I'm getting this error when running openscad:
./openscad: error while loading shared libraries: libCGAL.so.11: cannot open
shared object file: No such file or directory
Check dependencies returns:
qt 4.4 unknown NotOK
qscintilla2 2.7 2.10.1 OK
cgal 3.6 4.7 OK
gmp 5.0 6.0.0 OK
mpfr 3.0 3.1.1 OK
boost 1.35 1.56 OK
opencsg 1.3.2 1.3.2 OK
glew 1.5.4 1.7.0 OK
eigen 3.0 3.2.2 OK
glib2 2.0 2.38.2 OK
fontconfig 2.10 2.11. OK
freetype2 2.4 2.6.1 OK
harfbuzz 0.9.19 0.9.35 OK
bison 2.4 2.7 OK
flex 2.5.35 2.5.37 OK
make 3 3.82 OK
Not sure why qt shows not OK but I built it and qmake worked.
Any ideas why I am getting the libCGAL error? libCGAL_Core.so.11 is in
/home/ec2-user/openscad_deps/lib and that directory is in $PATH.
Please help, thanks!
View this message in context: http://forum.openscad.org/openscad-error-while-loading-shared-libraries-libCGAL-so-11-cannot-open-shared-object-file-No-such-fy-tp21974.html
try
LD_LIBRARY_PATH=/home/ec2-user/openscad_deps/lib openscad
better yet install it (CGAL) using your package manager, failing that
compile and install from source...
cgal 3.6 4.7 OK
gmp 5.0 6.0.0 OK
mpfr 3.0 3.1.1 OK
boost 1.35 1.56 OK
glew 1.5.4 1.7.0 OK
eigen 3.0 3.2.2 OK
glib2 2.0 2.38.2 OK
bison 2.4 2.7 OK
make 3 3.82 OK
I did compile from source. I used the build from source script included with
openscad. Isn't that how it got to the /openscad_deps/ directory?
LD_LIBRARY_PATH=/home/ec2-user/openscad_deps/lib:/home/ec2-user/openscad_deps/lib64
fixed it.
It finally runs! That was quite a journey.
View this message in context: http://forum.openscad.org/openscad-error-while-loading-shared-libraries-libCGAL-so-11-cannot-open-shared-object-file-No-such-fy-tp21974p21976.html
