Working on something a bit different --- worked up the code for making the union of a U.S. Flag at:
https://www.blockscad3d.com/community/projects/1963433
Note that ensuring that this adheres to U.S. Flag code is left as an exercise for the reader --- there should be sufficient parameters for that (and the numbers I initially used should have been correct, but didn't look right).
Next aspect to this is re-writing in Python so that it can be shared at: https://pythonscad.org/share_design.php
(which will hopefully show multi-colour DXF generation sufficiently simply/clearly that it will be of use to folks)
https://designinto3d.com/
I developed an OpenSCAD file to generate a US flag following official dimensions. The attached file has code to generate layers for my BambuLab 3D printer, but the geometry is in independent modules.
The only issue I had was that the stars while geometrically correct, didn’t look right when printed due to the extrusion width. I added a parameter to increase the star size to make it look right when extruded.
FWIW, I also created an OpenSCAD file for the Ohio State flag (where I live). It was much more difficult as the official specs are a drawing from the early 20th century and the stars are rotated.
Mark
On May 26, 2025, at 9:57 AM, William F. Adams via Discuss discuss@lists.openscad.org wrote:
