Importing DXF as lines
N
NathanA
Sat, Jun 6, 2015 3:05 AM
Why does this DXF file import with alternating solid and hollow parts? I just
want it to import the lines, which I will then offset to give them some
width.
If only enclosed shapes are possible and it is impossible to import lines,
is there a way I can edit the DXF so that it imports the shape I want?
http://forum.openscad.org/file/n12807/Capture.png
Untitled.dxf http://forum.openscad.org/file/n12807/Untitled.dxf
View this message in context: http://forum.openscad.org/Importing-DXF-as-lines-tp12807.html
Why does this DXF file import with alternating solid and hollow parts? I just want it to import the lines, which I will then offset to give them some width. If only enclosed shapes are possible and it is impossible to import lines, is there a way I can edit the DXF so that it imports the shape I want? <http://forum.openscad.org/file/n12807/Capture.png> Untitled.dxf <http://forum.openscad.org/file/n12807/Untitled.dxf> -- View this message in context: http://forum.openscad.org/Importing-DXF-as-lines-tp12807.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Jun 6, 2015 9:37 AM
There is no such thing as a line in Openscad. Only closed 2D and 3D shapes.
just
width.
There is no such thing as a line in Openscad. Only closed 2D and 3D shapes. On 6 June 2015 at 04:05, NathanA <napter@gmail.com> wrote: > Why does this DXF file import with alternating solid and hollow parts? I > just > want it to import the lines, which I will then offset to give them some > width. > > If only enclosed shapes are possible and it is impossible to import lines, > is there a way I can edit the DXF so that it imports the shape I want? > > <http://forum.openscad.org/file/n12807/Capture.png> > > Untitled.dxf <http://forum.openscad.org/file/n12807/Untitled.dxf> > > > > -- > View this message in context: > http://forum.openscad.org/Importing-DXF-as-lines-tp12807.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
