Yet another non-manifold part
JS
James Synge
Mon, Jan 28, 2019 1:12 PM
Attached is an STL file produced from this file
https://github.com/jamessynge/openscad-models/blob/master/ioptron_ieq30pro/weatherproofing_2/half_helmet_nut_side.scad
(on github). There are lots of intersections and differences used to
produce this model, and even a projection. An earlier version of the design
printed fine (using cura & octoprint), but when I was exporting yesterday I
saw the dreaded "not 2-manifold" warning. I attempted to reduce the number
of faces that were shared by cutting (difference) holes slightly smaller
than I had previously, knowing that the inserted tube would then overlap
with the solid. This may have made things worse, I'm not sure.
Viewing the rendered model in OpenSCAD doesn't make it obvious that there
is a problem, but the attached STL file is quite corrupted according to
octoprint and www.viewstl.com (including portions that seem like mirrors of
other portions of the model, which should never take that form during the
CSG process!).
For background, I'm modelling something that looks vaguely like a deep sea
diving helmet, then cutting that in half so that I can have parts that can
be screwed together. The STL and .scad files are for one half, though both
halves suffer the problem. You can see an animation of an earlier version
of the model here https://photos.app.goo.gl/TbmKEEihXYpmvaTU7, without
the corruption in the middle (i.e. the mirror of the top of the helmet):
[image: animated-helmet-halves.gif]
Advice on how to diagnose the source of the problem (i.e. the implied or
explicit CSG operation), and especially for then correcting the problem,
would be most welcome.
James
Attached is an STL file produced from this file <https://github.com/jamessynge/openscad-models/blob/master/ioptron_ieq30pro/weatherproofing_2/half_helmet_nut_side.scad> (on github). There are lots of intersections and differences used to produce this model, and even a projection. An earlier version of the design printed fine (using cura & octoprint), but when I was exporting yesterday I saw the dreaded "not 2-manifold" warning. I attempted to reduce the number of faces that were shared by cutting (difference) holes slightly smaller than I had previously, knowing that the inserted tube would then overlap with the solid. This may have made things worse, I'm not sure. Viewing the rendered model in OpenSCAD doesn't make it obvious that there is a problem, but the attached STL file is quite corrupted according to octoprint and www.viewstl.com (including portions that seem like mirrors of other portions of the model, which should never take that form during the CSG process!). For background, I'm modelling something that looks vaguely like a deep sea diving helmet, then cutting that in half so that I can have parts that can be screwed together. The STL and .scad files are for one half, though both halves suffer the problem. You can see an animation of an earlier version of the model here <https://photos.app.goo.gl/TbmKEEihXYpmvaTU7>, without the corruption in the middle (i.e. the mirror of the top of the helmet): [image: animated-helmet-halves.gif] Advice on how to diagnose the source of the problem (i.e. the implied or explicit CSG operation), and especially for then correcting the problem, would be most welcome. James
Tue, Jan 29, 2019 1:15 AM
This is what Kisslicer reports. Looks like you have some numerical problems
at the colored portions.
http://forum.openscad.org/file/t887/helmet.png
This is what Kisslicer reports. Looks like you have some numerical problems at the colored portions. <http://forum.openscad.org/file/t887/helmet.png> -- Sent from: http://forum.openscad.org/
JS
James Synge
Tue, Jan 29, 2019 7:47 PM
I definitely agree that there are problems! ;-) I had seen that by using
octoprint and meshlab. But, since I didn't generate the vertices, edges and
triangles myself, I'm struggling with how to avoid having OpenSCAD (or
CGAL) generate the non-manifold object.
I definitely agree that there are problems! ;-) I had seen that by using octoprint and meshlab. But, since I didn't generate the vertices, edges and triangles myself, I'm struggling with how to avoid having OpenSCAD (or CGAL) generate the non-manifold object. On Mon, Jan 28, 2019 at 8:17 PM Parkinbot <rudolf@digitaldocument.de> wrote: > This is what Kisslicer reports. Looks like you have some numerical problems > at the colored portions. > > <http://forum.openscad.org/file/t887/helmet.png> > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
JS
James Synge
Tue, Jan 29, 2019 7:50 PM
Oh, and I took a look at CGAL to see if there were some hints about
non-manifold results, and noticed they have a "mesh repair" project
underway: https://github.com/CGAL/cgal/projects/2#card-12258256
Not sure if any of these have landed in the version of CGAL used by
OpenSCAD.
problems
Oh, and I took a look at CGAL to see if there were some hints about non-manifold results, and noticed they have a "mesh repair" project underway: https://github.com/CGAL/cgal/projects/2#card-12258256 Not sure if any of these have landed in the version of CGAL used by OpenSCAD. On Tue, Jan 29, 2019 at 2:47 PM James Synge <james.synge@gmail.com> wrote: > I definitely agree that there are problems! ;-) I had seen that by using > octoprint and meshlab. But, since I didn't generate the vertices, edges and > triangles myself, I'm struggling with how to avoid having OpenSCAD (or > CGAL) generate the non-manifold object. > > On Mon, Jan 28, 2019 at 8:17 PM Parkinbot <rudolf@digitaldocument.de> > wrote: > >> This is what Kisslicer reports. Looks like you have some numerical >> problems >> at the colored portions. >> >> <http://forum.openscad.org/file/t887/helmet.png> >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >
Tue, Jan 29, 2019 7:59 PM
The main way of getting non-manifold objects is generating vertices that
are almost aligned but not quite due to floating point rounding errors.
