Functions with returnvalue?
S
Scalpel78
Wed, Dec 31, 2014 10:36 PM
Hi, this might be a stupid question, but looking through the documentation I
couldn't find the answer.
Does OpenSCAD have a way of defining a function which has a returnvalue?
I'd like to do something like this:
function multiply(a, b) {
return a*b;
or
function substring(string, start, length) {
substring = "";
for (i = [start : start+length])
substring = string[i];
return substring;
I was actually looking for a substring() method so that I could grab parts
of a string, and then that turned into a hunt for making my own function for
it, but I can't see any way to create functions.
View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842.html
Hi, this might be a stupid question, but looking through the documentation I couldn't find the answer. Does OpenSCAD have a way of defining a function which has a returnvalue? I'd like to do something like this: function multiply(a, b) { return a*b; } or function substring(string, start, length) { substring = ""; for (i = [start : start+length]) substring = string[i]; return substring; } I was actually looking for a substring() method so that I could grab parts of a string, and then that turned into a hunt for making my own function for it, but I can't see any way to create functions. -- View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Dec 31, 2014 11:24 PM
All functions have a return value but they are a single expression, not a
procedural body so no return statement.
function multiply(a, b) = a * b;
For iteration use recursion or list comprehension.
function function substring(string, start, length) = start < length ?
concat(string[start], substring(string, start + 1, length) : "";
I think, not tested.
I
return a*b;
or
substring = "";
return substring;
for
All functions have a return value but they are a single expression, not a procedural body so no return statement. function multiply(a, b) = a * b; For iteration use recursion or list comprehension. function function substring(string, start, length) = start < length ? concat(string[start], substring(string, start + 1, length) : ""; I think, not tested. On 31 December 2014 at 22:36, Scalpel78 <frode@lillerud.no> wrote: > Hi, this might be a stupid question, but looking through the documentation > I > couldn't find the answer. > > Does OpenSCAD have a way of defining a function which has a returnvalue? > > I'd like to do something like this: > > function multiply(a, b) { > return a*b; > } > > or > > function substring(string, start, length) { > substring = ""; > for (i = [start : start+length]) > substring = string[i]; > return substring; > } > > I was actually looking for a substring() method so that I could grab parts > of a string, and then that turned into a hunt for making my own function > for > it, but I can't see any way to create functions. > > > > -- > View this message in context: > http://forum.openscad.org/Functions-with-returnvalue-tp10842.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Dec 31, 2014 11:27 PM
This one works:
str(string[start], substring(string, start + 1, length)) : "";
echo(substring("abcdef", 2,4));
ECHO: "cd"
documentation I
return a*b;
or
substring = "";
return substring;
for
This one works: function substring(string, start, length) = start < length ? str(string[start], substring(string, start + 1, length)) : ""; echo(substring("abcdef", 2,4)); ECHO: "cd" On 31 December 2014 at 23:24, nop head <nop.head@gmail.com> wrote: > All functions have a return value but they are a single expression, not a > procedural body so no return statement. > > function multiply(a, b) = a * b; > > For iteration use recursion or list comprehension. > > function function substring(string, start, length) = start < length ? > concat(string[start], substring(string, start + 1, length) : ""; > > I think, not tested. > > On 31 December 2014 at 22:36, Scalpel78 <frode@lillerud.no> wrote: > >> Hi, this might be a stupid question, but looking through the >> documentation I >> couldn't find the answer. >> >> Does OpenSCAD have a way of defining a function which has a returnvalue? >> >> I'd like to do something like this: >> >> function multiply(a, b) { >> return a*b; >> } >> >> or >> >> function substring(string, start, length) { >> substring = ""; >> for (i = [start : start+length]) >> substring = string[i]; >> return substring; >> } >> >> I was actually looking for a substring() method so that I could grab parts >> of a string, and then that turned into a hunt for making my own function >> for >> it, but I can't see any way to create functions. >> >> >> >> -- >> View this message in context: >> http://forum.openscad.org/Functions-with-returnvalue-tp10842.html >> Sent from the OpenSCAD mailing list archive at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > >
B
Bananapeel
Thu, Jan 1, 2015 3:40 PM
function substring(start, count, v) = [for (i=[start:start+count-1]) v[i]];
echo(substring(4, 3, [0,1,2,3,4,5,6,7,8,9,10]));
echo(substring(4, 3,"012345678910"));
You may want to modify it to [start-1:start+count-2] if you want the first
index to be 1.
