Sun, Aug 7, 2022 10:45 PM
Greetings all;
I get the impression that my definition of an ellipse is a misnomer.
So this is an example of how I generated what I needed when designing a
harmonic drive of
whats known as the loose belt variation, and something like this defined
the armature.
module example_el()
{ $fn=128;
cl=30;
cd=40;
el=.50;
scale([1+el,1-el,1])
cylinder(h=cl,d=cd,center=true);
example_el();
But in my case, the requirement that it survive when printed in PETG,
which is much stronger
than PLA, limits el to something in the .04 to .05 area since the drive
gets to the belt via
a 4 row wide ball bearing, also printed, and filled with BB's for balls,
with the actual belt
on the outside of these printed bearings. The basic requirement for the
geometry is such that
the belt with twice the gear ratios number of splines on its outer
surface must be pulled free of
the outer rings at the minimum radius point, the outer rings having
matching splines but one
has 100 splines the other has 102. The 100 is locked to the housing and
the 102 is locked to
the output shaft, giving a backlash free if everything is fitted
correctly, 50/1 gear ratio.
Now the question:
Are you telling me the above should not be called an ellipse?
If that is the case, what is the proper name for it?
Unfortunately while that ran at creep speeds for a year, cranking up the
input speeds to get
the output speed I needed soon ran into 2 problems I could not fix,
first being the max speed
of the stepper motor I was going to use, about 2.5 grand, second was the
difficulty of finding
a lubricant for those BB's that didn't heat from the viscosity when the
BB's were spinning at
those speeds, heating the bearing races to the point of softening the
PETG they were printed
from, eventually destroying them.
So I put that motor in front of a 5/1 $70 worm drive, and printed the
output chuck to drive a
2x2x22 inch stick of hard maple. I'm carving woodworker's vise screws,
but a heck of a lot
better than the 100 yo stuff for sale on ebay at prices up to $259 USD
ATM. Everything from
the stick out is printed from designs I've made in OpenSCAD.
Many thanks for OpenSCAD. Even I can understand most of it at my 87
years, FreeCAD, not so much.
Take care, and stay well everybody.
Cheers, Gene Heskett.
Greetings all;
harmonic drive of
the armature.
module example_el()
{ $fn=128;
cl=30;
cd=40;
el=.50;
example_el();
Now the question:
input speeds to get
but a heck of a lot
- Louis D. Brandeis
Genes Web page <http://geneslinuxbox.net:6309/>
Mon, Aug 8, 2022 2:28 PM
On Sun, 2022-08-07 at 18:45 -0400, gene heskett wrote:
Greetings all;
a harmonic drive of whats known as the loose belt variation, and
something like this defined the armature.
module example_el()
{ $fn=128;
cl=30;
cd=40;
el=.50;
example_el();
I used a BOSL2 example (ellipse, example 6) to generate an ellipse with
your dimensions, extruded it, and placed them so they are congruent.
Dunno about the math, but they look the same in outline.
r=[30,10];
module be() {
back (3.5)
ydistribute(7)
stroke([ellipse(r=r, $fn=100)],width=0.05,color="blue");
module example_el()
{ $fn=128;
cl=30;
cd=40;
el=.50;
linear_extrude (10)
be();
#example_el();
> Greetings all;
> module example_el()
> { $fn=128;
> cl=30;
> cd=40;
> el=.50;
> example_el();
r=[30,10];
module be() {
back (3.5)
ydistribute(7)
module example_el()
{ $fn=128;
cl=30;
cd=40;
el=.50;
linear_extrude (10)
be();
#example_el();
Mon, Aug 8, 2022 4:25 PM
Greetings all;
module example_el()
{ $fn=128;
cl=30;
cd=40;
el=.50;
example_el();
That makes me feel better. I just wish it could be geared below 30/1 but
the amount of
ellipse then needed was rapidly approaching the limitation of PETG vs
working life time.
It was the bearing races, possibly fixable by steel needles in thinner
printed cylinders
with some sort of retainer flanges of minimal height. The loose belts
strength was not
a huge problem, but the thicker sides of the ball bearing races were
when the center was
thick enough to resist the splitting force of the balls. For the project
I wanted to do, the
5/1 worm was optimal.
I'm carving a vise screw, a big one, in hard maple, with buttress
thread, then
printing the half nuts and everything but the oak dowel for a handle,
designed in
OpenSCAD and printed in straight PETG, or carbon fiber reinforced PETG.
Using a 6 mm thread, and 2 starts for a 12mm pitch makes both half nuts
identical.
These are the sort of screws I hope you would build into your workbench
and then
pass on to your grandkids. 100 yo hand carved versions are selling for
nearly $300
on ebay if well preserved, but most aren't. Rode hard and put away wet
would be a
much better description.
