Any success building library dependencies on Mac OS X 10.11 via scripts/macosx-build-dependencies.sh?
AP
Andrew Plumb
Sat, Nov 21, 2015 6:36 PM
Hi Everyone,
Has anyone been building the dependencies on Mac OS X 10.11 with Xcode Version 7.1 (7B91b) successfully via the scripts/macosx-build-dependencies.sh script?
My attempts get hung up at the qt5 (5.5.1) stage, unable to find/resolve ‘-lqtpcre’:
ld: library not found for -lqtpcre
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[3]: *** [../../lib/QtCore.framework/QtCore] Error 1
make[2]: *** [sub-corelib-install_subtargets] Error 2
make[1]: *** [sub-src-install_subtargets] Error 2
make: *** [module-qtbase-install_subtargets] Error 2
I didn’t have any trouble installing qt5 directly from qt.io, and Mac Ports “sudo port install qt5” worked too, so it feels more like a problem with scripts/macosx-build-dependencies.sh than elsewhere.
Some other tweaks I had to make to get to this point:
# curl -O http://www.mpfr.org/mpfr-$version/mpfr-$version.tar.bz2
curl -O https://ftp.gnu.org/gnu/mpfr/mpfr-$version.tar.bz2
# curl -LO http://downloads.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2
curl -LO http://ufpr.dl.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2
Thanks!
Andrew.
"The future is already here.  It's just not very evenly distributed" -- William Gibson
Me: http://clothbot.com/wiki/ http://clothbot.com/wiki/
Hi Everyone, Has anyone been building the dependencies on Mac OS X 10.11 with Xcode Version 7.1 (7B91b) successfully via the scripts/macosx-build-dependencies.sh script? My attempts get hung up at the qt5 (5.5.1) stage, unable to find/resolve ‘-lqtpcre’: ld: library not found for -lqtpcre clang: error: linker command failed with exit code 1 (use -v to see invocation) make[3]: *** [../../lib/QtCore.framework/QtCore] Error 1 make[2]: *** [sub-corelib-install_subtargets] Error 2 make[1]: *** [sub-src-install_subtargets] Error 2 make: *** [module-qtbase-install_subtargets] Error 2 I didn’t have any trouble installing qt5 directly from qt.io, and Mac Ports “sudo port install qt5” worked too, so it feels more like a problem with scripts/macosx-build-dependencies.sh than elsewhere. Some other tweaks I had to make to get to this point: # curl -O http://www.mpfr.org/mpfr-$version/mpfr-$version.tar.bz2 curl -O https://ftp.gnu.org/gnu/mpfr/mpfr-$version.tar.bz2 # curl -LO http://downloads.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 curl -LO http://ufpr.dl.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 Thanks! Andrew. -- "The future is already here. It's just not very evenly distributed" -- William Gibson Me: http://clothbot.com/wiki/ <http://clothbot.com/wiki/>
Sat, Nov 21, 2015 6:39 PM
On 11/21/2015 07:36 PM, Andrew Plumb wrote: > My attempts get hung up at the qt5 (5.5.1) stage, unable to find/resolve ‘-lqtpcre’: > Have a look at https://github.com/openscad/openscad/issues/1490 ciao, Torsten.
Sat, Nov 21, 2015 6:45 PM
If you can see any differences that would trigger this issue, please let me know. Could it be that this is a bug in the Qt build system which triggers only when using some variation of which external components to user?
Hm, that’s odd. What failed with the original locations? I’ve been using this for years..
> > I didn’t have any trouble installing qt5 directly from qt.io, and Mac Ports “sudo port install qt5” worked too, so it feels more like a problem with scripts/macosx-build-dependencies.sh than elsewhere. > If you can see any differences that would trigger this issue, please let me know. Could it be that this is a bug in the Qt build system which triggers only when using some variation of which external components to user? > Some other tweaks I had to make to get to this point: > > # curl -O http://www.mpfr.org/mpfr-$version/mpfr-$version.tar.bz2 > curl -O https://ftp.gnu.org/gnu/mpfr/mpfr-$version.tar.bz2 > > # curl -LO http://downloads.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 > curl -LO http://ufpr.dl.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 > Hm, that’s odd. What failed with the original locations? I’ve been using this for years.. -Marius
AP
Andrew Plumb
Sat, Nov 21, 2015 7:15 PM
For those two, there was a period last week when neither were reachable/resolving so I found alternates.
I’m going to keep them in place for myself while I poke at the qt5 issue with a Big Stick.
Andrew.
