I am using the BOSL2 library to create several gears. I have successfully created a spur_gear, and I want to create a bevel_gear which, when viewed from the top (basically it's shadow), will match the spur_gear. This is my first time using bevel_gear, and I want the teeth to be straight, but they always seem to be curved. Can anybody tell me how to do this? Thanks.
Nathan Sokalski
I believe the solution is adding spiral=0, cutter_radius=0
On Oct 26, 2025, at 2:37 PM, Nathan Sokalski via Discuss discuss@lists.openscad.org wrote:
Nathan Sokalski
njsokalski@hotmail.com mailto:njsokalski@hotmail.com
That gets straight teeth, but I am also looking to be able to set the bevel gear on top of a spur gear. The teeth of this bevel gear look like the teeth of the spur gear tilted at an angle, but I want it to be something I can attach top to bottom
Nathan Sokalski
From: Revar Desmera via Discuss discuss@lists.openscad.org
Sent: Sunday, October 26, 2025 7:43 PM
Cc: Revar Desmera revarbat@gmail.com
Subject: [OpenSCAD] Re: Creating a Bevel Gear with Straight Teeth
Nathan Sokalski
Are you trying to mate a spur gear with a bevel gear? Even if the teeth
are straight on a bevel gear you can't mate it with a spur gear because the
teeth on the bevel gear taper. Bevel gears only mate with bevel gears. If
for some reason you want straight teeth Revar has given the method but if
you want to mate a spur gear then the crown_gear module may be what you are
looking for.
On Sun, Oct 26, 2025, 19:43 Revar Desmera via Discuss <
On Oct 26, 2025, at 2:37 PM, Nathan Sokalski via Discuss <
Nathan Sokalski