Takes a couple days on the mill to make the screw, and 2 weeks to print
the rest of it,
only one working printer I've about $1500 in.
Some pix on my web page in the sig, add "6040.stf/vise-screw-pix". No
commershills
yet, that's actually this machine.
Keeps me out of the bars dont'cha know..
Take care and stay well all.
r=[30,10];
module be() {
back (3.5)
ydistribute(7)
module example_el()
{ $fn=128;
cl=30;
cd=40;
el=.50;
linear_extrude (10)
be();
#example_el();
>> Greetings all;
>> module example_el()
>> { $fn=128;
>> cl=30;
>> cd=40;
>> el=.50;
>> example_el();
the amount of
working life time.
printed cylinders
strength was not
when the center was
I wanted to do, the
thread, then
designed in
identical.
and then
nearly $300
would be a
the rest of it,
commershills
> include <BOSL2/std.scad>
> r=[30,10];
> module be() {
> back (3.5)
> ydistribute(7)
> module example_el()
> { $fn=128;
> cl=30;
> cd=40;
> el=.50;
> linear_extrude (10)
> be();
> #example_el();
- Louis D. Brandeis
Mon, Aug 8, 2022 4:49 PM
On 8/7/2022 3:45 PM, gene heskett wrote:
module example_el()
{ $fn=128;
cl=30;
cd=40;
el=.50;
example_el();
> module example_el()
> { $fn=128;
> cl=30;
> cd=40;
> el=.50;
> example_el();
Certainly its footprint is an ellipse.
But ellipses are 2D, and this is 3D. Wikipedia seems to call it an
elliptic cylinder: https://en.wikipedia.org/wiki/Cylinder#Elliptic_cylinder
Mon, Aug 8, 2022 7:26 PM
module example_el()
{ $fn=128;
cl=30;
cd=40;
el=.50;
example_el();
Ahh, but I was doing the cylinder as a base, then scaling it. Worked
great at motor
speeds up to around a thousand rpm. I suppose Wikipedia is probably
correct, but to
me the 2d/3d difference was a mauchs niche. But I don't do German at all
well so
that is quite likely miss-spelled. My apologies to those who do German
as 1st language.
In English vernacular its mox nix. :)
Thank you Jordan. Take care & stay well.
>> module example_el()
>> { $fn=128;
>> cl=30;
>> cd=40;
>> el=.50;
>> example_el();
great at motor
correct, but to
well so
as 1st language.
- Louis D. Brandeis
mikeonenine@web.de
Tue, Aug 9, 2022 1:26 AM
to
well so
as 1st language.
A mauchs niche - I’m intrigued!
Presumably a female mauch?
Could be related to the dreaded gehuepftwiegesprungen?
gene heskett wrote:
> > to
> > well so
> > as 1st language.
> ## Cheers, Gene Heskett.
> \-Ed Howdershelt (Author, 1940)
> * Louis D. Brandeis
Tue, Aug 9, 2022 3:03 AM
to
well so
as 1st language.
IDK, but since you are from that neck of the woods, how do you spell it?
On 8/8/22 21:30, mikeonenine@web.de wrote:
> gene heskett wrote:
>>> to
>>> well so
>>> as 1st language.
>> * Louis D. Brandeis
- Louis D. Brandeis
terrypingm@gmail.com
Tue, Aug 9, 2022 5:54 AM
mox nix
An American spelling of the German expression "macht nichts" which means roughly, "it makes no difference."
Terry
to
well so
as 1st language.
mox nix
Terry
> gene heskett wrote:
>>> to
>>> well so
>>> as 1st language.
>> * Louis D. Brandeis
- Louis D. Brandeis
MH
Matthieu Hendriks
Tue, Aug 9, 2022 5:57 AM
MOX NIX [1]
An American spelling [2] of the German expression "macht [3] nichts"
which means roughly, "it makes no difference [4]."
-- Terry
all
respectable.
A mauchs niche - I'm intrigued!
it?
I would say "No problem" :)
Groet Matthieu
terrypingm@gmail.com schreef op 2022-08-09 07:54:
> MOX NIX [1]
> -- Terry
>> gene heskett wrote:
> to
> all
> well so
> as 1st language.
>> respectable.
>> * Louis D. Brandeis
it?
respectable.
- Louis D. Brandeis
Links:
[1] https://www.urbandictionary.com/define.php?term=mox+nix
[2] https://www.urbandictionary.com/define.php?term=American%20spelling
[3] https://www.urbandictionary.com/define.php?term=macht
[4] https://www.urbandictionary.com/define.php?term=no%20difference
mikeonenine@web.de
Tue, Aug 9, 2022 8:52 PM
Or:
Doesn’t matter.
Also:
It’s much the same thing if you hop or jump.
What I’d like to hear, though, is the pronunciation!
Or:
Doesn’t matter.
Also:
