If one makes a basic 3D object:
cube(size = [4,9,1], center = false);
then it calculates straight-forwardly enough:
Geometries in cache: 2
Geometry cache size in bytes: 1456
CGAL Polyhedrons in cache: 0
CGAL cache size in bytes: 0
Total rendering time: 0:00:00.020
Facets: 6
but if one makes the same shape using hull operations:
(see screen grab at: https://community.carbide3d.com/t/efficiency-of-stl-generation-in-openscad/25639 )
Geometries in cache: 11
Geometry cache size in bytes: 154600
CGAL Polyhedrons in cache: 3
CGAL cache size in bytes: 485872
Total rendering time: 0:00:07.088
Simple: yes
Vertices: 8
Halfedges: 24
Edges: 12
Halffacets: 12
Facets: 6
Volumes: 2
which is an increase in some number of 100-fold.
Interestingly if one exports an STL, both files create a 1,535 byte STL file --- presumably there is some optimization which happens when creating the STL.
Would it improve handling of files created using similar techniques to perform this operation intermittently while working on an OpenSCAD file?
Is there some command which would do this already?
Just as you commanded by giving $fn = 80.
What does that mean?
creating the STL.
What you are observing is that the first example is a primitive solid,
no need to involve CGAL booleans in order to create an STL from it.
The second example uses union, hull and difference on multiple solid
primitives, "accidentally" ending up with a result equivalent to the
first primitive solid, in OpenSCAD this means using CGAL datastructures
and operations. What is listed for the second case is resulting CGAL
half edge datastructure object counts for the resulting cuboid-shaped
polyhedron. Translated to STL it gives the same result as in the
primitive case.
There is no optimization happening related to STL, you just devised two
very different routes to creating the same object, where one route is
much more complex than the other.
The 100-fold increase in cache size could perhaps be taken as a measure
of how much more complex the second route is. It does not say anything
about the complexity of the result.
Of course, if you could save intermediate objects to file and forget
about how complex the route was to get there, potentially you could
solve larger problems.
Regards
Carsten Arholm
Oh.
Okay. But what about the complexity of the internal representation?
Agreed, but I'd rather not trouble about writing out a file --- would it be feasible/desirable to afford a command in OpenSCAD which would do this sort of internal optimization with an eye towards allowing OpenSCAD to work faster and to allow working on more complex files?
That sounds interesting.
Oh.
and Torsten Paul replied:
but if I comment that out we still get:
Rendering Polygon Mesh using CGAL...Geometries in cache: 11Geometry cache size in bytes: 13048CGAL Polyhedrons in cache: 3CGAL cache size in bytes: 77296Total rendering time: 0:00:00.724 Top level object is a 3D object: Simple: yes Vertices: 8 Halfedges: 24 Edges: 12 Halffacets: 12 Facets: 6 Volumes: 2Rendering finished.
which still has some markedly larger numbers.
What if there were a command which would allow when possible simplifying the geometric representation to a simpler form involving fewer triangles?
Presumably if the basic cube and the hulled version had further operations applied to them the hulled version would be more complex in internal representation than the same operation applied to the basic cube.
If there were such a simplification process command it could be called after complex operations (with simple results?) and then simpler, more elegant (in the traditional sense of "scientifically correct") representation be used for further operations.
In theory, perhaps. This would be something for the OpenSCAD developers
to answer. My guess is it is not so easy.
Yes, it's still using the default resolution for the
hulled cylinders which have more vertices than just a
plain cube.
That might be useful, but could prove a bit difficult
to parameterize (e.g. limit by face angle, and such
things).
In addition to that, there's an almost finished change
implementing a persistent cache. Hopefully that will
get to mergeable state soon-ish. In combination with
render() that would allow to cover cases where people
did export partial models as STL before.
You should examine the Design/Display-[CSG Tree / CSG Products] for your
milled version.
You will see the complexity it produces.
Such as render()?
Try activating "show edges" and look at the difference between and after a
render() of your objects.
