VB
Verachten Bruno
Wed, Dec 30, 2020 2:25 PM
Hi there,
I think I got the use of modules, I almost manage to get what I'm looking for.
Now that I'd like to work more on calculating new values and changing
values inside vectors (producing new vectors) before using modules to
"draw" the results, I'm facing strange issues...
Using the same kind of code refactored so that it can fit within a
function, I don't get the same results.
It must be obvious, I'm doing something super wrong, but for the time
being, I just can't spot it.
Here is an over simplified version of the issues I'm facing.
feet = [[0,0,0], [77,0,0], [14,45.50,0], [63,45.5,0]];
trapezium(feet);
echo(trapezoid(feet));
module trapezium(points) {
// the base 1 is point 0 to point 1
// the base 2 is point 2 to point 3
bigBase = points[1][0] - points[0][0];
littleBase = points[3][0] - points[2][0];
height = points[3][1] - points[0][1];
area = (bigBaselittleBaseheight)/2;
echo("Big base is : ", bigBase, ", small base is : ", littleBase,
", height is : ", height, ", area is : ", area);
function trapezoid(points) = (points[1][0] - points[0][0]*points[3][0]
- points[2][0]*points[3][1] - points[0][1])/2;
That snippet of code gives me
ECHO: "Big base is : ", 77, ", small base is : ", 49, ", height is :
", 45.5, ", area is : ", 85835.8
ECHO: -280
What did I miss?
Thanks a lot,
Bruno Verachten
Hi there,
trapezium(feet);
area = (bigBase*littleBase*height)/2;
ECHO: -280
What did I miss?
Thanks a lot,
Bruno Verachten
Wed, Dec 30, 2020 2:37 PM
I suggest that your problem is you wrote the function in a cryptic way,
removing all the intermediate steps that make it debuggable. Instead, do it
like this:
let(
bigBase = points[1][0] - points[0][0],
littleBase = points[3][0] - points[2][0],
height = points[3][1] - points[0][1],
area;
I don't know what's wrong with your cryptic version, but the above version
matches the behavior of the module.
gounthar wrote
Hi there,
for.
trapezium(feet);
ECHO: -280
What did I miss?
Thanks a lot,
Bruno Verachten
like this:
let(
area;
gounthar wrote
> Hi there,
> for.
> trapezium(feet);
> ECHO: -280
> What did I miss?
> Thanks a lot,
> Bruno Verachten
> Discuss@.openscad
You need brackets around the subtractions so they are done before the
multiplication.
You can make it more readable by using .x for [0] and .y for [1].
You can also use let() to assign partial results to variables like your
module.
On Wed, 30 Dec 2020 at 14:26, Verachten Bruno gounthar@gmail.com wrote:
Hi there,
for.
trapezium(feet);
ECHO: -280
What did I miss?
Thanks a lot,
Bruno Verachten
multiplication.
module.
On Wed, 30 Dec 2020 at 14:26, Verachten Bruno <gounthar@gmail.com> wrote:
> Hi there,
> for.
> trapezium(feet);
> ECHO: -280
> What did I miss?
> Thanks a lot,
> Bruno Verachten
VB
Verachten Bruno
Wed, Dec 30, 2020 2:43 PM
Stupid me!
function trapezoid(points) = ([points[1][0] -
points[0][0]][points[3][0] - points[2][0]][points[3][1] -
points[0][1]])/2;
does work the same.
Thanks a lot all for your (much needed) help!
On Wed, Dec 30, 2020 at 3:38 PM nop head nop.head@gmail.com wrote:
You need brackets around the subtractions so they are done before the multiplication.
You can also use let() to assign partial results to variables like your module.
Hi there,
trapezium(feet);
ECHO: -280
What did I miss?
Thanks a lot,
Bruno Verachten
Stupid me!
points[0][0]]*[points[3][0] - points[2][0]]*[points[3][1] -
points[0][1]])/2;
does work the same.
>> Hi there,
>> trapezium(feet);
>> ECHO: -280
>> What did I miss?
>> Thanks a lot,
>> Bruno Verachten
Bruno Verachten
Wed, Dec 30, 2020 2:47 PM
It should really be parenthesis (round brackets). I think you fluked the
right answer with square brackets because you made the differences into one
element vectors and then multiplied those, which gives a scalar product.
On Wed, 30 Dec 2020 at 14:44, Verachten Bruno gounthar@gmail.com wrote:
Stupid me!
points[0][1]])/2;
does work the same.
Hi there,
trapezium(feet);
ECHO: -280
What did I miss?
Thanks a lot,
Bruno Verachten
On Wed, 30 Dec 2020 at 14:44, Verachten Bruno <gounthar@gmail.com> wrote:
> Stupid me!
> points[0][1]])/2;
> does work the same.
> multiplication.
> module.
> wrote:
> >> Hi there,
> looking for.
> >> trapezium(feet);
> >> ECHO: -280
> >> What did I miss?
> >> Thanks a lot,
> >> Bruno Verachten
> Bruno Verachten
