Hi zapta,
accepted by the mailing list yet", so nobody gets it unless they look.
You need to subscribe to the mailing list
Also, don't use <"raw"> Nabble forum s/w cuts it out of the mailing list,
use <"quote"> instead - DON'T use the 'quote' button, it inserts the
original message, like so
zapta wrote
Is it possible to write operator that will take an object as an argument?
For example, in the program below the module
my_part_with_first_layer_inset()
and insets its first layer. I would like to write it as a general
operator that can accept
as an argument. for example
rather than relying on a hard coded name my_part().
eps = 0.01;
inset_width = 0.3;
inset_height = 0.2;
// An arbitrary part wich is placed at z=0.
module my_part() {
translate([-5, -5, 0]) cube([10, 10, 5]);
cube([6, 6, 20], center=true);
// The arbitrary part with first layer inset.
module my_part_with_first_layer_inset() {
children(); // <<==== pass this as an arg
cube([100, 100, 2*inset_height], center=true);
linear_extrude(height=inset_height+eps)
offset(r = -inset_width)
projection(cut=true)
my_part(); // <<==== pass this as an arg
translate([0,20,0])
color("orange")
my_part();
translate([20,0,0])
my_part_with_first_layer_inset(inset_width=2)
cylinder(d=20,h=2);
View this message in context: http://forum.openscad.org/Passing-objects-as-arguments-tp19877p19879.html
Hi zapta,
<http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1> ,
> takes the output of
> my_part()
> my_part
> inset(my_part())
> or
> inset() my_part()
This is how to do it:
> eps = 0.01;
> inset_width = 0.3;
> inset_height = 0.2;
> module my_part() {
> difference() {
> difference() {
> translate([0,20,0])
> color("orange")
> my_part();
> translate([20,0,0])
> cylinder(d=20,h=2);
