Hi all,
Many thanks for the years of wonderful use of OpenSCAD. I've been
working on the csgrs CAD kernel in Rust, which is now built around a
novel infinite precision partially symbolic numeric type. I've
recently accepted maintainership of SynapsCAD, an OpenSCAD compatible
Rust app with optional AI integration:
https://github.com/timschmidt/synaps-cad
You can try a web build of it here: https://timschmidt.github.io/synaps-cad/
All the math in this version of SynapsCAD is evaluated using
https://github.com/timschmidt/hyperreal at infinite precision. That
means you should be able to spin things around 10 billion times and
have them land in exactly the same spot, use arbitrarily large numbers
out to millions of digits (tested in our regression tests), or
extremely tiny numbers for nanomanufacturing. This didn't require
changing the OpenSCAD language in any way, I just replaced the scalar
underneath it. Of course, output is still triangulated / segmented.
As author / maintainer of the full stack under SynapsCAD, it's
possible for me to push some changes through the whole stack that
wouldn't be easy otherwise.
One of csgrs's dependencies: https://github.com/timschmidt/hypercurve
supports native exact lines, arcs, conics, cubic and quadratic
beziers, b-splines, and NURBs in 2D. It would be nice to find ways to
extend the language to support some of these things in ways which can
be standardized and supported by multiple implementations.
I've been thinking a lot about BOSL2 and NopSCADlib in this regard -
all the extensions they provide for the language. Certainly much of
what BOSL2 does can be supported at a lower level in the CAD kernel
directly, to speed it up, without presenting a materially different
API at OpenSCAD's level.
I guess I just wanted to open up the conversation and see what others
thought. What ideas y'all might have along these lines.
with great appreciation,
--tim
H Timi,
I tried the following on your web version (to test the angle misalign,
that I mentioned earlier)
module view_rocket() {
color("silver") cylinder(h = 40, r = 8);
color("red")
rotate([0,0.0001,0])
cylinder(h = 40, r=8);
changed $view to "rocket"
got this error
⚠️ Compilation warnings:
• Geometry failed: exact Difference failed: hypermesh boolean operation
failed: could not certify scalar sign; finite output retry failed:
hypermesh boolean operation failed: input mesh 1 has 8 boundary edges
Please report issues with the code that caused them.
Best wishes, Ray
ps this 'test' script OK in openscad
On 22/07/2026 18:52, Tim Schmidt via Discuss wrote:
Hi all,
--tim
