Re: [OpenSCAD] Setting Normalized Tree limit from command line?
Sun, Nov 6, 2016 8:17 PM
accepted by the mailing list yet", so nobody gets it unless they look.
You need to subscribe to the  mailing list
http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1  ,
Yourt post is copied below for others to see (I'm not a big cmdline user)
Troberg wrote
I'm trying to generate a bunch of images from the command line, and get
"Warning: Normalized tree is growing past 100000 elements. Aborting
normalization." and the image comes out with some holes coming out as
positives instead.
I've tried increasing "Turn off rendering at" in the GUI, but it doesn't
seem to have any effect on the command line.
Solution?
Edit: I only get this problem when rendering as preview, not when doing a
real render. Both work nicely in the GUI, but not when batching. I'd
prefer to do a preview, as I want the colors preserved.
View this message in context: http://forum.openscad.org/Setting-Normalized-Tree-limit-from-command-line-tp18958p18961.html
Welcome to the forum. Your post is still flagged as "This post has NOT been accepted by the mailing list yet", so nobody gets it unless they look. You need to subscribe to the mailing list <http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1> , and respond to the registration email. Yourt post is copied below for others to see (I'm not a big cmdline user) Troberg wrote > I'm trying to generate a bunch of images from the command line, and get > "Warning: Normalized tree is growing past 100000 elements. Aborting > normalization." and the image comes out with some holes coming out as > positives instead. > > I've tried increasing "Turn off rendering at" in the GUI, but it doesn't > seem to have any effect on the command line. > > Solution? > > Edit: I only get this problem when rendering as preview, not when doing a > real render. Both work nicely in the GUI, but not when batching. I'd > prefer to do a preview, as I want the colors preserved. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Setting-Normalized-Tree-limit-from-command-line-tp18958p18961.html Sent from the OpenSCAD mailing list archive at Nabble.com.
