I've added cylindrical_heightfield() to BOSL2, so you can completely bypass the oddnesses of vnf_bend().
https://github.com/revarbat/BOSL2/wiki/shapes3d.scad#functionmodule-cylindrical_heightfield
-Revar
On May 12, 2022, at 1:40 PM, Joe Weinpert joe.weinpert@gmail.com wrote:
Been running a lot of different pics for testing. It is all working great.
This really opens a huge door for using openSCAD and BOSL2 to easily render intricately wrapped designs that are needed in woodworking. Hope that you place this new feature into the BOSL2.library. Until then, I will continue using the python script and bending function you designed and developed. And will post any other question I run across.
<octoBent.png>
On Thu, May 12, 2022 at 11:56 AM Revar Desmera <revarbat@gmail.com mailto:revarbat@gmail.com> wrote:
On May 12, 2022, at 8:37 AM, Joe Weinpert <joe.weinpert@gmail.com mailto:joe.weinpert@gmail.com> wrote:
I did have a rendering error when the wrapping was more intense.
ERROR: CGAL error in CGALUtils::applyBinaryOperator difference: CGAL ERROR: assertion violation! Expr: itl != it->second.end() File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_3/SNC_external_structure.h Line: 1152
I had a full-cylinder shape style wrap I was testing: "r" was 402, up() was 68.9803 and bend_scale was 6.2382 Took a long time, however, for it to throw the error.
Yeah, wrapping around the cylinder fully will induce self intersections in the VNF that will cause it to fail in render. You can only wrap slightly less than fully around the cylinder.
-Revar
Wonderful
Another good application would be:
If only the top surface needs to be wrapped around maybe various shapes
like cylinder, cone or any irregular surface
Regards
Sanjeev
-Revar
This really opens a huge door for using *openSCAD *and *BOSL2 *to easily
<octoBent.png>
Line: 1152
-Revar
Well, with a bit more work, you can use textured_linear_sweep(), textured_revolution(), or textured_cylinder() with counts=[1,1]. It'd take a but more fiddling about, but it should work. But conical mods to cylindrical_heightfield() are a good idea.
https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-textured_linear_sweep
https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-textured_revolution
https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-textured_cylinder
On May 17, 2022, at 12:33 AM, Sanjeev Prabhakar sprabhakar2006@gmail.com wrote:
Wonderful
If only the top surface needs to be wrapped around maybe various shapes like cylinder, cone or any irregular surface
Regards
Sanjeev
On Tue, 17 May 2022, 11:07 Revar Desmera, <revarbat@gmail.com mailto:revarbat@gmail.com> wrote:
https://github.com/revarbat/BOSL2/wiki/shapes3d.scad#functionmodule-cylindrical_heightfield https://github.com/revarbat/BOSL2/wiki/shapes3d.scad#functionmodule-cylindrical_heightfield
-Revar
Looks great
Thanks
Sanjeev
Wonderful
Regards
Sanjeev
-Revar
Very very good, indeed! I see the link for the python script, too.
-Revar
<octoBent.png>
Line: 1152
-Revar
