This is what i was suggesting, You should be able to copy both the
library file and the construction file - make sure you adjust the
library location in the includes to your library location, of course.
A library file named nema_lib.scad say (with explanatory comments)
//nema fix plate library
/* notes
sc= shaft clearance
pd =pilot diameter
pl = pilot length
bd= bolt diameter
s= bolt fixings square
nema series is in inches, these metric values may have errors, nema17
should have unc thread in motor plate
depending on manufacturer. Best to check motor and adjust values as
required.
module nema_plate(sc,pd,pl,bd,s){
p=s/2;
translate([0,0,-pl])cylinder(h=pl2,d=pd,true); //to pl2 to stop z
fighting
// fix holes
translate([p,p,-50])cylinder(h=100,d=bd,true);
translate([p,-p,-50])cylinder(h=100,d=bd,true);
translate([-p,p,-50])cylinder(h=100,d=bd,true);
translate([-p,-p,-50])cylinder(h=100,d=bd,true);
translate([0,0,-50])cylinder (h=100,d=sc,true);
echo("bolt holes diameter =",bd);
module nema23_fix( ){
echo("Nema23");
nema_plate(
sc=7,
pd=38.1,
pl=1.5748,
bd=5,
s=47.1424 );
module nema17_fix( ){
echo("Nema17");
nema_plate(
sc=5.5,
pd=22,
pl=2.26,
bd=4.4,
s=30.988 );
module nema34_fix( ){
echo("Nema34");
nema_plate(
sc=10,
pd=73.025,
pl=1.5748,
bd=5.6,
s=69.596);
module nema42_fix( ){
echo("Nema42");
nema_plate(
sc=18,
pd=55.5244,
pl=1.5748,
bd=7.5,
s=88.9 );
a construction file which uses the library file
//test for making and positioning nema motor mounting plate
// plates depend not only on motor, but on whatever is supporting
it- it may not be square
// so they should be kept as a separate parts
// locate and make a nema34 mounting plate
// say centre of plate at 120,120,top at 100, and 120 mm square and
plate is always 10mm thick
// or maybe it could be 8mm... just change t
// 10mm fixing holes 10 mm in from two opposite corners
// in practice, the plates would be drawn as 2d, for 3 axis
milling, but 3d is ok for a ga.
t=10;// plate thickness
module nema34_plate(){
include<C:/users/Ray/Desktop/openscad/nema_lib.scad> ;
translate ([0,0,-t/2])
cube([120,120,t],true);
nema34_fix();
translate([120,120,100])
//fixing holes
nema34_plate();
translate ([50,50,-20]) cylinder(h=50, d=10);
translate ([-50,-50,-20]) cylinder(h=50, d=10);
// and say a nema 23, vertical, plate at y =-10, // xz axis same
thickness, 80mm square
module nema23_plate(){
cube([80,80,t],true);
bd=666; //just to show no name conflicts
s=222222; // likewise
nema23_fix();
translate([40,-10,40])
rotate([90,0,0])
nema23_plate();
// and so on and so forth.
// For this example, one library include would do outside of the
modules, but
// if the nemaxx_fix modules were different e.g. decided to move
the plate dimensions into there, then
//would need the separate modules as here.
// there are no conflicts of variable names with those in the library
sc=500; // no conflict
bd ="hi there"; // no conflict
// what starts in a module, stays in a module
Best wishes,
Ray