> On Nov 21, 2015, at 1:45 PM, Marius Kintel <marius@kintel.net> wrote: > >> >> I didn’t have any trouble installing qt5 directly from qt.io, and Mac Ports “sudo port install qt5” worked too, so it feels more like a problem with scripts/macosx-build-dependencies.sh than elsewhere. >> > If you can see any differences that would trigger this issue, please let me know. Could it be that this is a bug in the Qt build system which triggers only when using some variation of which external components to user? > >> Some other tweaks I had to make to get to this point: >> >> # curl -O http://www.mpfr.org/mpfr-$version/mpfr-$version.tar.bz2 >> curl -O https://ftp.gnu.org/gnu/mpfr/mpfr-$version.tar.bz2 >> >> # curl -LO http://downloads.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 >> curl -LO http://ufpr.dl.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 >> > Hm, that’s odd. What failed with the original locations? I’ve been using this for years.. > > -Marius For those two, there was a period last week when neither were reachable/resolving so I found alternates. I’m going to keep them in place for myself while I poke at the qt5 issue with a Big Stick. Andrew. -- "The future is already here. It's just not very evenly distributed" -- William Gibson Me: http://clothbot.com/wiki/ <http://clothbot.com/wiki/>
AP
Andrew Plumb
Sat, Nov 21, 2015 7:16 PM
Thanks for pointing me at that.  It didn’t exist when I took a first stab at things but didn’t have time to dig into it at the time.  It’s not just me!
A.
Thanks for pointing me at that. It didn’t exist when I took a first stab at things but didn’t have time to dig into it at the time. It’s not just me! A. > On Nov 21, 2015, at 1:39 PM, Torsten Paul <Torsten.Paul@gmx.de> wrote: > > On 11/21/2015 07:36 PM, Andrew Plumb wrote: >> My attempts get hung up at the qt5 (5.5.1) stage, unable to find/resolve ‘-lqtpcre’: >> > Have a look at https://github.com/openscad/openscad/issues/1490 > > ciao, > Torsten. > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- "The future is already here. It's just not very evenly distributed" -- William Gibson Me: http://clothbot.com/wiki/ <http://clothbot.com/wiki/>
AP
Andrew Plumb
Sun, Nov 22, 2015 3:03 AM
Big Stick poking mission a success!  All that was needed was an extra configure “-skip qtwebchannel” to clean up some unnecessary, broken dependencies.
https://github.com/openscad/openscad/pull/1501 https://github.com/openscad/openscad/pull/1501
Marius has already merged it in, so should be good to go!
Andrew.
On Nov 21, 2015, at 2:15 PM, Andrew Plumb andrew@plumb.org wrote:
On Nov 21, 2015, at 1:45 PM, Marius Kintel <marius@kintel.net mailto:marius@kintel.net> wrote:
I didn’t have any trouble installing qt5 directly from qt.io http://qt.io/, and Mac Ports “sudo port install qt5” worked too, so it feels more like a problem with scripts/macosx-build-dependencies.sh than elsewhere.
# curl -O http://www.mpfr.org/mpfr-$version/mpfr-$version.tar.bz2 <http://www.mpfr.org/mpfr-$version/mpfr-$version.tar.bz2>
curl -O https://ftp.gnu.org/gnu/mpfr/mpfr-$version.tar.bz2 <https://ftp.gnu.org/gnu/mpfr/mpfr-$version.tar.bz2>
# curl -LO http://downloads.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 <http://downloads.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2>
curl -LO http://ufpr.dl.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 <http://ufpr.dl.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2>
Andrew.
Big Stick poking mission a success! All that was needed was an extra configure “-skip qtwebchannel” to clean up some unnecessary, broken dependencies. https://github.com/openscad/openscad/pull/1501 <https://github.com/openscad/openscad/pull/1501> Marius has already merged it in, so should be good to go! Andrew. > On Nov 21, 2015, at 2:15 PM, Andrew Plumb <andrew@plumb.org> wrote: > >> >> On Nov 21, 2015, at 1:45 PM, Marius Kintel <marius@kintel.net <mailto:marius@kintel.net>> wrote: >> >>> >>> I didn’t have any trouble installing qt5 directly from qt.io <http://qt.io/>, and Mac Ports “sudo port install qt5” worked too, so it feels more like a problem with scripts/macosx-build-dependencies.sh than elsewhere. >>> >> If you can see any differences that would trigger this issue, please let me know. Could it be that this is a bug in the Qt build system which triggers only when using some variation of which external components to user? >> >>> Some other tweaks I had to make to get to this point: >>> >>> # curl -O http://www.mpfr.org/mpfr-$version/mpfr-$version.tar.bz2 <http://www.mpfr.org/mpfr-$version/mpfr-$version.tar.bz2> >>> curl -O https://ftp.gnu.org/gnu/mpfr/mpfr-$version.tar.bz2 <https://ftp.gnu.org/gnu/mpfr/mpfr-$version.tar.bz2> >>> >>> # curl -LO http://downloads.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 <http://downloads.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2> >>> curl -LO http://ufpr.dl.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2 <http://ufpr.dl.sourceforge.net/project/boost/boost/$version/boost_$bversion.tar.bz2> >>> >> Hm, that’s odd. What failed with the original locations? I’ve been using this for years.. >> >> -Marius > > For those two, there was a period last week when neither were reachable/resolving so I found alternates. > > I’m going to keep them in place for myself while I poke at the qt5 issue with a Big Stick. > > Andrew. > > > -- > > "The future is already here. It's just not very evenly distributed" -- William Gibson > > Me: http://clothbot.com/wiki/ <http://clothbot.com/wiki/> > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> -- "The future is already here. It's just not very evenly distributed" -- William Gibson Me: http://clothbot.com/wiki/ <http://clothbot.com/wiki/>
