c2); function _wc_to3d(v) = [for (i=[0:2]) i<len(v)? v[i] : 0]; function _wc_vec_axis(v1,v2) = let( eps = 1e-6, w1 = _wc_to3d(v1/norm(v1)), w2 = _wc_to3d(v2/norm(v2)), w3 = (norm(w1-w2) > eps && norm(w1+w2) > eps) ? w2 : (norm([abs(w2.x),abs(w2.y),abs(w2.z)]-[0,0,1]) > eps)? [0,0,1] : [1,0,0], x = cross(w1,w3) ) x/norm(x); module translate(v) { multmat(_wc_translate(v)) children(); } module scale(v) { multmat(_wc_scale(v)) children(); } module rotate(a=0, v) { mat = is_undef(v)? ( is_list(a)? ( _wc_rotx(len(a)>=1? assert(is_num(a.x)) a.x : 0) * _wc_roty(len(a)>=2? assert(is_num(a.y)) a.y : 0) * _wc_rotz(len(a)>=3? assert(is_num(a.z)) a.z : 0) ) : ( assert(is_num(a)) _wc_rotz(a) ) ) : ( assert(is_num(a)) assert(is_list(v)) let( v = [ for (i=[0:2]) v[i] ] ) _wc_rot_by_axis(v, a) ); multmat(mat) children(); } module multmat(mat) { $local_matrix = is_undef($local_matrix)? mat : ($local_matrix * mat); multmatrix(mat) children(); } // Returns the local transformation matrix. function local_matrix() = is_undef($local_matrix)? _wc_ident() : $local_matrix; // Returns the local translation vector [X,Y,Z] function local_translation() = is_undef($local_matrix)? [0,0,0] : let( vec = [0, 0, 0, 1], lvec = $local_matrix * vec ) _wc_to3d(lvec); // If mat is undef, resets to the world reference frame. // If given a matrix in mat, resets to that reference frame. module reference_frame(mat) { if (is_undef(mat)) { multmat(_wc_inverse($local_matrix)) children(); } else { multmat(_wc_inverse(mat)) children(); } } translate([30,40,50]) { scale([2,3,4]) { rotate(30,v=[1,1,0]) { cylinder(d1=5,d2=0,h=5); reference_frame() { cylinder(d1=5,d2=0,h=5); // This gets rendered in the world reference frame } } } } ``` You should be able to also store local reference frames in the middle there, in $special_vars and pass those to reference_frame() to access arbitrary reference frames. You just have to make sure that your code never calls multmatrix(), but multmat() instead. - Revar > On Oct 23, 2020, at 1:26 AM, Revar Desmera <revarbat@gmail.com> wrote: > > Actually if you want to go to the effort of overriding all the transformation built-ins (translate, rotate, scale) with user modules calling multmatrix(), and provide an alternate call for multmatrix() itself, it should become fairly trivial to keep track of the world coordinates compared to local. > > -Revar > > >> On Oct 23, 2020, at 1:01 AM, Rob Ward <rl.ward@bigpond.com> wrote: >> >>  This is assuming there is some reverse logic provided at the time the forward logic of an openscad design is conceived. Unfortunately for people who ask these questions about openscad the original designers of the scripts (let's not call it a programming language until it can do X=X+1) only looked forward to what it could produce (ie parts for 3D printers). Not how it it could be introspective, and analyse itself. Its current powers are a noble and awesome achievement for sure, and should be applauded, but in this race to simply produce "things" lies its main restriction. >> >> Those of you who desire to work your way back through the 3-D machinations of your design to reliable coordinates in a defined universe will be ultimately disappointed. I am not, because I don't aspire to these heights of intellectual achievement. Design it, print it for me. >> >> But I do understand what you desire, however only a total rewrite of openscad could achieve that. There are too many hours invested by the people who have built Openscad in the way it is useful for them now, to invest the intellectual effort you improve it beyond what will make most of their previous designs unworkable. >> >> I have sympathies on both sides. >> Cheers, RobW >> >> On 23 October 2020 3:35:06 pm AEDT, Jordan Brown <openscad@jordan.maileater.net> wrote: >> On 10/22/2020 8:27 PM, Doug Moen wrote: >>> It sounds similar to the Relativity library: >>> https://github.com/davidson16807/relativity.scad <https://github.com/davidson16807/relativity.scad> >> Not really. Relativity (from a brief look) is about constructing objects connected to one another. >> >> This concept is about managing the relationship between local coordinates and world coordinates. >> >> The two are orthogonal to one another. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Fri, Oct 23, 2020 3:58 PM
See my separate message on the mistake that I made in March 2019.  That
was how I was thinking, that an object was a black box to which a
transformation was applied.
But that's not what OpenSCAD does.  I wouldn't say that it "copies" the
object, but rather that each invocation creates a new instance of the
object, in the context of its transformation.
Neither scheme is wrong... they're just different.
On 10/23/2020 1:43 AM, arnholm@arnholm.org wrote: > On 2020-10-23 04:48, Jordan Brown wrote: >> There's no intrinsic reason why an object can't know its own >> transformation.  After all, it's called through a tree of >> transformations.  Its parents could tell it the transformation. > If you want to be a purist you might say that an object and its > transformation(s) are separate, the transformation defines the context > and an object can exist in several contexts at the same time. See my separate message on the mistake that I made in March 2019.  That was how I was thinking, that an object was a black box to which a transformation was applied. But that's not what OpenSCAD does.  I wouldn't say that it "copies" the object, but rather that each invocation creates a new instance of the object, in the context of its transformation. Neither scheme is wrong... they're just different.
Fri, Oct 23, 2020 4:04 PM
But, for almost all transformations, there is.
When you say
translate([10,0,0]) ...
the inverse is
translate([-10,0,0]) ...
and similarly for any other transformation, except scale(0) variants.
The trick is in keeping track of those transformations and their
inverses as you work your way through the stack of transformations.
Note that I'm not attempting to "undo" Boolean operations... just
transformations.
On 10/23/2020 1:00 AM, Rob Ward wrote: > This is assuming there is some reverse logic provided at the time the > forward logic of an openscad design is conceived. But, for almost all transformations, there is. When you say translate([10,0,0]) ... the inverse is translate([-10,0,0]) ... and similarly for any other transformation, except scale(0) variants. The trick is in keeping track of those transformations and their inverses as you work your way through the stack of transformations. Note that I'm not attempting to "undo" Boolean operations... just transformations.
