I do a lot of modelling that involves discarding the section with a
negative z so I decided to have a little module to do that; see code below.
The module intersects the basic design with a cube occupying the upper
part of the coordinate space. Because I wanted a general purpose module
that didn't depend on my model dimensions, I thought I might as well use
a huge cube, so I read up on the maximum allowed value for a number in
OpenSCAD. In line with an example in the online documentation I defined
a infinity variable and set it to 1e300 but it didn't work!
Nothing was generated in either preview or render, so I went through a
series of progressively smaller infinities until I got a value that
works in both preview and render. I have a solution that works but just
for interest - why are there problems with the bigger infinity values?
Steve
module top() {
// Using OpenSCAD versions 2021.01 or 2023.05.24
//inf = 1e300; // fails to display anything in both preview and render; with 2023.05.24, render reports no top level geometry
//inf = 1e10; // weird flickering as I change preview angle with mouse; seems okay in render
//inf = 1e6; // ok when previewed from above but disappears when I try to view underside; seems okay in render
inf = 1e4; // seems okay in both preview and render
translate([-inf / 2, -inf / 2, 0]) cube(inf);
children(0);
top() sphere(50);
