Editor issue: file opening unfold folded codes in all open files
runsun
Sat, Apr 18, 2015 1:39 AM
Issue: Opening a file (old or new) unfolds all codes that are folded in all
currently opened files.I've been encountered this issue for some time. It
happens in the older version as well as the newly released 2015.03 and the
nightly-builds (OS: linux Mint 17 and/or 17.1 x64)This creates a headache in
a coding session. Every time I opened a file, I'll have to go thru each
opened file to re-fold those that were folded before. This looks like a bug.
BTW, since we mentioning this, how about a "fold all" option in the menu ?
When files get larger, it'd be extremely helpful to be able to fold them all
at once. You can only work on a small portion at a time, anyway.
$  Runsun Pan, PhD
$ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse  )
View this message in context: http://forum.openscad.org/Editor-issue-file-opening-unfold-folded-codes-in-all-open-files-tp12412.html
Issue: Opening a file (old or new) unfolds all codes that are folded in all currently opened files.I've been encountered this issue for some time. It happens in the older version as well as the newly released 2015.03 and the nightly-builds (OS: linux Mint 17 and/or 17.1 x64)This creates a headache in a coding session. Every time I opened a file, I'll have to go thru each opened file to re-fold those that were folded before. This looks like a bug. BTW, since we mentioning this, how about a "fold all" option in the menu ? When files get larger, it'd be extremely helpful to be able to fold them all at once. You can only work on a small portion at a time, anyway. ----- $ Runsun Pan, PhD $ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse ) $ -- hash parameter model: here , here $ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD 2015.03.15/2015.04.01.nightly -- View this message in context: http://forum.openscad.org/Editor-issue-file-opening-unfold-folded-codes-in-all-open-files-tp12412.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Apr 18, 2015 3:07 AM
Fold all the files and/or fold all the foldable bits in the current file
and/or fold all the top level foldable bits in the current file. I'd suggest
the later.
View this message in context: http://forum.openscad.org/Editor-issue-file-opening-unfold-folded-codes-in-all-open-files-tp12412p12414.html
Fold all the files and/or fold all the foldable bits in the current file and/or fold all the top level foldable bits in the current file. I'd suggest the later. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Editor-issue-file-opening-unfold-folded-codes-in-all-open-files-tp12412p12414.html Sent from the OpenSCAD mailing list archive at Nabble.com.
runsun
Sun, Nov 13, 2016 1:58 AM
I continue to suffer this issue, now with the newest dev snapshot (2016.10.04
(git 7e0935d)). Seems that it was never addressed ?
$  Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 );   $ tips: hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg , tests ( 2 ), text ; $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf )
View this message in context: http://forum.openscad.org/Editor-issue-file-opening-unfold-folded-codes-in-all-open-files-tp12412p19067.html
I continue to suffer this issue, now with the newest dev snapshot (2016.10.04 (git 7e0935d)). Seems that it was never addressed ? ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 );   $ tips: hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg , tests ( 2 ), text ; $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf ) -- View this message in context: http://forum.openscad.org/Editor-issue-file-opening-unfold-folded-codes-in-all-open-files-tp12412p19067.html Sent from the OpenSCAD mailing list archive at Nabble.com.