Then OpenSCAD snaps them to a grid and that can corrupt topology. If you
have something meeting very close offset it by a small amount so the
vertices are distinct. I use 1/128.
Always clear the cache before generating an STL as OpenSCAD can cache a
lower resolution mesh that is is broken. F6 from a clear cache can often
give cleaner results.
OpenSCAD.
problems
The main way of getting non-manifold objects is generating vertices that are almost aligned but not quite due to floating point rounding errors. Then OpenSCAD snaps them to a grid and that can corrupt topology. If you have something meeting very close offset it by a small amount so the vertices are distinct. I use 1/128. Always clear the cache before generating an STL as OpenSCAD can cache a lower resolution mesh that is is broken. F6 from a clear cache can often give cleaner results. On Tue, 29 Jan 2019 at 19:51, James Synge <james.synge@gmail.com> wrote: > Oh, and I took a look at CGAL to see if there were some hints about > non-manifold results, and noticed they have a "mesh repair" project > underway: https://github.com/CGAL/cgal/projects/2#card-12258256 > Not sure if any of these have landed in the version of CGAL used by > OpenSCAD. > > On Tue, Jan 29, 2019 at 2:47 PM James Synge <james.synge@gmail.com> wrote: > >> I definitely agree that there are problems! ;-) I had seen that by using >> octoprint and meshlab. But, since I didn't generate the vertices, edges and >> triangles myself, I'm struggling with how to avoid having OpenSCAD (or >> CGAL) generate the non-manifold object. >> >> On Mon, Jan 28, 2019 at 8:17 PM Parkinbot <rudolf@digitaldocument.de> >> wrote: >> >>> This is what Kisslicer reports. Looks like you have some numerical >>> problems >>> at the colored portions. >>> >>> <http://forum.openscad.org/file/t887/helmet.png> >>> >>> >>> >>> -- >>> Sent from: http://forum.openscad.org/ >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Tue, Jan 29, 2019 8:12 PM
How do I clear the cache?
On Tue, Jan 29, 2019 at 07:59:11PM +0000, nop head wrote: > Always clear the cache before generating an STL as OpenSCAD can cache a > lower resolution mesh that is is broken. F6 from a clear cache can often > give cleaner results. How do I clear the cache? Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** The plan was simple, like my brother-in-law Phil. But unlike Phil, this plan just might work.
Tue, Jan 29, 2019 8:16 PM
With the Design / Flush Caches menu option.
With the Design / Flush Caches menu option. On Tue, 29 Jan 2019 at 20:13, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: > On Tue, Jan 29, 2019 at 07:59:11PM +0000, nop head wrote: > > Always clear the cache before generating an STL as OpenSCAD can cache a > > lower resolution mesh that is is broken. F6 from a clear cache can often > > give cleaner results. > > How do I clear the cache? > > Roger. > > -- > ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 > ** > ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** > The plan was simple, like my brother-in-law Phil. But unlike > Phil, this plan just might work. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
JS
James Synge
Thu, Jan 31, 2019 1:10 PM
Thanks so much for the hint about flushing caches. This "seemed" to fix the
problem, except I then realized that I had generated the STL files from the
command line. Reconsidering that caused me to see the problem: my command
line was using the released version of openscad, but I'm using the nightly
build for the GUI. Oops! It certainly explains why I was getting warnings
about assert being an unknown module.
Thanks again,
James
OpenSCAD.
problems
Thanks so much for the hint about flushing caches. This "seemed" to fix the problem, except I then realized that I had generated the STL files from the command line. Reconsidering that caused me to see the problem: my command line was using the released version of openscad, but I'm using the nightly build for the GUI. Oops! It certainly explains why I was getting warnings about assert being an unknown module. Thanks again, James On Tue, Jan 29, 2019, 3:00 PM nop head <nop.head@gmail.com wrote: > The main way of getting non-manifold objects is generating vertices that > are almost aligned but not quite due to floating point rounding errors. > Then OpenSCAD snaps them to a grid and that can corrupt topology. If you > have something meeting very close offset it by a small amount so the > vertices are distinct. I use 1/128. > > Always clear the cache before generating an STL as OpenSCAD can cache a > lower resolution mesh that is is broken. F6 from a clear cache can often > give cleaner results. > > On Tue, 29 Jan 2019 at 19:51, James Synge <james.synge@gmail.com> wrote: > >> Oh, and I took a look at CGAL to see if there were some hints about >> non-manifold results, and noticed they have a "mesh repair" project >> underway: https://github.com/CGAL/cgal/projects/2#card-12258256 >> Not sure if any of these have landed in the version of CGAL used by >> OpenSCAD. >> >> On Tue, Jan 29, 2019 at 2:47 PM James Synge <james.synge@gmail.com> >> wrote: >> >>> I definitely agree that there are problems! ;-) I had seen that by using >>> octoprint and meshlab. But, since I didn't generate the vertices, edges and >>> triangles myself, I'm struggling with how to avoid having OpenSCAD (or >>> CGAL) generate the non-manifold object. >>> >>> On Mon, Jan 28, 2019 at 8:17 PM Parkinbot <rudolf@digitaldocument.de> >>> wrote: >>> >>>> This is what Kisslicer reports. Looks like you have some numerical >>>> problems >>>> at the colored portions. >>>> >>>> <http://forum.openscad.org/file/t887/helmet.png> >>>> >>>> >>>> >>>> -- >>>> Sent from: http://forum.openscad.org/ >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
