can I ask why you are using the apt get install command for openscad?
the repository version 2015.03-2 is > 3 years old.
why don't you try the latest openscad appimage? and see if that works for
you?
73,
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
Raspberry Pi and 3D designer
On Sun, Mar 18, 2018 at 2:25 PM, Rob Ward rl.ward@bigpond.com wrote:
Hi Florian and everybody else,
Please excuse the nature of this reply (ie obliquely about OpenSCAD), but
as I stated in a previous post I am do not have a very deep understanding
of Linux, and compiling libraries and applications onto the system is one
of my (many?) weakest points. So here I go...
In preparation I have
sudo apt remove openscad
then I have visited this page, https://sourceforge.net/
projects/glew/files/glew/2.0.0/ to the latest OpenCSG (I hope)
and installed advised build tools with
sudo apt-get install build-essential libxmu-dev libxi-dev
libgl-dev libosmesa-dev git
then followed links to
and downloaded this version "glew-2.0.0".
Extracted it to a folder. Entered the folder with a Terminal
and executed the following commands...
make
sudo make install
make clean
These appeared to run OK.
I then reinstalled OpenScad
sudo apt install openscad
Which again worked without a hitch, and openSCAD reappeared and works,
however the "F5+error" problem remains and none of what I have done above
appears to have made any difference.
Here is the start of the current library/build dump,
OpenSCAD Version: 2015.03-2
System information: Linux 4.4.0-116-generic #140-Ubuntu SMP Mon Feb 12
21:23:04 UTC 2018 x86_64 Ubuntu 16.04.4 LTS 4 CPUs 3.85 GB RAM
Compiler: GCC "5.4.0 20160609" 64bit
Boost version: 1_58
Eigen version: 3.2.92
CGAL version, kernels: 4.7, Cartesian, Extended_cartesian, Epeck
OpenCSG version: OpenCSG 1.4.0
The items in red have not changed, so I still have the same OpenSCAD and
OpenCSG versions.
Please let me apologise first, I don't expect people to micro-manage me,
as your (and everybody else's!!) time is valuable. However if anyone could
identify where I am going wrong and point me in the right direction it
would be much appreciated eg a tutorial they can recommend. I would like to
be able compile versions of OpenSCAD eventually to try out new features.
Many thanks in advance,
Rob
PS Apologies Florian for the PM I overlooked hitting the reply to the
group, and did not intend to heap that reply on you.
On 17/03/18 03:47, Chris Camacho wrote:
I've seen it just occasionally, I'm periodically upto date with github...
(on Void Linux)
can't reliably reproduce so just wrote it off as "one of those things" I
assume its an OpenCSG issue??
restarting always resolves it for me...
On 16/03/18 16:03, NateTG wrote:
RobWLakes wrote
This where my confusion comes in, as after returning color to "green", the
F5 no longer renders anything, though F6 renders all three elements
properly. If I save the file, and reload it, F5 will work again. I have
tried Flushing the Caches, but that does not help.
What am I missing?
Rob
Using: Ubuntu (16.04.4LTS) Mate, and openSCAD 2015.03-2
I'm experiencing a similar issue with a 2018 build on Debian. I think
it's
worth an error report on github. I wonder if it's some kind of issue with
a
rendering cache.
for the sake of others that come here after you... you may want to make
a different thread
Look for as many of the development packages as you can through your
package manager, you should only need to compile and install a few libs
from source...
the openSCAD build process is fairly painless once you have all the
dependencies installed...
but as I stated in a previous post I am do not have a very deep
understanding of Linux, and compiling libraries and applications onto
the system is one of my (many?) weakest points. So here I go...
https://sourceforge.net/projects/glew/files/glew/2.0.0/ to the latest
OpenCSG (I hope)
sudo apt-get install build-essential libxmu-dev libxi-dev libgl-dev
libosmesa-dev git
make
sudo make install
make clean
above appears to have made any difference.
Boost version: 1_58
and OpenCSG versions.
me, as your (and everybody else's!!) time is valuable. However if
anyone could identify where I am going wrong and point me in the
right direction it would be much appreciated eg a tutorial they can
recommend. I would like to be able compile versions of OpenSCAD
Rob
github... (on Void Linux)
things" I assume its an OpenCSG issue??
"green", the
have
What am I missing?
Rob
think it's
issue with a
rendering cache.
Ok, I will try again and report back in a week or two on another thread eg OpenCSG upgrade or some such thing.
Thanks Chris,
Cheers,
Rob
Cheers, RobW
On 19 March 2018 9:56:31 pm AEDT, Chris Camacho chris@bedroomcoders.co.uk wrote:
a different thread
from source...
OpenCSG (I hope)
libosmesa-dev git
make
sudo make install
make clean
works,
12
Boost version: 1_58
Rob
"green", the
elements
I
have
What am I missing?
Rob
think it's
issue with a
rendering cache.
I've tried updating the AppImage builds so they are using the
newest OpenCSG. Both should report OpenCSG 1.4.2 in the library
info window.
Release version 2015.03-3:
https://download.opensuse.org/repositories/home:/t-paul/AppImage/OpenSCAD-Release-latest-x86_64.AppImage
Dev Snapshot:
https://download.opensuse.org/repositories/home:/t-paul/AppImage/OpenSCAD-Nightly-latest-x86_64.AppImage
Thank you Torsten, that is very helpful. I will be home in about 5days and will report back after that.
Cheers, RobW
info window.
Dev Snapshot:
Cheers Torsten, that worked perfectly for me. Much Appreciated.
Library correctly reported as below. You have made it so simple!!!
Errors no longer jeopardize the F5 preview mode.
Are these AppImage versions clearly advertised on the OpenSCAD site? I
did not find them.
RobW
info window.
Dev Snapshot:
Great, thanks for reporting back.
site? I did not find them.
For small values of clearly, yes. :-)
As of now only the Dev-Snapshot for Intel/64bit is linked in
the download section.
This is still pretty new and not too well tested on various
distributions and we also rely on OBS (OpenSUSE build service)
to build those. There's still some changes going on there which
make it a bit unstable, e.g. the ARM builds are currently not
working, I don't know why yet.
