JG
Jonathan Gilbert
Fri, Oct 14, 2022 12:15 AM
Here's a poser that I haven't really found a good answer to.
There seem to be a subset of function calls that work within user-defined
functions without any sort of special handling, that don't return anything,
and allow you to stack or chain without returning a value. An example might
be the use of let() or assert() here: these calls don't return a value,
maybe they impart some scoped change, maybe not, but ultimately the value
of m is what's returned from myfunc():
function myfunc(arg) = let(m = 1 + arg ) assert(arg > 0, "arg must be
(I'm not sure what we're calling this behavior in OpenSCAD parlance;
functions that return no value? void functions? chained functions? I've no
idea. [1] below seems to imply that functions have children they can opt to
return or not, though it's probably something quite different than the
children() that are available to modules.)
Regardless of whatever term used to describe this behavior: Can we create
user functions of the same type? A function that returns nothing, that
can't be misinterpreted as a return value for another user function? I'm
thinking something along the lines of this (admittedly contrived) example:
function mylog(msg) = echo( ($preview) ? msg : undef );
function myfunc(arg) = let( m = 1 + arg ) mylog(str("using ", m, " for
whatever")) m;
g = myfunc(5);
And, if not, how would you implement this behavior? Right now, I think
the easiest way is to capture and discard the return of whatever function
you're calling within a let():
function myfunc(arg) = let( m = 1 + arg, _ = mylog(str("using ", m, " for
...but that gets a little ugly when you're doing that 8 or 10 or more than
20 times in a single let() call. Is there a better way?
of `m` is what's returned from myfunc():
> greater than zero") m;
> whatever")) m;
> g = myfunc(5);
And, if not, how would you implement this behavior? Right now, I _think_
> whatever")) ) m;
[1]:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Other_Language_Features#Using_assertions_in_function
- Jon Gilbert
jong@jong.org / jgilbertsjc@gmail.com
Fri, Oct 14, 2022 12:26 AM
There are unfortunately several circumstances where you have to use a dummy
return value. I do this all the time:
let( blah, blah, blah, dummy=echo(something), ....)
More subtly, if you are writing a module with asserts or echoes you may
need to do the same thing:
module foo(x){
dummyA = echo(x);
dummy = assert(x>0);
y = 17/x;
Why are dummy variables necessary? Because assignments run before modules,
and if you don't use the dummy assignment, then echo and assert are
modules, so then y=17/x runs first, and you get an error if x is zero
instead of catching it with your assert. And the echo never runs because
the error happens first! With dummy variables, the assert and echo
statements become assignments and run in the obvious order, and you'll see
your echo output, and hit the assert before you try to compute with x.
whatever")) m;
g = myfunc(5);
module foo(x){
dummyA = echo(x);
y = 17/x;
>> whatever")) m;
>> g = myfunc(5);
>> whatever")) ) m;
> [1]:
> - Jon Gilbert
Fri, Oct 14, 2022 12:33 AM
You can approximate...
...wth
module mylog(msg) { echo( ($preview) ? msg : undef ); }
// Example usage:
$preview = true;
mylog("HI");
dummy return value. I do this all the time:
module foo(x){
dummyA = echo(x);
y = 17/x;
modules, and if you don't use the dummy assignment, then echo and assert
are modules, so then y=17/x runs first, and you get an error if x is zero
whatever")) m;
g = myfunc(5);
than 20 times in a single let() call. Is there a better way?
...wth
// Example usage:
$preview = true;
mylog("HI");
> module foo(x){
> dummyA = echo(x);
> y = 17/x;
>>> whatever")) m;
>>> g = myfunc(5);
>>> whatever")) ) m;
>> [1]:
>> - Jon Gilbert
Fri, Oct 14, 2022 12:37 AM
You can't use a module inside a let(), so that won't work. There is no way
to do what he wants to do.
On Thu, Oct 13, 2022 at 8:34 PM Leonard Martin Struttmann <
...wth
// Example usage:
$preview = true;
mylog("HI");
module foo(x){
dummyA = echo(x);
y = 17/x;
user-defined functions without any sort of special handling, that don't
return anything, and allow you to stack or chain without returning a value.
An example might be the use of let() or assert() here: these calls don't
return a value, maybe they impart some scoped change, maybe not, but
ultimately the value of m is what's returned from myfunc():
create user functions of the same type? A function that returns nothing,
that can't be misinterpreted as a return value for another user function?
I'm thinking something along the lines of this (admittedly
contrived) example:
whatever")) m;
g = myfunc(5);
> ...wth
> // Example usage:
> $preview = true;
> mylog("HI");
>> module foo(x){
>> dummyA = echo(x);
>> y = 17/x;
>>> ultimately the value of `m` is what's returned from myfunc():
>>> contrived) example:
>>>> whatever")) m;
>>>> g = myfunc(5);
>>>> for whatever")) ) m;
>>> [1]:
>>> - Jon Gilbert
Fri, Oct 14, 2022 1:39 AM
don't return anything, and allow you to stack or chain without
returning a value.
Yeah, those aren't really functions. They are more like statements in
the sub-language of expressions... and as Adrian says, there's no way to
define them from a user program.
You can do something sort of similar by passing the value that follows
them as an argument to your function.
Say you have:
function f(arg) = echo(arg) arg*2;
You want to replace echo() with your own function. (Which, note, can't
take an unspecified number of arguments like echo can.)
function myecho(msg, val) = echo(str("myecho: ", msg)) val;
and then your original becomes:
function f(arg) = myecho(arg, arg*2);
> returning a value.
Say you have:
