Re: Merging sub-assemblies?
Troberg
Sun, May 9, 2021 5:41 AM
I usually try to stay as true as possible to the construction method. Each
part I make will be one part in the model.
So, if I do something for laser cutting, I make each laser cut part each own
part. If I make a plan for woodworking, Every single bit will be it's own
module, which is then put together in one or more assemblies.
I usually try to stay as true as possible to the construction method. Each part I make will be one part in the model. So, if I do something for laser cutting, I make each laser cut part each own part. If I make a plan for woodworking, Every single bit will be it's own module, which is then put together in one or more assemblies. -- Sent from: http://forum.openscad.org/
