I am trying to design a dock for these ryobi batteries
but I am having problems with the square with one round side above the
base as well as a slanted feature on the top thing that enters the
tool
here are a ton of pictures of the tool
https://www.amazon.com/Ryobi-P102-Genuine-Lithium-Cordless/dp/B00AGCHVS6/ref=sr_1_4?crid=10718TR6KPQKF&keywords=ryobi+18v+lithium+battery&qid=1560404515&s=hi&sprefix=ryobi+18v+li%2Ctools%2C349&sr=1-4
not advertising amazon here just was convenient because it has
pictures from every angle.
there is the base of the battery the more squared off side pints
towards the front at least in my impact and drill.
above the base there is a about 5.4mm high squarish thing where the
holding clamps protrude from everything is fairly easy except the
rounded back I have no clue how to model this.
unlike the protruding top part where the rounded back is is a cylinder
with the same diameter as the cube-ish thing in front of it. the
problem on this thing both the base and the squarish thing above it
have rounding(s) that followed to their natural conclusion are bigger
than the model.
Also if you look at the top view you can see that the protrusion and
the front of the base have slanted roundish features that are not even
close to cylindrical it's more like a section of an extruded ellipse.
those are my problems any suggestions would be welcome.I will paste
the code I have so far below so you can see what I do have
terramir
PS here it is
ryobibattdock();
module ryobibattdock(){
// raw data 33 27.6 21.5 16.6 2.8
//base 59.2 61.4 65 1.7
//34.5 40 43 35.4 9.3 52.3 86.5
union(){
cube([61.4,49,5.5]);
translate([16.9,26,5.4])
cube([27.6,19.31,43.6]);
translate([30.7,45.2,5.4]) cylinder(r=13.8,h=43.6,$fn=32)
// cutting corners to be added outside of module
translate([-0.1,-0.1,-0.1]) cube ([5.1,5.1,5.7]);
translate([61.4-5,-0.1,-0.1]) cube ([5.1,5.1,5.7]);
// there be rounded corners
translate([5,5,0])cylinder(r=5, h=5.4,$fn=32);
translate([61.4-5,5,0])cylinder(r=5, h=5.4,$fn=32);
As long as you don't want it for commercial use, you can use my one:
https://www.thingiverse.com/thing:70938
hmmm just add the clips and ink it in a block to cut it out well there
are some slight things missing but yeah I can add that,
it's for my wall mount LOL need to cut the batteries out of the block
for printing, also I wanted to make two mounts that can get the
contacts thinking about running a printer off two of these batteries
:p
thanks that is a great start.
terramir
Also https://www.thingiverse.com/thing:82868
