Hi
I am a second year architectural student and my project is to build a brick
house then 3d print it. Could you direct me to tutorial that would explain
how to texture the walls so that the model would have the look and feel of
real brick. Would texture stamping be the correct term for this technique?
Regard
Harry
Sent from my iPad
On 02/22/2015 04:47 PM, Harry Cohen wrote:
Could you direct me to tutorial that would explain how to texture
technique?
That's currently not possible with OpenSCAD, there is no color/
texture support for the final model (the preview does support
color).
A possible way is to export the model as STL and import into
Blender. There you have lots of options to finish the appearance
of the model and also generate high quality renderings.
In case you did not use Blender before, have a look at
Andrew Price: https://www.youtube.com/user/AndrewPPrice
Sardi Pax: https://www.youtube.com/user/srf123
Part 2 of "How to make an Airplane" tutorial has some good
examples of how to apply textures to a model:
Part 1: https://www.youtube.com/watch?v=mu9J0D6ebVw
Part 2: https://www.youtube.com/watch?v=p4lsgMw9uQc
In OpenSCAD you'll have to do it the old fashioned way:
for (i=[0:10])
for (j=[0:10])
translate([i1.1+j/2,j1.1,0])cube();
2015-02-22 17:01 GMT+01:00 Torsten Paul Torsten.Paul@gmx.de:
technique?
color).
schreiben.
Enjoy!
Not bricks, but you may get some ideas from this
http://www.thingiverse.com/thing:5299 or this
http://www.thingiverse.com/thing:31832 .
You could think about using surface() to provide a brick texture (is a 3D
sense) , should be easy to script a repetitive pattern.
View this message in context: http://forum.openscad.org/Textures-tp11692p11719.html
On Sun, 22 Feb 2015 17:56:56 +0100
for (i=[0:10])
for (j=[0:10])
Not entirely true. You can import a DXF of the brick pattern and then
extrude it and difference it.
However, a word of caution. The difference between the surface of a brick
and the mortar is usually of the order of millimetres, it's almost always
the case that a correct scale down of bricks to a 3D printed model should
not have brick patterns scribed into it and you can do the brick patterns
far more accurately when colouring it (eg using vinyls).
Alan
..of course there is the option to use surface(“texture.png”).
This will create some sort of relief, assuming that intensities in the png are representative of elevation values.
Then, the resulting object can be treated like any other object in OpenSCAD.
Note: This will likely severely impact your rendering (F6) performance.
