DIL test clip in openscad ?
DS
David Slipper
Sat, May 9, 2020 12:20 AM
Has anyone come across an scad design for a DIL test clip (ie a test
clip that goes on top of a Dual In Line IC package to monitor signals) ?
Not too bothered about the pin count 8 or 16 or thereabouts would be
fine - I just need some ideas.
I came across an STL file for these but I need to "tweak" it.
TIA
Dave
Has anyone come across an scad design for a DIL test clip (ie a test clip that goes on top of a Dual In Line IC package to monitor signals) ? Not too bothered about the pin count 8 or 16 or thereabouts would be fine - I just need some ideas. I came across an STL file for these but I need to "tweak" it. TIA Dave
Sat, May 9, 2020 9:07 AM
No but what do people use for contacts when they print their own?
TIA
Dave
No but what do people use for contacts when they print their own? On Sat, 9 May 2020 at 01:23, David Slipper <softfoot@hotmail.com> wrote: > > Has anyone come across an scad design for a DIL test clip (ie a test > clip that goes on top of a Dual In Line IC package to monitor signals) ? > > Not too bothered about the pin count 8 or 16 or thereabouts would be > fine - I just need some ideas. > > I came across an STL file for these but I need to "tweak" it. > > TIA > Dave > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
lar3ry
Wed, May 13, 2020 2:07 AM
softfoot wrote > Has anyone come across an scad design for a DIL test clip (ie a test > clip that goes on top of a Dual In Line IC package to monitor signals) ? > > Not too bothered about the pin count 8 or 16 or thereabouts would be > fine - I just need some ideas. > > I came across an STL file for these but I need to "tweak" it. You didn't mention what, specifically, you found, but here are four for your consideration. https://www.thingiverse.com/thing:2681296 https://www.thingiverse.com/thing:1104612 https://www.thingiverse.com/thing:2039755 https://www.thingiverse.com/thing:2039755 -- Sent from: http://forum.openscad.org/
lar3ry
Wed, May 13, 2020 4:07 AM
Wire, mostly.
nophead wrote > No but what do people use for contacts when they print their own? Wire, mostly. -- Sent from: http://forum.openscad.org/