View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10861.html
function substring(start, count, v) = [for (i=[start:start+count-1]) v[i]]; echo(substring(4, 3, [0,1,2,3,4,5,6,7,8,9,10])); echo(substring(4, 3,"012345678910")); You may want to modify it to [start-1:start+count-2] if you want the first index to be 1. -- View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10861.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
Scalpel78
Thu, Jan 1, 2015 5:45 PM
Thanks for the suggestions, guys. It's almost there, but not quite.
nopheads variant takes in start and end, but I want start and length.
Bananapeels variant returns a list(?) of characters, not a string.
I tried to write my own, like this, but it fails on a syntax error, and I
don't see why:
function substring(string, start, length) = for(i=[start:start+length-1])
str(string[i]);
View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10862.html
Thanks for the suggestions, guys. It's almost there, but not quite. nopheads variant takes in start and end, but I want start and length. Bananapeels variant returns a list(?) of characters, not a string. I tried to write my own, like this, but it fails on a syntax error, and I don't see why: function substring(string, start, length) = for(i=[start:start+length-1]) str(string[i]); -- View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10862.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Fri, Jan 2, 2015 2:20 AM
Sorry, this is probably what you want:
function substring(string, start, length) = length > 0 ? str(string[start],
substring(string, start + 1, length - 1)) : "";
echo(substring("abcdef", 2,3));
ECHO: "cde"
Your version is a syntax error because you have used a for statement where
an expressions is required. Possibly confused by list comprehension syntax
that can build lists with a for statement that can then be used in an
expression where a list is needed.
don't see why:
str(string[i]);
Sorry, this is probably what you want: function substring(string, start, length) = length > 0 ? str(string[start], substring(string, start + 1, length - 1)) : ""; echo(substring("abcdef", 2,3)); ECHO: "cde" Your version is a syntax error because you have used a for statement where an expressions is required. Possibly confused by list comprehension syntax that can build lists with a for statement that can then be used in an expression where a list is needed. On 1 January 2015 at 17:45, Scalpel78 <frode@lillerud.no> wrote: > Thanks for the suggestions, guys. It's almost there, but not quite. > > nopheads variant takes in start and end, but I want start and length. > > Bananapeels variant returns a list(?) of characters, not a string. > > I tried to write my own, like this, but it fails on a syntax error, and I > don't see why: > function substring(string, start, length) = for(i=[start:start+length-1]) > str(string[i]); > > > > -- > View this message in context: > http://forum.openscad.org/Functions-with-returnvalue-tp10842p10862.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
B
Bananapeel
Fri, Jan 2, 2015 11:33 AM
You are right, but why does it matter?
View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10875.html
Scalpel78 wrote > Bananapeels variant returns a list(?) of characters, not a string. You are right, but why does it matter? -- View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10875.html Sent from the OpenSCAD mailing list archive at Nabble.com.
B
Bananapeel
Fri, Jan 2, 2015 11:41 AM
/* Convert all elements of a vector to string and concatenate*/
function toStr(v, i=0) = i<len(v) ? str(v[i], toStr(v, i+1)) : "";
/* Return a range of elements from a vector or string as a vector */
function subSection(start, count, v) = [for (i=[start:start+count-1]) v[i]];
/* Return a range of elements from a vector or string as a string */
function subStr(start, count, v) = toStr(subSection(start, count, v));
echo(subStr(4, 3, [0,1,2,3,4,5,6,7,8,9,10]));
echo(subStr(4, 3,"012345678910"));
View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10876.html
/* Convert all elements of a vector to string and concatenate*/ function toStr(v, i=0) = i<len(v) ? str(v[i], toStr(v, i+1)) : ""; /* Return a range of elements from a vector or string as a vector */ function subSection(start, count, v) = [for (i=[start:start+count-1]) v[i]]; /* Return a range of elements from a vector or string as a string */ function subStr(start, count, v) = toStr(subSection(start, count, v)); echo(subStr(4, 3, [0,1,2,3,4,5,6,7,8,9,10])); echo(subStr(4, 3,"012345678910")); -- View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10876.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
Scalpel78
Fri, Jan 2, 2015 8:54 PM
Thanks Bananapeel! I'm not good enough with the functions, lists, expressions
etc to write those myself, so thanks for making them :)
View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10882.html
Thanks Bananapeel! I'm not good enough with the functions, lists, expressions etc to write those myself, so thanks for making them :) -- View this message in context: http://forum.openscad.org/Functions-with-returnvalue-tp10842p10882.html Sent from the OpenSCAD mailing list archive at Nabble.com.
