Function literals in commandline OpenSCAD
JK
Jan Koupil
Sat, Aug 15, 2020 6:37 PM
Hi all,
I am successfully using the function literals from dev snapshot in my
project. However, when I started my "mass production" of STLs from
command line, the production failed with a warning:
WARNING: Support for function literals is disabled in file
make_tile.scad, line 68
Function literals are enabled in my OpenSCAD GUI, however, the
commandline openscad.com seems to use a different settings set. Is there
any help?
Thanks
Jan
Hi all, I am successfully using the function literals from dev snapshot in my project. However, when I started my "mass production" of STLs from command line, the production failed with a warning: WARNING: Support for function literals is disabled in file make_tile.scad, line 68 Function literals are enabled in my OpenSCAD GUI, however, the commandline openscad.com seems to use a different settings set. Is there any help? Thanks Jan
Sat, Aug 15, 2020 6:48 PM
There are no persistent settings for command line, but you
can enable via command line parameter:
--enable=function-literals
On 15.08.20 20:37, Jan Koupil wrote: > Function literals are enabled in my OpenSCAD GUI, however, > the commandline openscad.com seems to use a different > settings set. Is there any help? There are no persistent settings for command line, but you can enable via command line parameter: --enable=function-literals ciao, Torsten.
